hyosung gt250p fuel level gauge problem
Ling_Ling
Real Name: Viktor
My Motorcycle: 2012 hyosung gt250p
#1 Unread post by Ling_Ling »
Not showing correct fuel tank level. when fuel tank is empty it shows half full. even with disconnected sending unit - still half. is there any solution for this problem?
BRUMBEAR
Real Name: Dave
Years Riding: 40
Re: hyosung gt250p fuel level gauge problem
#2 Unread post by BRUMBEAR »
new stuff :D
there aint nothin like it
pchast
#3 Unread post by pchast »
Victor,
First...
I've never had a Motorcycle that read correctly,
but the meter should move.
Can you take it back to the dealer?????
Do you have a voltmeter?
Do you have a maintenance manual for the bike?
Trace the wiring from the tank to the gauge.
Inspect it for shorts or grounds.
Check all the connections and clean them.
Then use the millage per tank to fill it
before it is empty.
Thats what I do...
