2013 Indian Chief Classic: Cool Factor 42%
Posted: Fri Jan 04, 2013 8:17 am
2013 Indian Chief Classic on the Total Motorcycle Cool Wall
More photos and information: http://www.totalmotorcycle.com/motorcyc ... lassic.htm
Raw. Powerful. And begging to be ridden.
Built of the bare essentials, like a a 105ci PowerPlus engine and a two-into-one stainless steel exhaust system, the Chief Classic is anything but stripped down, providing all you need to cruise the roadways in style and comfort.
The 2013 Indian Chief Classic is what an Indian motorcycle is meant to be. Built with only the essentials: a thick, solo black leather seat with hand-sewn double stitching, refined 105ci PowerPlus engine, two-into-one stainless steel exhaust system, and chromed spoke wheels. It’s definitive proof that less is more. So much more.
2013 Indian Chief Classic Key Features
Colors: Thunder Black, Indian Red
Timeless Indian Script tank design says everything there is to know.
Warbonnet front fender light is as uniquely Indian as it gets.
The flowing lines of classic valance long fenders take you back to a simpler time.
Black and polished engine with chrome covers provide a distinctive, yet powerful look.
2013 Indian Chief Classic - USA Specifications/Technical Details
US MSRP Price: $26,499* USD
Engine
Engine Type
Power Plus, Air-Cooled
Displacement
105 Cubic Inches
Bore x Stroke
3.966" x 4.25"
Compression Ratio
9 to 1
Fuel System
Closed Loop Sequential Port Fuel Injection
Drivechain
Primary Drive
Chain
Gearbox
Six Speed
Gear Ratio (overall)
1st
3.77:1
2nd
2.56:1
3rd
1.87:1
4th
1.44:1
5th
1.15:1
6th
1:1
Final Drive
Belt
Chassis
Frame
High tensile steel
Suspension/Front
Dia. 41 mm/Travel 4.25"
Suspension/Rear
Single shock/Travel 2.90"
Brakes/Front
Dual Caliper w/Floating Rotors
Brakes/Rear
Single Caliper Floating Rotor
Tires/Front
130/90-16 Black
Tires/Rear
150/80-16 Black
Wheels
Wire spoked
Exhaust System
Two into one Stainless Steel
Dimensions
Length
100.5"
Width
40.5"
Height
50.5"
Seat Height
27.25"
Wheelbase
68.4"
Dry Weight
728 lbs
GVWR
1220 lbs
Rake/Trail
34°/5.92"
Electrical & Instruments
Analog speedometer & multi-function digital display
Charging System
42 Amps
Lamps
Tear drop head lamp, fender light
Color
Thunder Black w/silver script; Indian Red w/gold script
Standard Equipment
Long Fenders; Solo Seat w/ Passenger Pillion
Pricing
$26,499
Warranty
2 Years
Engine
Engine Type
Displacement
105 Cubic Inches
Bore x Stroke
3.966" x 4.25"
Compression Ratio
9 to 1
Fuel System
Drivechain
Primary Drive
Chain
Gearbox
Six Speed
1st
3.77:1
2nd
2.56:1
3rd
1.87:1
4th
1.44:1
5th
1.15:1
6th
1:1
Final Drive
Belt
Chassis
Frame
High tensile steel
Suspension/Front
Suspension/Rear
Brakes/Front
Brakes/Rear
Tires/Front
130/90-16 Black
Tires/Rear
150/80-16 Black
Wheels
Wire spoked
Exhaust System
Dimensions
Length
100.5"
Width
40.5"
Height
50.5"
Seat Height
27.25"
Wheelbase
68.4"
Dry Weight
728 lbs
GVWR
1220 lbs
Rake/Trail
34°/5.92"
Charging System
42 Amps
Lamps
Color
Standard Equipment
Pricing
$26,499
Warranty
2 Years
