Yes, it does. I was skeptical from reading another forum where a guy said it made no difference. Then I read a road test on the zrx1200, and they said it had pretty good protection. The farings looked similar, so I went for it. It is adjustable, so don't be afraid to adjust it after installation and a test ride. I needed to, and it improved. Also, be aware that all mounting holes in the faring are put there by you, so careful measuring/drilling is important. You also have to bend the lower brackets to custom fit them to your headlight housing bolts. After mounting it, it's a trial and error process, but it gives you one more excuse to ride , like you need that.mt_100 wrote: Does it really make that much of a difference? .
Update on wind protection
- ronboskz650sr
- Legendary 750
Ride safe...God bless!
-Ron
-Ron
