2009 Honda Rebel 250 - COOL WALL VOTE: COOL
Posted: Thu May 26, 2011 9:52 pm
http://www.totalmotorcycle.com/photos/2 ... bel250.htm
2009 Honda CMX250C Rebel 250
Who says you need a big-bore machine to appreciate the joys of motorcycling? Not a Honda CMX250C Rebel rider, that's for sure. A user-friendly combination of light weight and comfortable size has made the CMX250C Rebel an enduring favourite among riders looking for an easy-to-handle cruiser. The good stuff begins with a high-output twin-cylinder engine that runs more smoothly than a single, yet is thrifty on gas and easy to maintain. A front disc brake brings you to a halt quickly, and that's when you'll notice how easy it is to put your feet flat on the ground, thanks to a low seat height.
This is a bike that instills confidence on every ride.
Rebel riders agree, this bike makes you look good no matter how long you've been riding. It's an entry-level bike, sure, but it boasts big-bike styling with its timeless cruiser looks and nifty chrome highlights. Its reliable 234cc four-stroke twin delivers smooth power, and its five-speed transmission is a no-brainer to shift. Why pay more for a lesser bike? The Rebel's sticker price is as unbelievable as its outstanding fuel economy—proof positive it's a Honda.
Features & Benefits
Engine/Drivetrain
- Proven twin-cylinder 234 cc SOHC four-stroke engine is smooth, quiet, economical and easy to maintain.
- Convenient and reliable electric starter.
- Screw-type valve adjusters simplify maintenance.
- Constant-velocity carburetor gives excellent throttle response.
- Easy-shifting five-speed transmission.
- Automatic cam-chain tensioner.
- Radically styled twin-muffler exhaust system.
Chassis/Suspension
- Semi-double-cradle frame allows a long wheelbase and extremely low seat height.
- Hydraulic front fork with dual Syntallic bushings.
- Dual rear shocks feature five-position spring preload adjustment.
- Rectangular-section swingarm.
- Front disc brake with twin-piston caliper.
- Wide 130/90-15 rear tire.
- Spoke wheels with chrome rims.
- O-ring-sealed chain for increased durability.
- Pullback handlebar.
- 9.8-litre teardrop fuel tank.
- Two-piece custom-styled seat.
Additional Features
- Custom-styled chrome-plated headlight case.
- Stylish chrome-plated taillight housing.
- Simple, straightforward instrumentation.
- Chrome-plated turn-signal housings.
- Maintenance-free battery.
- Push-to-cancel turn-signal switch.
- Key-operated steering lock for added security.
- Easy-to-use helmet lock.
- 1 year, unlimited mileage, freely transferable warranty.
2009 Honda CMX250C Rebel 250 - Specifications
MSRP: $3,399 USD / $5,299 CDN
ENGINE
Engine Type 234cc air-cooled parallel twin-cylinder
Bore and Stroke 53.0mm x 53.0mm
Induction Single 26mm diaphragm-type constant-velocity (CV) carburetor
Ignition CD
Compression Ratio 9.2:1
Valve Train SOHC; two valves per cylinder
DRIVE TRAIN
Transmission Five-speed
Final Drive O-ring sealed chain
CHASSIS / SUSPENSION / BRAKES
Front Suspension 33mm fork; 4.6-inch travel
Rear Suspension Dual shocks with five-position spring-preload adjustability; 2.9-inch travel
Front Brake Single-disc with twin-piston caliper
Rear Brake Drum
Front Tire 3.00-18
Rear Tire 130/90-15
DIMENSIONS
Rake 30-degree 40'
Trail 113mm (4.4 inches)
Wheelbase 57.1 inches
Seat Height 26.6 inches
Curb Weight 331 lbs (Includes all standard equipment, required fluids and a full tank of fuel-ready to ride)
Fuel Capacity 2.6 gallons, including 0.7-gallon reserve
OTHER
Available Colors Black, Ultra Blue Metallic
Model ID CMX250C
Emissions Meets Current EPA standards. California version differs slightly due to emissions equipment.
Note The perfect entry-level street bike
