Bolt-on vs. Slip-on's
calif562
#1 Unread post by calif562 »
What's the difference between bolt-on's and slip-on's? Are they the same thing? I'm thinking of replacing my exhaust.
JCS
#2 Unread post by JCS »
Slip-ons are normally just the rear section after the collectors or head pipes. Bolt-ons are a complete system from the heads on.
clueless
#3 Unread post by clueless »
I'm little bit confused. The head pipe is just a hollow tube. What's the difference between replacing the slip-on and replacing the entire exhaust system?
Psyco Diver 69
#4 Unread post by Psyco Diver 69 »
thats a big differnce. With new full exhuast the head pipe is usually larger and where the pipes merge are in different spots too because that can effect performance too.
Jake 20/m
1980 Honda CB750 Custom
1972 Oldsmobile 442
1985 Oldsmobile Cutlass Supreme
clueless
#5 Unread post by clueless »
Got it. That's why I'm called "clueless".
keysman
#6 Unread post by keysman »
An aftermarket header might also have a different exterior coating that might be more resistant to blueing.
Old & Busted: 2003 BMW F650CS
FIREBIRD
#7 Unread post by FIREBIRD »
i to, trying to decide slip on, or new pipes, im leaning toward a slip on, called holeshot, should give me about 8 more horse power,ive installed a power commander usb, to richen, or lean the bike out. :mrgreen:
jmillheiser
Legendary 2500
Legendary 2500
#8 Unread post by jmillheiser »
whats wrong with heat bluing on pipes. I always thought it looked cool.
Mac
#9 Unread post by Mac »
I put a Scorpion (carbon fiber) slip on my R6 and it works great, and gave me just enough noise to get noticed in traffic. Check them out the web site even has a thing where you can listen to your bike with the pipes on.
Mac
"Moderatio est figmentam!"
