Clutch lever has no slack
Blanket
Years Riding: 3
My Motorcycle: 2011 Yamaha FZ8
Unread post by Blanket » Thu Feb 02, 2017 4:25 am
Not sure how this happened or what to do with it. The bike is a 2011 Yamaha FZ8 with about 12k miles on it. Rode it today fine, came home, clutch was acting funny in that it was feeling a bit sticky, not releasing fully. I messed around with the cable adjustment a bit, then eventually there was no slack on the clutch whatsoever. What did I do? :oops:
https://www.youtube.com/watch?v=fE7Qbt- ... e=youtu.be
Re: Clutch lever has no slack
Unread post by totalmotorcycle » Thu Feb 02, 2017 9:42 am
Might be that the cable is broken in the middle somewhere. Can you see it move the clutch in and out on the engine? (other end of the cable)?
2017 Motorcycle Model Guides
2016 Motorcycle Model Guides
Blanket
Years Riding: 3
Unread post by Blanket » Thu Feb 02, 2017 8:08 pm
Image Looks like you're right. After further investigation this just came right out. This is the clutch cable right? Is it expensive to fix, about how much, easy to do myself, or mechanic suggested?
NorthernPete
Years Riding: 11
My Motorcycle: 1982 Yamaha sr250
Unread post by NorthernPete » Thu Feb 16, 2017 11:57 pm
Replacing cables isn't too hard. YouTube is your friend as long as you get the right part. :)
1982 sr250
Users browsing this forum: No registered users and 146 guests
cron
