2013 Victory Judge - VOTED: Awesome
Your Coolness Factor of the 2013 Victory Judge is...
View results
Unread post by totalmotorcycle » Fri Jan 20, 2012 5:05 am
2013 Victory Judge
http://www.totalmotorcycle.com/motorcyc ... -Judge.htm
2013 Victory Judge
American muscle never died. It just needed handlebars.
Available in dealerships April 2012
2013 Victory Judge Model Highlights
•106 cubic-inch Freedom V-Twin Engine
•113 ft lbs torque
•Mid mounted controls
2013 Victory Judge Features and Benefits
A NEW CRUISER EXPERIENCE
Victory reinvented the cruiser riding experience with the premium ride and performance of the Vegas. Now Victory again introduces a high new level of cruiser excitement with the stylish, sport-influenced Victory Judge.
MID MOUNTED CONTROLS
The mid mounted controls put the driver in an active, engaged riding position. The rider is confidently in total command of the bike, and the ergonomics ensure long-riding leg comfort for riders on the open road.
ALL-NEW VICTORY STYLING
Only Victory offers such distinctive cruiser styling. The Victory Judge is a powerful rolling sculpture showcasing fresh bodywork, blacked-out features, new drag handlebars, a new headlight nacelle and side panels an owner can customize. The Victory ignition cover between the cylinders also features a great new look.
AMERICAN CRUISER STYLE
The Victory Judge combines modern high-performance technology with American styling cues of the 1960s muscle car era, such as cast 5-spoke wheels. The 16" wheels are shod with premium Dunlop Elite II tires with raised white lettering, the perfect look on this cruiser.
CONFIDENCE-INSPIRING RIDE & HANDLING
Beautifully balanced and engineered with a low center of gravity, the Victory Judge is a full-sized cruiser with sporty & performance-oriented handling that instills confidence and delivers an incredibly smooth ride.
106 CUBIC-INCH FREEDOM V-TWIN
The pulse of the street beats from within the powerful Freedom® 106/6 V-Twin. Its serves up 113 ft-lbs of torque that lets a rider accelerate through the gnarliest traffic and bask in the freedom of the open road.
6-SPEED OVERDRIVE TRANSMISSION
Helical-cut gears in the durable, reliable 6-speed transmission deliver consistently smooth shifting. The true overdrive of 6th gear provides a rider with the smoothest highway cruising.
113 FT-LBS OF TORQUE
The Freedom® 106/6 V-Twin delivers instant throttle response and outstanding acceleration that gets a rider off the line and through traffic in complete control. Even while cruising in 6th gear, there's passing power to spare
2013 Victory Judge - USA Specifications/Technical Details
USA MSRP Price: $13,999 USD
Canada MSRP Price: $15,299 CDN
Engine
Battery 12 volts / 18 amp hours
Bore x Stroke 101 x 108 mm
Charging System 38 amps max output
Clutch Wet, multi-plate
Compression Ratio 9.4 : 1
Cooling System Air / oil
Displacement 106 ci / 1731 cc
Engine Type 4-stroke 50° V-Twin
Exhaust Staggered slash-cut dual exhaust with crossover
Final Drive Carbon Fiber Reinforced Belt
Fuel Capacity 4.5 gal / 17.0 ltr
Oil Capacity 5.0 qts / 4.75 ltr
Primary Drive Gear drive with torque compensator
Transmission 6-speed overdrive constant mesh
Valve Train Single overhead camshafts with 4 valves per cylinder, self-adjusting cam chains, hydraulic lifters
Chassis
Dry Weight 660 lbs / 300 kg
Ground Clearance 4.7 in / 120 mm
GVWR 1151 lbs / 522 kg
Length 92.0 in / 2337 mm
Rake/Trail 31.7o / 6.7 in / 170 mm
Seat Height 25.9 in / 658 mm
Wheelbase 64.8 in / 1647 mm
Suspension
Front Suspension Conventional telescopic fork, 43 mm diameter, 5.1 in / 130 mm travel
Rear Suspension Single, mono-tube gas, cast aluminum with rising rate linkage, 3.0 in / 75 mm travel, preload adjustable spring
Brakes
Brake System Type Conventional
Front Braking System 300mm floating rotor with 4-piston caliper
Rear Braking System 300mm floating rotor with 2-piston caliper
Wheels & Tires
Front Tire 130/90 B16 67H Dunlop 491 Elite II-RWL
Front Wheel 16 x 3.5 in
Rear Tire 140/90 B16 77H Dunlop 491 Elite II-RWL
Rear Wheel 16 x 3.5 in
Color
Colors Gloss Black; Sunset Red; Suede Nuclear Sunset
2017 Motorcycle Model Guides
2016 Motorcycle Model Guides
Re: This Week: 2013 Victory Judge - VOTE NOW!
Unread post by totalmotorcycle » Fri Jan 20, 2012 1:01 pm
...and here we go, also the very first 2013 motorcycle model as well!
madjak30
Years Riding: 3
My Motorcycle: 2006 Yamaha MT-01
Unread post by madjak30 » Fri Jan 20, 2012 1:18 pm
Nice bike...but it isn't a big enough step away from existing models to warrant an awesome vote...
Voted: Cool
It's a Vegas with 16" front rubber and realistic sized rear...should be a nice ride, but I still like the Crossroads!!
Later.
Unread post by totalmotorcycle » Fri Jan 20, 2012 2:38 pm
I Voted: Awesome
Why? Because Victory needed a "Standard" bike, something with normal controls and a sport"ie" look to it. I really like the "60's muscle car look" of the rims (ya, baby!) and the idea of something other than cruiser (although, it is still a standard cruiser umm I guess). And the red, matte orange and black colors are awesome too.
Now, my wishes would have been:
- Should have been priced under $10k
- Should have used the old 2004 92 cubic inch Freedom V-twin or 2007 100 cubic inch engine to keep costs under $10k
- Should have been lighter (or smaller engined) to make it a "sportster" or attact new riders to the brand...
This is the 92 engine on this 2004:
HYPERR
Unread post by HYPERR » Fri Jan 20, 2012 7:00 pm
Victory not only stole the name from Pontiac but the paint as well. :laughing:
Years Riding: 41
Unread post by High_Side » Fri Jan 20, 2012 7:29 pm
I'm not sure about the looks, thinking that they should have went with 17" wheels to allow for better looks and sportier rubber choices. And I'm not sure if reviving an older, smaller engine would have been lighter or any cheaper. I'd love to take one for a ride and find out if it is any more agile than the average cruiser
ceemes
Real Name: a big secret
Unread post by ceemes » Fri Jan 20, 2012 7:36 pm
No vote from me.....neither cool or uncool, sort of falls in between the middle of those two options IMHO....just another muscle cruiser in an already saturated market.
[img]http://i38.tinypic.com/2j0gmzq.jpg[/img]
madjak30
Years Riding: 3
Unread post by madjak30 » Fri Jan 20, 2012 11:45 pm
Here's something to help...
Later.
Unread post by totalmotorcycle » Sat Jan 21, 2012 10:18 am
Good official Victory video, shows the bike size and colors as well as "suggested riding" style. The bke is a little bit bigger than I thought originally it was, which would explain the 667lb wet weight.
Unread post by dr_bar » Sat Jan 21, 2012 11:43 am
I voted fail, I didn't like the looks of the bike and thought small things like that oval side cover was just nasty to look at.
Unread post by totalmotorcycle » Sat Jan 21, 2012 1:59 pm
dr_bar wrote:I voted fail, I didn't like the looks of the bike and thought small things like that oval side cover was just nasty to look at.
I'm actually surprised to hear you didn't like the look of the Judge, I honestly thought it would be up your alley. The oval side cover is strange and yesterday I thought "humm, it should have a number on it"... and ta-da:
Here is Victory's "behide the scenes" development video on the Judge as well:
HYPERR
Unread post by HYPERR » Sat Jan 21, 2012 11:37 pm
"The Victory Judge combines modern high-performance technology with American styling cues of the 1960s muscle car era, such as cast 5-spoke wheels. The 16" wheels are shod with premium Dunlop Elite II tires with raised white lettering, the perfect look on this cruiser."
Muscle car ruled the road from the mid 60s to the early 70s, and the name they stole was introduced in the late 60s, but the those raised white lettered Dunlop Elites scream 1980s. :?
mogster
Real Name: MOG
Unread post by mogster » Sun Jan 22, 2012 9:53 pm
ceemes wrote:..just another muscle cruiser in an already saturated market.
OK so there are a lot of bikes similar to this in the market but I am pleased that Victory are IN the market!
Any bike that gives H-D something to think about is welcome as far as I am concerned :lol:
I think the colour is cool too & if copied from an old car so what.
I wouldn't be likely to purchase one or even ride it but I would be happy for it to park outside :D
My vote = Awesome
BTW Mike - can we please have prices listed in Sterling too? :?
:party:
Unread post by totalmotorcycle » Mon Jan 23, 2012 12:20 pm
I would be happy to, but Victory UK hasn't let us (press) know the pricing for it yet or have (just checked) put it up on the UK Victory page yet either. As soon as I have it, I'll list it for ya. :D
Unread post by sunshine229 » Mon Jan 23, 2012 2:35 pm
I voted cool as this is a pretty sweet bike.
However, since Victory made a huge ordeal of the announcement of this new bike I was expecting something different. Something cheaper, lighter, smaller; something to get people into their first Victory before moving up to their much bigger lineup of bikes. Maybe next time.
ZRex
Real Name: Ben
My Motorcycle: 2002 Kawasaki ZRX1200R
Unread post by ZRex » Tue Jan 24, 2012 7:36 pm
I love Muscle cars (my first car was a 1968 Ford Mustang GT fastback, I miss that car so much) and I love Motorcycles, so I have to vote Awesome.
ceemes
Unread post by ceemes » Wed Jan 25, 2012 9:01 pm
One can only hope that the only thing they kept from the Muscle Car era is the name, otherwise the bike will be hot off the line, blindingly quick down the straight and a hopeless wallowing pig in the corners and brakes made of tin foil. I grew up in the early to mid 70's era of muscle cars, great big honking V-8's, hooker headers, holley carbs and all that. Damn things could snap your neck in two off the line but for sheer terror, nothing beat trying to get them around a bend. Buddy of mine had Datsun 1600, and for fun we would race muscle cars through the Fraser Canyon, once we got into the twisties, we had them beat.
After I got out of the Army, I bought a 79 5 litre Mustang Cobra, first year of that new model. Damn was quick but could not corner worth a damn and the brake sucked hind teat. I actually spun it out going around a corner just a tad bit too hot, was chasing a Datsun Z who made the corner at speed no sweat.
Unread post by totalmotorcycle » Fri Jan 27, 2012 5:06 am
I have to be honest and say the more I look at the 2013 Victory Judge the more it is drawing me in to ride it. I think the 2013 Victory Judge will be a hit, unless it's a pig of a bike...
ceemes & ZRex : Yes, there is nothing like a muscle car is there? I'm drawn to them myself, I equate a muscle car to a naked bike as it's all about the engine and simplicity of it all. I owned a 1980 Camaro V8 back in the day (bought it before I had a licence for $50! outside of a bar) haha.
I looked just like this:
When we move back to North America we looking at buying a muscle car... (Challenger, 350/370z or even a mustang)
Unread post by totalmotorcycle » Fri Jan 27, 2012 5:38 am
Lots of votes for the Victory Judge! Good stuff people.
As it goes into the Cool Wall:
Awesome 42%
Cool 27%
Uncool 12%
Fail 19%
But the vote will remain open as it will be interesting to see how the discussion and voting goes as time goes on.
Thanks for voting on the 2013 Victory Judge and please Vote & Discusss on the new current Cool Wall bike up now.
ZRex
Real Name: Ben
Unread post by ZRex » Fri Jan 27, 2012 1:18 pm
totalmotorcycle wrote:I have to be honest and say the more I look at the 2013 Victory Judge the more it is drawing me in to ride it. I think the 2013 Victory Judge will be a hit, unless it's a pig of a bike...
Yeah I love Muscle Cars and naked bikes for the same reason. It is great to see other people were as lucky as me when it comes to a first car. My dad restored a 1968 Mustang GT to sell but, when he got done he did not want to sell it, so he gave it to me when I was 14, and my neighbor had a 72 Nova that he turned into a drag car. Good luck getting a muscle car, when I get my money situation straightened out I would like to get a new(ish) Mustang GT.
Users browsing this forum: faded sun, Google [Bot], Google Adsense [Bot] and 184 guests
cron
