79 cx 500
balldy18
Real Name: john
Years Riding: 1
My Motorcycle: 1979 cx 500 deluxe
79 cx 500
#1 Unread post by balldy18 »
I have Honda 70 cx 500 ..I hosed it off it was pretty dirty, it was running before I decided to hose it and now it won't start. I put new solenoid, the starter works I tested it...changed the plugs, the 20amp fuse is good. this cdi stuff is new to me. I am going to try neutral safety next, maybe coils, maybe a switch?
GS_in_CO
Real Name: Ron
Re: 79 cx 500
#2 Unread post by GS_in_CO »
balldy18 wrote:I have Honda 70 cx 500 ..I hosed it off it was pretty dirty, it was running before I decided to hose it and now it won't start. I put new solenoid, the starter works I tested it...changed the plugs, the 20amp fuse is good. this cdi stuff is new to me. I am going to try neutral safety next, maybe coils, maybe a switch?
Does the starter roll it over briskly?
Do you have spark?
Every part you named is a maybe until you actually diagnose what's wrong.
Ron
Past: 1987 Yamaha XT350
1983 Honda CB900F
1980 Honda XL185S
1979 Suzuki GS425E
balldy18
Real Name: john
Years Riding: 1
Re: 79 cx 500
#3 Unread post by balldy18 »
hey took your advice no spark... new coil? repair manual says they never fail
GS_in_CO
Real Name: Ron
Re: 79 cx 500
#4 Unread post by GS_in_CO »
No spark both cylinders?
What can cause no spark? Well - plug wire, coil open, coil connector, power (ignition box)to coil, kill switch, etc.
Helps if you have a wiring diagram. But just unseating and reseating connectors can often "fix" issues.
Ron
1983 Honda CB900F
1980 Honda XL185S
1979 Suzuki GS425E
balldy18
Real Name: john
Years Riding: 1
Re: 79 cx 500
#5 Unread post by balldy18 »
I have the diagram .... starter disconnect switch, it says it is near the horn?
GS_in_CO
Real Name: Ron
Re: 79 cx 500
#6 Unread post by GS_in_CO »
balldy18 wrote:I have the diagram .... starter disconnect switch, it says it is near the horn?
An electrical diagram showing part proximity doesn't mean that the physical parts are next to each other. But if there's other text indicating so then - they are.
Is the kill switch on the same side as the horn button?
Ron
1983 Honda CB900F
1980 Honda XL185S
1979 Suzuki GS425E
riya20
Real Name: riya
My Motorcycle: bmw
Re: 79 cx 500
#7 Unread post by riya20 »
