Page 1 of 2
600 mile service necessary?
Posted: Thu Apr 26, 2007 5:53 am
by tortus
Hey all,
I've owned my bike now about 10 days, put just over 600 miles on it now. My manual says at this point I need to replace the oil, oil filter and get the valves adjusted. Ok.
I went to my dealer to schedule the service. I'm clearly a newb, and after I tell the guy what my bike is (yamaha v star classic 650), he pulls down a suzuki manual and thumbs through it looking for what I need to have done at 600 miles -- a valve adjustment. He says all in all it'll be about $180 for the work. The whole exchange felt fishy to me.
If this is really the right thing to do, then sure, I'll do it. I don't want to jeopardize my bike.
But is $180 for what I'm assuming is just a valve adjustment about right? He never mentioned anything about an oil change, just the valves. I plan to change the oil myself anyway.
And don't most dealers offer this 600 mile service for free? Just about everyone I've spoken to who has bought a bike has said this should be free.
Posted: Thu Apr 26, 2007 6:42 am
by Scoutmedic
Yes, you really should have the 600 mile service done. As for the dealer, that is very high in my opinion. I honestly can't remember what mine cost but, I know it wasn't more than $50. They changed the engine oil and checked the valves, other fluids, bolts, tire pressure, etc. Basically, gave the bike a good once over to make sure everything was working correctly.
Posted: Thu Apr 26, 2007 6:54 am
by storysunfolding
Scoutmedic wrote:Yes, you really should have the 600 mile service done. As for the dealer, that is very high in my opinion. I honestly can't remember what mine cost but, I know it wasn't more than $50. They changed the engine oil and checked the valves, other fluids, bolts, tire pressure, etc. Basically, gave the bike a good once over to make sure everything was working correctly.
This is what it should cost. My dealer wanted $600 unless I bought the first 5 services in advance... then $400
Posted: Thu Apr 26, 2007 9:43 am
by Phat_J
180.00 sounds reasonable for the first service. I have a Yamaha too so I know the pains of having to do the valve adjustment. Usually they package the adjustment and oil/filter change together with that first service, but make sure. I would definitely change at least the oil/filter and transaxle fluid if your bike is a shaft drive.
Posted: Thu Apr 26, 2007 11:46 am
by blues2cruise
When the bike is new and just getting broken in, the oil will have metal flakes in it. It is important to have that oil drained out (hot) so that the crud comes out with it. You don't want that staying in your engine.
Not all dealers offer it for free. And yes, the first service is expensive.
Posted: Thu Apr 26, 2007 12:29 pm
by storysunfolding
blues2cruise wrote:When the bike is new and just getting broken in, the oil will have metal flakes in it. It is important to have that oil drained out (hot) so that the crud comes out with it. You don't want that staying in your engine.
My first service only called for an oil and filter change along with making sure all the bolts were still tight. No valve checks or anything. $400.
I did it on my own, checked my valves (perfectly in the middle of tolerances btw), changed my oil and filter (did this first at 50 miles), made sure all my bolts were torqued correctly and added loctite to some pesky ones known to come loose... and then added stuff. If you are mechanically inclined or have a garage a six pack and know someone who's mechanically inclined- you can save alot of money.
Posted: Thu Apr 26, 2007 12:41 pm
by blues2cruise
storysunfolding wrote:blues2cruise wrote:When the bike is new and just getting broken in, the oil will have metal flakes in it. It is important to have that oil drained out (hot) so that the crud comes out with it. You don't want that staying in your engine.
I just looked in my manual. The first service on the V-Star included
Valves
Carbuerators
Clutch
Brakes...check and adjust both front and back
Steering bearings
Oil and filter and element
Fnal Gear oil - change
control cables - lube
Perhaps Honda's valves are self adjusting which is why yours didn't need to be done.
It cost me $282.00 CDN
$400. US sure does seem like a lot. Surely it must cover more than an oil and filter?
Posted: Thu Apr 26, 2007 1:09 pm
by Social Distortion
i have an 06 classic and i changed my own oil and final gear oil also.
I am in the proicess of tightening most of my bolts and will wait for my valves to be adjusted.
I think you may also want to search the intern for a "C, C& D" forum that V STar owners chat about taking care of your bike.
they'l help you w/ everything related to youe V Star.
Also, sooner rather than later, you'll want to make a Carb. Synch tool ( About $6) and make sure your carbs are synched.
Posted: Thu Apr 26, 2007 2:58 pm
by Sicko
One thing I learned when I had the 600 mile service done on my late Shadow was the dealer service dept was totally unprofessional and that I'd be a fool to ever let them touch my bike again. I can't complain about the price ($135.00) but the hillbilly mechanic asking his buddy "Hey Earl, what should I charge for adjustin' the valves?" Didn't exactly instill confidence in me. From then on, I did all the routine maintenance myself and vowed that if I ever had to take her to a dealer, it would not be the dealer I bought her from.
Posted: Fri Apr 27, 2007 1:46 pm
by tortus
Thanks for all the help guys. Looks like I'll take it in on Tuesday for the service.
I'm hoping to learn most maintenance my own, so I won't have to bother with dealer's prices one of these days
