2012 Honda Gold Wing GL1800: Voted Uncool
Your Coolness Factor of the 2012 Honda Gold Wing GL1800 Audio Comfort is...
View results
Unread post by totalmotorcycle » Fri May 18, 2012 10:19 am
More photos and information: http://www.totalmotorcycle.com/motorcyc ... omfort.htm
Long acknowledged as the pinnacle of two-up motorcycling, the 2012 Gold Wing® continues its remarkable legacy. Its travel-oriented creds include the latest generation of sophisticated electronic amenities, starting with an innovative GPS navigation system with user-friendly programmability for sharing favorite ride routes with friends and other riders, which can be accessed online via computer. The Gold Wing also now incorporates a built-in MP3/iPod® interface for a new SRS CS Auto™ technology surround-sound system for a premium listening experience. In addition to its renowned power-laden yet refined drivetrain and delightfully sporty handling, the 2012 Gold Wing also brings upgraded styling, increased luggage capacity, greater protection from wind and weather, revised suspension settings for enhanced ride compliance, and unparalleled comfort for both rider and passenger. In addition, packages for Navi, ABS and airbag do much to further the Gold Wing's reputation as the most celebrated touring machine in motorcycle history.
There’s big news when it comes to the new 2012 Honda Gold Wing. Because we’ve taken what is the world’s best touring motorcycle and made it even better. The new bodywork is the first thing you’ll notice, complementing what is the best engine and chassis package the touring world has ever seen. Look a little further and you’ll discover great new improvements to the audio system, the available navigation system, and the Gold Wing’s comfort, too. And there’s new functionality, as well, like integrated iPod® connectivity and the ability to upload trips to the navi system from your home computer.
If you thought the Gold Wing was the world’s ultimate touring motorcycle, you were right. And if you think the new Gold Wing is even better, you’re right again.
2012 Honda Gold Wing GL1800 Audio Comfort Features and Benefits
New for 2012
- Fresh styling cues produce a more integrated appearance along with a sporting edge, adding to the premium touring visage.
- Redesigned fairing adds extra wind protection, especially to the lower body and leg areas.
- Larger saddlebags add approximately 7 liters of additional storage space, upping total capacity to well over 150 liters including the trunk and fairing pockets.
- Handy central storage pocket added to models without airbag.
- Revised suspension settings front and rear yield added compliance for a better ride and more comfort.
- Urethane seat material and cover material give added comfort.
- Re-shaped taillight adds a distinctive appearance and aids visibility.
- Wheels are now clear-coated for easier cleaning and a great, long-lasting look.
- Updated instrumentation styling lends a high-performance touch.
Next-Generation Honda Satellite Linked Navigation System™:
- New, fully integrated navigation system with new, brighter color screen.
- Next-generation receiver gives quicker satellite connection.
- 3-D terrain view, lane assist with junction view and more.
- Complete United States and Canada mapping with points of interest installed.
- Points-of-interest information includes Honda dealers, fuel stations, restaurants, lodging, attractions, transportation, government and emergency information and saved rider's input with home function.
- Voice prompting through headsets or speakers.
- On-screen text guidance and pop-up menus.
- Easy-to-use handlebar and fairing-mounted controls.
- Navigation available on select Gold Wing models.
Next-Generation Premium Audio System:
- New enhanced system offers direct MP3/i-Pod connectivity plus full device control through handlebar controls.
- SRS CS Auto™ technology surround-sound system brings the latest in sound system technology to the Gold Wing.
- 80-watt-per-channel power amplifier provides clear, crisp sound at all highway speeds.
- Six-element speaker system includes two rear speakers, a pair of front speakers and two tweeters for a rich, full surround sound quality.
- Tuner features auto bass control combined with auto volume control.
- Standard on all Gold Wing models.
2012 Honda Gold Wing GL1800 Audio Comfort - US Specifications
USA MSRP Price - $23,199 USD
Canada MSRP Price - $29,999 CDN
ENGINE
Engine Type 1832cc liquid-cooled horizontally opposed six-cylinder
Bore And Stroke 74mm x 71mm
Induction Programmed Fuel Injection (PGM-FI)
Ignition Computer-controlled digital with three-dimensional mapping
Compression Ratio 9.8:1
Valve Train SOHC; two valves per cylinder
DRIVE TRAIN
Transmission Five-speed including Overdrive, plus electric Reverse
Final Drive Shaft
CHASSIS / SUSPENSION / BRAKES
Front Suspension 45mm cartridge fork with anti-dive system, 5.5 inches travel
Rear Suspension Pro Arm® single-side swingarm with Pro-Link® single shock with computer-controlled spring preload adjustment with two memory presets; 4.1 inches travel
Front Brake Dual full-floating 296mm discs with CBS three-piston calipers
Rear Brake Single ventilated 316mm disc with CBS three-piston caliper
Front Tire 130/70R-18
Rear Tire 180/60R-16
DIMENSIONS
Rake 29.15 degrees
Trail 109mm (4.3 inches)
Wheelbase 66.5 inches
Seat Height 29.1 inches
Curb Weight 904-933 pounds, depending on option packages selected (Includes all standard equipment, required fluids and a full tank of fuel-ready to ride)
Fuel Capacity 6.6 gallons
OTHER
Model Id GL18HPM
Emissions Meets current California Air Resources Board (CARB) and EPA standards.
Available Colors Candy Red, Pearl White, Ultra Blue Metallic, Black
FACTORY WARRANTY INFORMATION
Three Years Transferable, unlimited-mileage limited warranty; extended coverage available with a Honda Protection Plan.
2017 Motorcycle Model Guides
2016 Motorcycle Model Guides
Re: This Week - 2012 Honda Gold Wing GL1800: Vote and Discus
Unread post by totalmotorcycle » Fri May 18, 2012 10:21 am
Since our last Cool Wall bike (which was a 800cc tourer) was so popular let's bring out the big gun battleship and see how the Honda Goldwing does! This might be the base Gold Wing but there is nothing base about it's luxury list of features.
Unread post by Johnj » Fri May 18, 2012 2:06 pm
Jebus, why don't you just get a car.
Unread post by totalmotorcycle » Fri May 18, 2012 2:47 pm
Johnj wrote:Jebus, why don't you just get a car.
:laughing:
Unread post by Wrider » Fri May 18, 2012 5:10 pm
I can understand the Goldwing by itself, it's the Goldwings with sidecars (with able-bodied riders), and/or trailers that I ask that about. If you honestly need enough room to fit stuff that you need a 'Wing and a trailer, you could probably fill a Cadillac pretty easily.
Grey Thumper
Real Name: Dino
Unread post by Grey Thumper » Sat May 19, 2012 6:48 am
This.
ceemes
Real Name: a big secret
Unread post by ceemes » Sat May 19, 2012 12:47 pm
I am gonna go with cool mainly because the big Wing is in a class by itself. There are other that are close, but they just don't quite come up to the Wing's shoulders. And for a big arsed monster, its pretty maneuverable and quick, if I am not mistaken the quickest time clocked doing the infamous Dragon is held by a Wing, or at least so I have been told.
Not my type of bike, but still cool.
Unread post by Wrider » Sat May 19, 2012 1:12 pm
ceemes wrote:I am gonna go with cool mainly because the big Wing is in a class by itself. There are other that are close, but they just don't quite come up to the Wing's shoulders. And for a big arsed monster, its pretty maneuverable and quick, if I am not mistaken the quickest time clocked doing the infamous Dragon is held by a Wing, or at least so I have been told.
I'm pretty sure you're right on this. I know one guy that consistently smokes sportbike riders on it lives 5 miles from it and owns a 'Wing. From what I hear he's gone through 3 sets of valve covers on the thing. Now THAT is getting over...
HYPERR
Unread post by HYPERR » Sat May 19, 2012 8:05 pm
Goldwings can only be awesome.
JackoftheGreen
Real Name: Eric
Unread post by JackoftheGreen » Sun May 20, 2012 12:23 am
I gotta go with Uncool.
I understand the reason someone might want this bike, and I understand the sort of people who may turn to this bike as a way to keep riding. This bike has it's place, and fulfills a necessary role in the motorcycling pantheon.
However, the same things could be said about Prius' (Prii, I think the plural is now), minivans, Smartcars and prenuptial agreements. All practicle, all necessary, all fatally uncool.
Thumper
Real Name: K.A. Thompson
My Motorcycle: '14 BMW F700GS
Unread post by Thumper » Sun May 20, 2012 1:41 pm
If I did a lot of touring, I would probably like this a lot more than I do. I think it's cool because of its potential...just impractical for day to day riding. Though, if I ever get to where I can't hold two wheels up, I'd love to trike a Gold Wing and make it a daily driver.
snakedoctEr726
Real Name: Kyle
My Motorcycle: '11 BMW K1300S
Unread post by snakedoctEr726 » Sun May 20, 2012 10:40 pm
Personally I'm not a Goldwing fan, I'd much rather have a K1600GT, but I can respect the engineering that went into the wing. I see people hating on them all over but Goldwing sales probably make up a good chunk of Honda revenue. That said, i had to vote uncool because it just doesn't seem like a very fun bike to ride.
Grey Thumper
Real Name: Dino
Unread post by Grey Thumper » Mon May 21, 2012 2:08 am
snakedoctEr726 wrote:Personally I'm not a Goldwing fan, I'd much rather have a K1600GT, but I can respect the engineering that went into the wing.
Good point. I was trying to figure out why I think the Goldwing is uncool. I was about to suggest that all its creature comforts kinda take away from the spirit of motorcycling, but that's a silly argument. The K1600GT arguably has more electronic/comfort/convenience/luggage doodads, and I'm fine with that bike (although I wouldn't buy one either).
I guess it's the Goldwing's stuck-in-the-80s Barcalounger styling that (IMHO) is uncool. Of course, as has been mentioned, in spite of its looks, these things can be hustled
Unread post by dr_bar » Mon May 21, 2012 2:31 am
There is no other bike that is in the same class as the Goldwing. I voted awesome, just be ause it is. Anybody that thinks this is a cumbersome bike, has never ridden one. Saw this video posted on a Harley site and the poster was suitably impressed...
sapaul
Unread post by sapaul » Wed May 23, 2012 5:03 am
I had this on demo a while back. it handles like a dream, plenty of grunt and an absolute pleasure to ride. Lots of gadgets and when you can scrape the centre stand in the corners without fear, well nuff said
I vote awsome
Unread post by Wrider » Wed May 23, 2012 7:56 am
sapaul wrote:I had this on demo a while back. it handles like a dream, plenty of grunt and an absolute pleasure to ride. Lots of gadgets and when you can scrape the center stand in the corners without fear, well nuff said
I vote awesome
Fixed your spelling there for you.
*sneaks back to hidey hole to watch the fun ensue* :twisted:
ceemes
Unread post by ceemes » Wed May 23, 2012 12:26 pm
Wrider wrote:
sapaul wrote:I had this on demo a while back. it handles like a dream, plenty of grunt and an absolute pleasure to ride. Lots of gadgets and when you can scrape the centre stand in the corners without fear, well nuff said
I vote awesome
And I fixed it back to the way it should be.... damn 'mericans cannot speak let alone spell the Queen's English properly. :devil:
Unread post by Wrider » Wed May 23, 2012 1:32 pm
ceemes wrote:
I vote awesome
Que?
HYPERR
Unread post by HYPERR » Wed May 23, 2012 4:52 pm
ceemes wrote: And I fixed it back to the way it should be.... damn 'mericans cannot speak let alone spell the Queen's English properly. :devil:
C'est Français Monsieur Ceemes... :wink:
madjak30
Years Riding: 3
My Motorcycle: 2006 Yamaha MT-01
Unread post by madjak30 » Wed May 23, 2012 10:14 pm
Voted: Uncool...
It's not really either, but I can't say I would feel cool riding one...even though it would be a great bike to ride and tour on...there should be an "Okay" choice...I wouldn't feel like a dork, but definitely not cool.
Later.
Users browsing this forum: Gigabot [Bot], Grey Thumper, montanalifter and 199 guests
cron
