Total Motorcycle Forums • View topic - Rider Tips: Motorcycle Cleaning Tips
Unread postPosted: Tue May 29, 2007 4:57 pm
Years Riding: 20
Frequent cleaning of your machine will enhance its appearance, maintain better overall performance, and extend the life of many components.
Before washing the machine, block off the end of the exhaust pipe to prevent water from entering. A plastic bag secured with a rubber band may be used for this purpose.
If the engine is excessively greasy, apply some degreaser to it with a paintbrush. Do not apply degreaser to the chain, sprockets, or wheel axles.
Rinse the dirt and degreaser off with a garden hose; only use enough pressure to do the job.*
After the majority of the dirt and degreaser have been hosed off, wash all surfaces with warm water and a mild detergent. Use an old toothbrush to clean hard-to-reach places.
Rinse the machine off immediately with clean water, and dry all surfaces with a soft towel or cloth.
Immediately after washing, remove excess water from the chain with a paper towel and lubricate the chain to prevent rust.
Clean the seat with vinyl upholstery cleaner to keep the cover pliable and glossy.
Automotive wax may be applied to all painted or chromed surfaces. Avoid combination cleaner-waxes, as they may contain abrasives.
After completing the above, start the engine and allow it to idle for several minutes.
*Note: Excessive hose pressure may cause water seepage and contamination of wheel bearings, front forks, brakes and transmission seals. Many expensive repair bills have resulted from improper high-pressure detergent applications such as those available in coin-operated car wash facilities.
2013 Motorcycle Model Guides
2012 Motorcycle Model Guides
2013 ATV/Quad Model Guides
Unread postPosted: Tue May 29, 2007 5:03 pm
Years Riding: 20
Please feel free to add your opinion and discuss the tip article above from Bow Cycle Calgary.
Users browsing this forum: High_Side and 20 guests
