Oil filler plug question
NorthernPete
Years Riding: 11
#1 Unread post by NorthernPete »
Hey everyone! Got a question. My oil filler plug is plastic. It's got two little tabs on the top to grab to unscrew. One is broken off. While I can still take it off it looks like poop. I'm wondering if I go to a machine shop and get an aluminum plug made up to the same diameter and thread would this be an alright replacement? Would the material cause an issue? I'd use a rubber o ring in the build to ensure a good deal and there no dipstick involved.
Would aluminum work or end up a seized mess at some point?
2009 GS500F
GS_in_CO
Real Name: Ron
Re: Oil filler plug question
#2 Unread post by GS_in_CO »
You might look into the cost of the replacement part - if it's cheap it would be less hassle.
No reason aluminum would be a problem. Especially as that's an oil fill hole so there's lots of oil mist to keep corrosion minimized.
But getting the part custom -made could be pricey.
Ron
Past: 1987 Yamaha XT350
1983 Honda CB900F
1980 Honda XL185S
1979 Suzuki GS425E
pchast
#3 Unread post by pchast »
What material is the case itself that is threaded into?
NorthernPete
Years Riding: 11
#4 Unread post by NorthernPete »
Aluminum engine case I believe at that spot. As for the custom part, there's a machine shop in the area and I have a buddy who can get me fairly good deal. I'll check it all out though. :)
2009 GS500F
