2011 Triumph Daytona 675 SE - VOTED: AWESOME
Posted: Thu Oct 20, 2011 9:28 pm
http://www.totalmotorcycle.com/photos/2 ... a675SE.htm
The best supersport bike in the world or a class of its own? Designed for the racetrack, to compete with the best in the supersport class, Triumph’s Daytona 675 is the bike to beat on both road and track.
Winner of the 2009 Supertest ‘King of Supersports’ award (for the fourth time, no less) and MCN’s Sportsbike of the Year, the Daytona 675 delivers a killer blow with its combination of outstanding handling and a storming three-cylinder engine.
With the lightest and narrowest chassis in the class, the Daytona 675 delivers outstandingly agile and intuitive handling. Fully adjustable suspension front and rear, with separate adjustment for high and low speed compression damping, gives the Daytona 675 superb composure on all surfaces, while top-of-the-range monobloc radial brake calipers up front deliver eye popping stopping power.
But it is the engine that makes the Daytona 675 stand apart from the competition. With 126ps and more torque than the competition, the 675cc triple offers an exhilarating ride for novice and experienced riders alike. With its unique and wicked three-cylinder howl, the Daytona 675 delivers an unadulterated experience like no other sportsbike.
Updates for 2011 include new instruments, decals and a new Dayona 675SE option.
Triumph is offering customers across North America the opportunity to own a truly unique factory sport bike with the Daytona 675 Special Edition. The limited edition model takes the award-winning Daytona 675 and covers its body panels, tank and fenders in a stunning new Pearl White while the frame, swing arm and subframe receive a distinctive Sparkle Blue paint. -
Introducing the Triumph Daytona 675 SE, a stunning special edition of the award winning supersport machine that really stands out from the crowd.
"The Daytona 675 has received exceptional reviews for its performance and styling," said Jim Callahan, North American Marketing Manager for Triumph Motorcycles. "Now, Triumph has taken the bike's styling a step further with this incredible new color scheme. You absolutely have to see the Daytona 675 Special Edition in person to appreciate the way sunlight makes this bike shine."
The Daytona 675 SE is mechanically identical to the standard 2009 Daytona 675, which has received praises worldwide by winning several road and track-based tests against its competitors.
The race-bred machine utilizes a 126bhp three-cylinder engine and the very latest chassis technology, including a highly sophisticated and adjustable front and rear suspension. Riders can adjust both high and low speed compression damping to obtain unparalleled levels of control that are suited to both spirited street and track riding as well as compliance for rough road surfaces. New radial-mount Nissin monobloc front brakes give tremendous stopping power while the latest Pirelli SuperCorsa SP tires give outstanding levels of grip and feedback.
A full range of genuine accessories and factory race parts also are available for the Daytona 675 SE, giving owners an opportunity to personalize both the looks and performance of their machine. Track day enthusiasts will find a number of accessories that include lightweight carbon fiber parts and a 'plug-and-play' quickshifter as well as race-style rear set footrests and a racing inspired exhaust that were developed with Italian racing specialist Arrow Special Parts.
Similarly, Triumph's association with Alpinestars technical riding apparel has resulted in a range of performance jackets, pants, gloves and boots that are designed for male and female Daytona 675 riders.
2011 Triumph Daytona 675 SE - USA Specifications
MSRP: $10,899 USD, MSRP: $12,399 CDN
Engine
Type
Liquid-cooled, 12 valve, DOHC, in-line 3-cylinder
Capacity
675cc
Bore/Stroke
74 x 52.3 mm
Compression Ratio
12.65:1
Fuel System
Multipoint sequential electronic fuel injection with forced air induction and SAI
Transmission
Final Drive
O ring chain
Clutch
Wet, multi-plate
Gearbox
6-speed, close ratio
Cycle Parts
Frame
Aluminum beam twin spar
Swingarm
Braced, twin-sided, aluminum alloy with adjustable pivot position
Front Wheel
Cast aluminum alloy 5-spoke, 17 x 3.5in
Rear Wheel
Cast aluminum alloy 5-spoke, 17 x 5.5in
Front Tyre
120/70 ZR 17
Rear Tyre
180/55 ZR 17
Front Suspension
Kayaba 41mm upside down forks with adjustable preload, rebound and high/low speed compression damping, 110mm wheel travel
Rear Suspension
Kayaba monoshock with piggy back reservoir adjustable for preload, rebound and high/low speed compression damping, 130mm rear wheel travel
Front Brakes
Twin 308mm floating discs, Nissin 4-piston radial mono-block calipers
Rear Brakes
Single 220mm disc, Nissin single piston caliper
Dimensions
Length
79.5 in
Width (Handlebars)
27.9 in
Height
43.5 in
Seat Height
32.7 in
Wheelbase
55.7 in
Rake/Trail
23.9 degree / 89.1 mm
Wet Weight
407 lbs
Fuel Tank Capacity
4.6 US gals
Performance (measured at crankshaft to 95/1/EC)
Maximum Power EC
124bhp @ 12600 rpm
Maximum Torque EC
53 ft.lbs @ 11700 rpm
Colours
Phantom Black, Tornado Red, Caspian Blue
2011 Special Edition - Pearl White with Sparkle Blue Frame
Price
$10,499/ 2011 SE - $10,899
Engine
Type
Capacity
675cc
Bore/Stroke
74 x 52.3 mm
Compression Ratio
12.65:1
Fuel System
Transmission
Final Drive
O ring chain
Clutch
Wet, multi-plate
Gearbox
Cycle Parts
Frame
Swingarm
Front Wheel
Rear Wheel
Front Tyre
120/70 ZR 17
Rear Tyre
180/55 ZR 17
Front Suspension
Rear Suspension
Front Brakes
Rear Brakes
Dimensions
Length
79.5 in
Width (Handlebars)
27.9 in
Height
43.5 in
Seat Height
32.7 in
Wheelbase
55.7 in
Rake/Trail
Wet Weight
407 lbs
Fuel Tank Capacity
4.6 US gals
Maximum Power EC
124bhp @ 12600 rpm
Maximum Torque EC
Colours
Price
