2012 Suzuki Hayabusa - Voted: Awesome
Your Coolness Factor of the 2012 Suzuki Hayabusa is...
View results
Unread post by totalmotorcycle » Fri Feb 10, 2012 4:08 am
More photos and information: http://www.totalmotorcycle.com/motorcyc ... yabusa.htm
The Suzuki Hayabusa, quite simply, isn't for everyone. With performance credentials that have established it as the most exciting sportbike on the planet, it's designed for serious sport riders who will settle for nothing less than the best. If that's you, and if you choose to ride the Hayabusa, you'll be rewarded with a riding experience you'll never forget. Its combination of unsurpassed power, crisp handling and superb aerodynamics creates the ultimate sport bike.
For 2012, the Hayabusa is available with new graphics and colors - Glass Sparkle Black and Candy Sonoma Red.
Ever since Suzuki introduced the Hayabusa, it's had only one competitor: Itself. That's why the latest Hayabusa is so impressive - compared to the original, it's hotter than ever. For enthusiasts, that comparison will make your heart pound.
Building on an impeccable pedigree, the Hayabusa features a number of major developments to cement its place at the forefront of sportsbike styling, engineering and performance.
Effortlessly delivering broad, muscular torque, the new Hayabusa is powered by a 1,340cc, DOHC, liquid-cooled, four-cylinder, 16-valve engine, offering 11% greater performance and smoother running than its predecessor.
Suzuki's Dual Throttle Valve (SDTV) fuel injection system, with dual injectors per cylinder, improves power delivery for a more linear response, better fuel economy and reduced emissions.
Idle Speed Control (ISC) improves cold starts and maintains a stable idle, while the Suzuki Pulsed-secondary AIR-injection (PAIR) system and large-volume catalyser reduce emissions.
The new Suzuki Drive Mode Selector (S-DMS) delivers a choice of three different engine power characteristic settings to suit riding conditions and preferences.
A new 4-2-1-2 exhaust system includes dual, large-volume, tapered mufflers for increased banking angle, cornering clearance, enhanced power and reduced noise.
The slick-shifting six-speed transmission works in conjunction with the innovative Suzuki Clutch Assist System (SCAS) back-torque-limiting clutch to deliver smooth and controlled downshifts.
Featuring fully-adjustable spring preload, compression and rebound damping on the front suspension and link-type rear shock absorber, the Hayabusa's inverted cartridge forks use Diamond-Like Coating (DLC) surface treatment to reduce static friction and improve rider feel.
Race-proven, aluminium piston, radial-mount front brake calipers combined with smaller 310mm dual-floating-discs reduces unsprung weight and improves handling.
The original Hayabusa was the best. With today's Hayabusa, you're looking at better than the best.
2012 Suzuki Hayabusa Key Features
Redesigned instrument cluster now features four analog meters for speedometer, tachometer, fuel gauge and water temperature with a new S-DMS mode indicator, gear position indicator and adjustable engine rpm indicator.
1340cc engine, DOHC liquid-cooled engine with 16-valves, Twin Swirl Combustion Chambers provides 11% higher performance and smoother operation.
Suzuki SDTV fuel injection system with dual injectors per cylinder and ram air intake with large volume airbox.
S-DMS (Suzuki Drive Mode Selector) allows the rider to choose from three different engine settings depending on riding conditions or rider preferences.
Lightweight titanium intake and exhaust valves with narrow 14 degree valve angle for high combustion chamber efficiency.
Lightweight aluminum alloy pistons feature a revised shape and a higher compression ratio of 12.5:1 for maximum performance in all conditions.
SCEM (Suzuki Composite Electro-chemical Material) plated cylinders minimize cylinder size and improve heat dissipation and new hydraulic cam chain tensioner for reduced mechanical noise.
Ventilation holes at the cylinder skirt for reduced pumping losses and increased performance.
High efficiency curved radiator now features dual electric fans controlled by the ECM for increased cooling capacity. Oil cooler now has 10 rows cores for increased heat dissipation.
Large volume 4-2-1-2 exhaust system with a large capacity catalyzer, dual triangular canisters and closed loop system that meets Euro 3 and Tier 2 regulations.
Shot-peened chrome-moly steel connecting rods for maximum durability Ion plating treatment utilizing PVD (physical vapor deposit) method is applied to piston rings providing a smoother surface treatment for increased durability, reduced friction loss and reduced oil consumption.
Slick shifting 6 speed transmission working in conjunction with an innovative back torque limiting clutch for smooth and controlled downshifts.
Aggressive aerodynamic fairing design with low drag coefficient retains it's signature Hayabusa look and features an updated, muscular look to work with the new more powerful engine and updated chassis.
Fully adjustable inverted front fork featuring DLC coated inner tubes for minimal friction resistance and outstanding suspension performance over a variety of riding conditions.
Fully adjustable rear shock absorber with a 43mm piston and 14mm rod diameter.
Lightweight and rigid twin-spar aluminum frame minimizes weight while maintaining high torsional strength.
Bridged aluminum alloy swingarm features a new cross-sectional shape for increased rigidity and to cope with improved rear tire grip and increased engine output.
Radial-mount front brake calipers for maximum braking performance and allows for smaller 310mm front brake rotors resulting in reduced unsprung weight and improved handling.
Lightweight single piston rear brake caliper working in conjunction with a new larger 260mm rear brake disc.
Newly designed wheels mounted with high performance Bridgestone BT-015 tyres for unmatched handling and control.
Passenger seat and rear subframe are lowered for improved passenger comfort
Fuel tank height is lowered to allow riders helmet to tuck in and windscreen height is increased for improved wind protection and optimum aerodynamic efficiency with the rider in place.
Newly designed vertically stacked twin headlights provide increased light intensity, improved light distribution and match the elegant flow of the new Hayabusa styling.
LED taillight utilizes a double lens structure with a clear inner lens and a red outer lens for maximum visibility and a high quality finish.
2012 Suzuki Hayabusa - USA Specifications/Technical Details
US MSRP Price: $13,999 USD
Canada MSRP Price: $15,399 CDN
CHASSIS
Overall Length 2190 mm (86.2 in)
Overall Width 735 mm (28.9 in)
Wheelbase 1480 mm (58.3 in)
Ground Clearance 120 mm (4.7 in)
Seat Height 805 mm (31.7 in)
Curb Weight 260 kg (573 lbs)
Transmission 6-speed constant mesh
Final Drive Chain, RK GB50GSV Z4, 114 links
Suspension Front Inverted telescopic, coil spring, oil damped
Suspension Rear Link type, coil spring, oil damped
Brakes Front Disc brake, twin
Brakes Rear Disc brake
Tires Front 120/70ZR17 M/C (58W), tubeless
Tires Rear 190/50ZR17 M/C (73W), tubeless
Fuel Tank Capacity 21.0 L (5.5 US gallons)
Fuel Tank Capacity CA 20.0 L (5.3 US gallons)
Color Glass Sparkle Black and Pearl Glacier White
ENGINE
Displacement 1340cc, 4-stroke, Liquid-cooled, 4-cylinder, DOHC
Fuel System Suzuki fuel injection
Starter Electric
Ignition Electronic ignition (transistorized)
WARRANTY
Warranty 12 month unlimited mileage limited warranty.
2017 Motorcycle Model Guides
madjak30
Years Riding: 3
My Motorcycle: 2006 Yamaha MT-01
Re: This Week's Bike: 2012 Suzuki Hayabusa - Vote & Discuss
Unread post by madjak30 » Fri Feb 10, 2012 11:30 am
Well, it's not the bike it used to be...Kawasaki has topped it with the Ninja ZX-14R...and that has been topped by the BMW S1000RR...so it isn't the TOP DOG anylonger, but those other bikes don't have the name & marketing...you ask most non-riders what the fastest bike is and I would be willing to bet the Hyabusa, or 'Busa, would be at the top of the list 99% of the time...
It's not really a HyperBike, but it is a SuperSport Touring bike...I would love to take one for a blast, but I'm not sure if I could own one (opinion may change after a ride :mrgreen: )
I voted: AWESOME
Just on reputation alone of being an all around great and easy bike to ride, but offering some of the best performance you can buy...pull off the tacky decals and you have a pretty nice bike :wink:
Later.
Unread post by dr_bar » Fri Feb 10, 2012 5:14 pm
I know I'll take flack for this but...
I voted uncool if only for the fact that any squid in the world can buy this bike that should really be limited to track use only. There is no reason whatsoever to have that much power in a bike.
HYPERR
Unread post by HYPERR » Fri Feb 10, 2012 6:20 pm
With a name as cool as Hayabusa (I love when manufacturers name bikes in their native language 8) ...as long as it's not Chinese :laughing: ) and monster engine to back it up, there is no other way to vote other than Awesome. :kicking:
ZRex
Real Name: Ben
Unread post by ZRex » Fri Feb 10, 2012 11:23 pm
This is a tough one, the Hayabusa is an Awesome bike, but not as Awesome as the ZX-14R. I guess I will have to vote Awesome, I guess it was not as tough as I thought.
Unread post by Wrider » Sat Feb 11, 2012 12:56 am
I'm gonna vote cool. I love the Busa, and everyone here knows that, but at the same time, the '12 ZX14 blows it away.
Years Riding: 41
Unread post by High_Side » Sat Feb 11, 2012 7:08 am
It's alright I suppose.... cool.
Grey Thumper
Real Name: Dino
Unread post by Grey Thumper » Sat Feb 11, 2012 8:11 am
There's a reason why it's name rhymes with Eye Abuser ;-P
That said, I love "form follows function"-type bikes, and the Hayabusa is, in its own weird way, one of the most provocative, polarising, and influential bikes of the late 90s, and a modern classic. Cool then.
HYPERR
Unread post by HYPERR » Sat Feb 11, 2012 11:51 am
Grey Thumper wrote:There's a reason why it's name rhymes with Eye Abuser ;-P
It only rhymes if one does the non-prevocalic [r] deletion as in a typical New York City accent. :wink:
ceemes
Real Name: a big secret
Unread post by ceemes » Sat Feb 11, 2012 8:33 pm
I'd say cool, but its not really my style of bike....and to be honest, its tail strikes me as rather ugly looking, looks like they fished some tail bits and bobs out of excess cruiser part bin.
Unread post by sunshine229 » Mon Feb 13, 2012 3:15 pm
Well boys... I really struggled with this one but in the end I had to vote uncool. :sofa:
Maybe it's just me but I don't see the necessity for this kind of power and speed for a road bike. Also, I don't like the bubbly look of it. Does anyone actually find the look of this bike appealing? :dunno:
Unread post by totalmotorcycle » Wed Feb 15, 2012 4:37 am
I went with: Uncool
In my opinion it's kind of a "lost child" in the Suzuki range. Sure, Suzuki needed a sport touring bike to compete with the other manufacturers but this engine has a lot more potential than being stuck in just 1 model. Back when it was first launched (2002 I believe) I thought Suzuki was going to also make a GSX-1300R with it (as well), but to no avail yet.
I would like to see more updates to the Hayabusa and for it to go on a fat slimming diet program. It's just too "bulky" looking and the rear end of the bike always makes me think "scooter". If Suzuki cleaned the lines up more by adding some angles to bring the style more up to date then that would work and get rid of the camel hump rear please (fail).
Again, wonderful engine (awesome), why not put it in a 2013 Suzuki Bandit 1350 or 2013 GSX-R1300?
For me, the Busa does have a well deserved reputation but it just falls too short to be cool.
jstark47
Unread post by jstark47 » Wed Feb 15, 2012 6:32 pm
It gets a Cool from me for that marvelous motor. I've never much liked the way it looks (...but as we V-strom owners say, if you're riding it you don't need to look at it!!!!) :mrgreen:
totalmotorcycle wrote:Sure, Suzuki needed a sport touring bike to compete with the other manufacturers but this engine has a lot more potential than being stuck in just 1 model.
Suzuki tried putting that engine in a different bike, the B-King. It didn't work out well for them.
Unread post by totalmotorcycle » Thu Feb 16, 2012 2:25 am
Doh, of course, had a brain fart there. I even looked at buying a B-King when I first saw it in images, but then when I sat on it it wasn't a good fit and was quite wide, but then I bought a V-Strom so go figure! haha.
I agree, wonderful engine, Suzuki just needs to put it into a non-bulky naked bike or sportbike.
Unread post by Wrider » Thu Feb 16, 2012 3:22 am
Pssst, hey Mike, it is the GSX-1300R. Oh and '97... lol
Honestly though if they tuned the Busa motor like they do the GSX-R lineup, it'd produce some amazing horsepower numbers. And I keep wishing Suzuki would come out with an actual sport tourer along the lines of the Concours, KxxxxGT, FJR, or ST.
Unread post by totalmotorcycle » Thu Feb 16, 2012 3:51 am
Wrider wrote:Pssst, hey Mike, it is the GSX-1300R. Oh and '97... lol
I should just go back to bed today! haha. Didn't have a lot of sleep when I wrote that and of course as Andrea would tell you, never have time to re-read my posts a lot... :laughing:
Thank god you got the gist of what I was saying with the tuning of the Busa motor though and the idea of a actual sport tourer like the other's have. Although they are trying with the 2012 Suzuki GSX1250FA ST/SEA Touring here: http://www.totalmotorcycle.com/motorcyc ... ouring.htm
Unread post by Wrider » Thu Feb 16, 2012 12:38 pm
Lol you're one busy guy... I know exactly what you were saying! But yeah if they would make an actual sport touring bike it'd be great!
Unread post by totalmotorcycle » Thu Feb 16, 2012 12:53 pm
The votes are still coming in so it will be interesting to see how the Busa' comes out tomorrow morning... so far it's:
Awesome 40%
Cool 30%
Uncool 25%
Fail 5%
Keep voting!
jstark47
Unread post by jstark47 » Thu Feb 16, 2012 4:30 pm
Wrider wrote:And I keep wishing Suzuki would come out with an actual sport tourer along the lines of the Concours, KxxxxGT, FJR, or ST.
.......and the idea of a actual sport tourer like the other's have. Although they are trying with the 2012 Suzuki GSX1250FA ST/SEA Touring
IMO the GSX1250FA is a lot closer to the idea of a sport-tourer than a ST1300. And if something happened to my Trophy, I would much sooner buy a GSX1250FA than a Concours 14. The GSX1250FA comes at a reasonable price, it's not larded up with electronic gizmos, and the Concours has no answer to its 130 lb weight advantage. No, it doesn't have the top end performance of the Concours, but ........ seriously.... where the heck am I gonna use that? The Bandit motor is famous for its fat torque band. I sat on a GSX1250FA at the NY show last month, it felt light and comfy.
mogster
Real Name: MOG
Unread post by mogster » Thu Feb 16, 2012 5:46 pm
dr_bar wrote: I voted uncool if only for the fact that any squid in the world can buy this bike that should really be limited to track use only. There is no reason whatsoever to have that much power in a bike.
+1
Funnily enough I bumped into an old friend today who drags his 'Busa here in UK. It is an awesome bike on the strip but when I see it parked up next to others on a night out (his is street legal), it always looks like an enormous lump of plastic.
I am sure the tech spec on the new model is impressive but not my cup of tea old chap.
Uncool from me :(
:party:
Users browsing this forum: ceemes, montanalifter and 102 guests
cron
