carbs
cuz
Real Name: willie w
Years Riding: 1
My Motorcycle: kawasaki vulcan 900
carbs
#1 Unread post by cuz »
the front carb on my v-star 650 is running lean how do i adjust it
Hanson
Real Name: Richard Hanson
Years Riding: 3
Re: carbs
#2 Unread post by Hanson »
I don't have an answer to your question, but I would like to welcome you to Total Motorcycle. Check back in a day or two and someone will likely have some good tips to help you.
Re: carbs
#3 Unread post by Johnj »
Hello Willie and welcome to the forum. You most likely need to clean your carbs. Instructions are in your service manual.
cuz
Real Name: willie w
Years Riding: 1
Re: carbs
#4 Unread post by cuz »
Carbs already cleaned
Re: carbs
#5 Unread post by Johnj »
May I ask what makes you think that the front cylinder is running lean.
Does your bike have one carb or two?
Have you modified your exhaust?
BRUMBEAR
Real Name: Dave
Years Riding: 40
Re: carbs
#6 Unread post by BRUMBEAR »
+1 to John also if its a plug issue that makes you think your running lean on 1 cyl like its whiter and caked before you go crazy, check for air leaks as they are the main culprit for running extremely lean.
if you have a cv check your diaphram but a single carb v twin it's usually an air leak or valve adjustment issue or both
Hope this helps
there aint nothin like it
BRUMBEAR
Real Name: Dave
Years Riding: 40
Re: carbs
#7 Unread post by BRUMBEAR »
cuz
Real Name: willie w
Years Riding: 1
Re: carbs
#8 Unread post by cuz »
Johnj wrote:May I ask what makes you think that the front cylinder is running lean.
Thanks for your input, I'm not that handy with motors. But this
Is what makes me think it is runing lean. I front cylinder won't
Run until I pull the back spark plug open the choke and turn
The throttle about a 1/4 turn. And then it spuders a lot
cuz
Real Name: willie w
Years Riding: 1
Re: carbs
#9 Unread post by cuz »
BRUMBEAR wrote:+1 to John also if its a plug issue that makes you think your running lean on 1 cyl like its whiter and caked before you go crazy, check for air leaks as they are the main culprit for running extremely lean.
Hope this helps
Thanks for the vido, how's the best way to check for air leaks
cuz
Real Name: willie w
Years Riding: 1
Re: carbs
#10 Unread post by cuz »
This is an 03 with 5600 mile on it
