2013 Kawasaki Concours 14 ABS: Voted Cool
Posted: Thu Dec 20, 2012 5:44 pm
2013 Kawasaki Concours 14 ABS on the Total Motorcycle Cool Wall
More photos and information: http://www.totalmotorcycle.com/motorcyc ... s14ABS.htm
This year continues Kawasaki's heritage of high performing, versatile, rider-friendly sports motorcycles. There are some welcome returns along with a few young upstarts that'll get your heart racing.
Inspiring Touring Performance, Enviable Sporting Credentials
Sport touring riders are among the most discerning of all motorcyclists, and the Concours™ 14 supersport tourer's combination of technology, comfort and continent conquering performance meets the toughest demands of this selective crowd. It is powered by a muscular heart derived from the legendary Ninja® ZX™-14 sportbike. Comfortable ergonomics make it well-suited to long days in the saddle, while offering proper body positioning for sport riding. Its overall performance will entice riders to pull out the big maps and plan extraordinary sporting tours through the next county or country.
The Concours 14 holds its own with the best world-class touring rigs yet still negotiates the twists and turns of America’s backroads in finest, Ninja-inspired tradition. Whether carving through canyons, devouring highways and even shuttling through the cities, a Concours 14 provides the ultimate platform for your next sport touring adventure.
The Concours 14 supersport tourer boasts several features that enhance comfort, convenience and safety, solidifying its position at head of the class. Dynamic bodywork increases comfort by routing heat away from the rider and passenger. A tall, electrically adjustable windscreen creates a calm cockpit experience with help from ducts above the instrument panel, which balances pressure areas outside and inside the screen. Handgrip heaters come standard, providing comfort when the temperatures drop to disagreeably cold temperatures.
The Concours is packed with technological features that enhance the riding experience. The bike’s K-ACT (Kawasaki Advanced Coactive-braking Technology) braking system offers two modes of linked, anti-lock braking and great overall performance. A high-tech traction control system (KTRC: Kawasaki Traction Control) not only reduces wheelspin on slick surfaces, offering riders more confidence-inspiring feedback, but it can be easily switched off at the rider’s discretion.
2013 Kawasaki Concours 14 ABS Key Features
• Ninja ZX-14-based 1,352cc inline-four with variable valve timing provides smooth power across a wide rev range
• Kawasaki Traction Control (KTRC) reduces engine output when wheelspin is detected, helping the rear tire to regain grip
• Kawasaki Coactive-braking Technology (K-ACT) links front and rear brakes and has two modes to suit different riding styles
• Aluminum monocoque frame is lightweight, narrow and rigid
• Tetra-Lever shaft drive offsets the lifting and squatting tendencies of shaft drive
• Fuel economy assistance mode prioritizes fuel savings, giving up to a 25 percent mileage boost
• Standard heated grips help provide comfort even in harsh conditions
• Convenient Kawasaki Intelligent Proximity Activation Starting System (KIPASS)
• Electrically adjustable windscreen has memory function and suits a variety of riders
• Includes a 36 month limited factory warranty that can be supplemented with up to an additional 36 months of Kawasaki’s Good Times™ Protection Plan. That’s a total of up to an amazing SIX YEARS of coverage!
2013 Kawasaki Concours 14 ABS - USA Specifications/Technical Details
US MSRP Price: $16,199 USD
Engine Four-stroke, liquid-cooled, DOHC, four valves per cylinder, inline-four with VVT
Displacement 1,352cc
Bore x Stroke 84.0 x 61.0mm
Maximum Torque 102.0 lb-ft @ 6,200 rpm
Compression Ratio 10.7:1
Fuel System DFI® with four 40mm throttle bodies
Ignition TCBI with Digital Advance
Transmission 6-Speed
Final Drive Tetra-Lever shaft drive
Rake/Trail 26.1 degrees/4.4 in.
Front Tire Size 120/70 ZR-17
Rear Tire Size 190/50 ZR-17
Front Suspension / wheel travel 43mm inverted, telescopic fork with adjustable rebound damping and spring preload / 4.4 in.
Rear Suspension / wheel travel Tetra-Lever with stepless rebound damping adjustment and remote spring preload adjuster / 5.4 in.
Front Brakes Dual floating 310mm petal discs with four-piston calipers with ABS
Rear Brakes Single 270mm petal disc with ABS
Fuel Capacity 5.8 gal.
Seat Height 32.1 in.
Curb Weight 688.0 lbs.
Wheelbase 59.8 in.
Overall Length 87.8 in.
Overall height windscreen lowered / raised: 50.8 in. / 57.7 in.
Overall width 39.4 in.
Color Choices Metallic Spark Black, Metallic Nocturne Blue
Warranty 36 Months
Good Times™ Protection Plan 12, 24 or 36 months are available
Wheelbase 59.8 in.
Warranty 36 Months
