Mounting GPS/Cell in a Sportbike Cocpit
JackoftheGreen
Real Name: Eric
#1 Unread post by JackoftheGreen »
So I'm stumped. Here's the cockpit of one of our Ninjas:
What type of whiz-band or boondoggle does one use to secure a cell phone or dedicated GPS device somewhere in that nice? Or am I barking up the wrong tree? Better to use a magnetic tank bag with a clear "map pocket" for my device?
skbiker
My Motorcycle: ZX-6R 636
Re: Mounting GPS/Cell in a Sportbike Cocpit
#2 Unread post by skbiker »
Hello! Which model of Ninja is it? If I'am right there is plastic cover on triple tree screw that you can take off and then install THIS. For me it is the simplest way to install phone/gps holder on a bike. Also it is easier to take a quick look if you put it there instead of on a tank and you do not need to take it off when you have to refill gas.
JackoftheGreen
Real Name: Eric
#3 Unread post by JackoftheGreen »
SK, it's a 2008 EX500R. Your recommendation is exactly what I was looking for, and I've added one to my Amazon wish list already. Thanks for the tip! Do you have any pics of your install? I'm curious how much clearance it leaves for the ignition key.
skbiker
#4 Unread post by skbiker »
Great! Unfortunately I don't have pictures because I was doing the same thing with tank bag and map pocket. Recently I found this solution and hope so to install it this year. But from pictures on ebay it looks like the phone/gps is much higher then the key so there shouldn't be a problem.
JackoftheGreen
Real Name: Eric
#5 Unread post by JackoftheGreen »
Ahhhh, gotcha.
If you haven't purchased it yet, look on Amazon for less expensive iterations of this method. Just search "fork mount gps".
Lion_Lady
Real Name: Pam
Years Riding: 20
#6 Unread post by Lion_Lady »
Another option for mounting gadgets to a motorcycle is a RAM mount. http://www.rammount.com/ use "motorcycle" to get to moto-specific mounts and gadget holders. I like that you can get a whole gadget rig, or go "a la carte." I've been using the X-clamp for my Galaxy S5 for two years. Before that, I also have a 10+ year old GPS that I still use in its original RAM mount.
RAM has a fork stem mount set up.
P
