THE 2010 BMW R 1200 GS Adventure: Another Adventure Begins
05.11.2009 Press Kit
Woodcliff Lake, NJ – November 5, 2009…No wonder it’s called unstoppable! The BMW G 1200 GS Adventure looks as if it invented the term - and it certainly has defined it in the motorcycle world. This is partly due to the range of features which have become almost as legendary as the bike itself. On this machine you can handle potholes with 20 mm more clearance than on the R 1200 GS. Add to that excellent ergonomics, optimum gearing for every terrain, and a chassis which - whether fully loaded or not - will allow you to thrill your passenger as well as surprise anyone ahead of you.
With the introduction of the 2010 BMW R 1200 GS Adventure, BMW Motorrad is adding yet another chapter to the epic adventure of its highly successful GS models which, for almost three decades, have been the epitome of the large-capacity grand touring enduro.
Building upon the former generation of the R 1200 GS and R 1200 GS Adventure, which already offered supreme power and performance as well as a broad range of practical riding qualities for long tours combined with supreme pleasure on winding country and mountain roads, BMW Motorrad is now enhancing this standard to an even higher level. A more powerful engine with extra torque results in even greater driving dynamics both onroad and offroad.
The main features of the 2010 BMW R 1200 GS Adventure at a glance:
* New, even more dynamic engine now with two overhead camshafts per cylinder and valves in radial arrangement.
* Increase in engine output by 5 per cent to 110 hp at 7,750 rpm and maximum torque to 88 lb-ft at 6,000 rpm.
* Increase in maximum engine speed from 8,000 to 8,500 rpm with an even wider power band.
* Significantly better acceleration and torque.
* Electronically controlled exhaust flap for an aggressive muscular sound.
* Color variants of the R 1200 GS Adventure: Smoke Grey matt metallic and
Brilliant Yellow metallic.
* Options and accessories tailored to the model with BMW’s usual high level of quality.
In its construction principle and fundamental layout, the new flat-twin engine is the same as the Double Overhead Camshaft (DOHC) engine on the BMW HP2 Sport. In its latest generation, the engine has been carefully updated and optimized for the R 1200 GS Adventure, tailored to the specific requirements of a grand touring enduro.
With the 1,170-cc Boxer engine on the former model already ensuring supreme power under all conditions and in all situations, the new R 1200 GS Adventure has even more to offer in virtually every respect. Delivering maximum output of 110 hp, reaching top engine speed now increased by 500 to 8,500 rpm, and with an even broader power band the new R 1200 GS Adventure is even more dynamic, powerful and muscular in terms of both torque and acceleration throughout the entire speed range -- setting the standard once again for the grand touring enduro in terms of riding dynamics.
New DOHC cylinder heads for even more efficient cylinder charge
Designed and built at the outset for higher engine speed, the new flat-twin engine in the
R 1200 GS Adventure, like the engine featured in the BMW HP2 Sport, comes with two overhead, chain-driven camshafts per cylinder. The valves are operated by very light rocker arms able to withstand high engine speeds due to their low weight alone. Radial arrangement of the four valves is accomplished by the compact combustion chambers. Like on the former model, the fuel/air mixture is ignited by two spark plugs (HP2 Sport: one spark plug), while the compression ratio remains at 12.0:1.
Thanks to efficient knock control, the R 1200 GS Adventure is able to run on premium (plus) fuel with an octane rating of 95-98 RON (maximum output is measured at 98 RON). Under certain conditions, there may be a very small loss of torque and a slight increase in fuel consumption as soon as knock control cuts in. On long tours where the rider might be required to use inferior fuel, the engine may also run on 91 RON regular fuel, using specific fuel injection data available as special equipment free of charge from the factory.
Horizontal arrangement of the camshafts in the direction of travel gives the new flat-twin engine two particular technical features: Each camshaft controls one intake and exhaust valve and, due to the radial arrangement of the valves, the cams come with a conical profile. To increase both output and torque, fuel volume has been increased throughout the entire speed range by increasing valve plate diameter over the former models from 1.42–1.54 inches on the intake side and 1.22–1.30 inches on the exhaust side.
Intake and exhaust timing on the two camshafts has been optimized in particular for increased power at low and medium engine speeds and for even faster, free-revving engine performance throughout the entire range. To increase the free valve cross-section, valve lift is up by 0.415 inches on the intake and 0.365 inches on the exhaust side to 0.425 inches on both sides. Valve clearance is adjusted by light semi-hemispherical shims.
More power and extra torque throughout the entire speed range
The existing ratio of bore and stroke of 3.98 : 2.87 inches remains unchanged from the former model, as does the engine’s cubic capacity of 1,170 cc. Other features likewise carried over from the previous engine are the crankshafts and connecting rods as well as their mounts and bearings, while the two new cast-aluminum pistons have been re-designed to match the change in combustion chamber geometry.
Interacting with the upgraded intake system, now featuring black instead of silver throttle butterfly manifolds as on the former model, measuring 1.97 inches instead of formerly 1.85 inches (HP2 Sport: 52 mm/2.05") opening clearance and with newly designed intake air manifolds and an air filter element with higher volume capacity, the engine now develops maximum output of 110 hp at 7,750 rpm and peak torque of 88 lb-ft at 6,000 rpm. An oil cooler ensures stable engine temperatures even when riding to the extreme.
In all, the modifications to the engine provide a significantly more homogeneous flow of power and torque throughout the entire speed range. In this process of technical development, the engine now features magnesium-colored cylinder head covers with two instead of the former four fastening bolts and have an even more dynamic design. A valve cover guard made of aluminum or plastic as well as a chrome-plated aluminum cylinder head cover may be installed as accessory items.
The exhaust system features two manifolds with the same design, length and diameter as the previous model, while a modified interference pipe regulates the change in vibration conditions in the exhaust system. Featuring an exhaust flap controlled by an electric motor as well as opening and closing cables, the new BMW R 1200 GS Adventure provides a particularly throaty boxer sound naturally in full compliance with legal standards. To reduce ram pressure and improve the sound of the engine even further, the rear silencer remains the same in design as on the former model and comes with a completely new interior structure.
Ideal transmission of power through six-speed gearbox and drive shaft
Power is transmitted as before by the proven six-speed gearbox with larger bearing diameters and a modified distance between the individual shafts previously upgraded technically for the 2008 model year. In the process, the gear ratios were once again changed and the finale drive has been modified from 2.82 to 2.91.
In conjunction with the new, more powerful engine, there is significantly more torque throughout the entire range of engine speed. The new R 1200 GS Adventure also benefits from improved shifting with an optimized power/travel curve for precise gearshift and clear feedback at all times.
The maintenance-free drive shaft to the rear wheel also remains unchanged, relieving the rider of annoying and time-consuming maintenance requirements, particularly on long tours.
Proven Suspension and high-performance brakes with Integral ABS
Like its predecessor, the new R 1200 GS Adventure offers an improved synthesis of offroad and onroad riding qualities. As in the past, the stiff and torsionally-resistant suspension, front wheel control with the unique BMW Telelever, and the rear wheel incorporating the BMW Paralever provide first class riding qualities in combination with the new engine offering even more power and torque.
In conjunction with optional BMW Motorrad Integral ABS, extremely powerful brakes provide maximum safety even in critical situations. Optimum environmental compatibility is achieved on the new boxer engine through the most advanced exhaust gas management with a fully controlled three-way catalytic converter.
Enduro ESA - Optional for optimum electronic adjustment of the suspension for every purpose
Designed and built for the specific requirements of a grand touring enduro, Enduro Electronic Suspension Adjustment (ESA) is available on the latest version of the R 1200 GS Adventure as an option straight from the factory. Enduro ESA allows adjustment of the suspension under all kinds of running conditions and with virtually any load level, simply by pressing a button. An important feature of the Enduro ESA is that it offers both an onroad and offroad mode within which the rider, choosing specific settings for the spring base and damping, is able to adjust the suspension even more precisely to specific needs and requirements.
As usual, Enduro ESA meets the particular requirements of a grand touring enduro by additional electrohydraulic adjustment of the spring base on the front spring strut. When riding offroad, this ensures a far smoother ride without the disadvantages otherwise experienced onroad, such as shorter negative spring travel or greater seat height.
Optimum ergonomics and even more practical features
The high-quality, sophisticated handlebar, constructed from a heat-treated aluminum tube, mounted with two asymmetrical clamps, facilitates turning by up to 180 degrees (as on the HP2 Enduro Sport) and may be adjusted in two ergonomically different positions. While the rear handlebar position for riding onroad and in less demanding terrain ensures optimum ergonomics particularly for the shorter rider, the front handlebar position offers advantages when standing up on the machine in rough terrain.
The hand protectors available as accessories for the R 1200 GS are fitted as standard equipment straight from the factory on the R 1200 GS Adventure. In the process of technically upgrading the successful R 1200 GS models, the instrument cluster has received a new designed dial. And last but not least, the windshield now comes with larger hand-bolts with even better grip for adjusting its position with greater ease.
Options and accessories tailored to both the rider and the machine
As a genuine, fully-fledged systems supplier, BMW Motorrad has developed a wide range of options and accessories for further customization of the new R 1200 GS Adventure. One particularly important new feature is the additional headlight in LED technology.
Options come directly from the factory and are installed during production at the Berlin Plant. Accessories and special equipment are installed by Authorized BMW Motorcycle Dealers.
Optional Extras
* Enduro ESA
* BMW Motorrad Integral ABS (semi-integral, on-demand)
* RDC
* ASC
* Exhaust system chrome-plated
* Heated HandGrips
* Hand protectors (Adventure: standard)
* Cross-spoke wheels (Adventure: standard)
* On-board computer with oil level warning
* Anti-theft warning system with remote control
* LED direction indicators
* Offroad tires
* Enduro transmission (short first gear)
* Additional halogen headlight
* Power reduced to 98 hp
* 91 RON
Special Equipment
Cases:
* Aluminum case
* Case mounting brackets for Aluminum case*
* Aluminum Topcase
* Topcase mounting bracket
* Inner bags for Aluminum case/Topcase
* Back padding Aluminum Topcase
* Watertight tank bag
* Softbag 2, large, 13.5 gallons
* Softbag 2, small, 5 gallons
Styling and Design
* Cylinder head covers chrome-plated
* Front fender, in carbon
* Splashguard rear, in carbon
* HP Carbon cover for engine housing
* Headlight protector (for offroad use only)
* Cap for Telelever and fork bridge
* Additional LED headlight
* Holder for additional headlight
* LED direction indicators.*
Sound
* Akrapovic sports muffler
Ergonomics and Comfort
* Windshield, tinted
* Wide enduro footrests -- standard
* Adjustable footbrake lever -- standard
* Handlebar cross reinforcement
* Padding for handlebar cross reinforcement
* Rider’s seat, low (32.3") in Black*
* Rider’s seat, Grey
* Additional power socket
* Heated HandGrips*
Navigation and Communication
* BMW Motorrad Navigator IV
* Mount for BMW Motorrad Navigator
* Navigator function bag
Safety
* Hand protectors -- standard*
* Spoiler guards, large, for hand protectors
* Aluminum cylinder head cover protection -- standard
* Plastic cylinder head cover protection
* Enduro skid plate protection, aluminum
* Frame guard
* Safety bolts for oil filler manifold
* Anti-theft warning system with remote control*
Maintenance and Technical Equipment
* Reduction in power to 98 hp*
* Paddock stand
* On-board toolkit/service kit
* LED light for on-board power socket, 16.1"
*Also available as an option from the factory.
New surface and color design
The 2010 R 1200 GS Adventure demonstrates its enhanced dynamics through new surface design and colors. Smoke Grey metallic emphasizes the almost rustic, masculine character of the machine, while Brilliant Yellow metallic accentuates its sporting offroad qualities. Particularly the second color variant forms an exciting contrast to the seat finished in Black Olive Grey. The new throttle butterfly manifolds come in Black.
2010 BMW R 1200 GS Specifications
Engine
Capacity 1,170 cc
Bore/stroke 3.98/2.87 inches
Max output 110 hp at 7,750 rpm
Max torque 88 ft-lb @ 6,000 rpm
Configuration Flat-twin
No. of cylinders 2
Compression ratio/fuel grade 12/S 95-98 RON, max output with 98 RON, optional 91 RON SA
Valve/gas timing DOHC
Valves per cylinder 4
Intake/exhaust valve diameter 1.54/1.30 inches
Throttle butterfly diameter 1.97 inches
Fuel supply BMS-K+
Exhaust management Fully-controlled three-way catalytic converter
Electrical System
Alternator (W) 720 W
Battery (V/Ah) 12/14, maintenance-free
Headlight (W) H7
Starter (kW) 1.1
Transmission/Gearbox
Clutch Single-plate dry clutch, diameter 7 inches
Transmission Dog-type six-speed gearshift
Primary ratio 1.737
Gear ratios I 2.375; optional 2.600
II 1.696
III 1.296
IV 1.065
V 0.939
VI 0.848
Rear-wheel drive Drive shaft
Final drive ratio 2.91
Suspension
Frame Tubular steel frame, load-bearing engine
Front wheel guidance BMW Telelever
Rear wheel guidance BMW Paralever
Overall spring travel, front/rear 8.0/8.7 inches
Castor 3.0 inches
Wheelbase 59.4 inches
Steering head angle 65.2 degrees
Brakes
Front Dual disc brake, diameter 12 inches
Rear Single disc brake, diameter 10 inches
Optional BMW Motorrad Integral ABS
Wheels
Cast Cross-spoke
Front 2.5 x 19
Rear 4.0 x 17
Tires
Front 110/80 R 19
Rear 150/70 R 17
Dimensions and Weight
Length 88.2 inches
Width (overall, with mirrors) 39 inches
Handlebar width (without mirrors) 37.4 inches
Seat height 35.8/35 inches
Dry weight 492 lbs
DIN (unladen weight in road trim) 564 lbs
Max permissible 1,047 lbs
Tank capacity 8.7 gallons
Performance Data
Acceleration 0–62 mph 3.95 sec
Top speed 124 +
- Years Riding: 32
2023 Motorcycle Model Guides
