2013 Moto Guzzi Griso 1200 8V SE - Voted: 83.3%
Your Coolness Factor of the 2013 Moto Guzzi Griso 1200 8V SE is..
View results
Unread post by totalmotorcycle » Fri Apr 26, 2013 11:23 am
2013 Moto Guzzi Griso 1200 8V SE on the Total Motorcycle Cool Wall
More photos and information: http://www.totalmotorcycle.com/motorcyc ... 008VSE.htm
The 2013 Moto Guzzi Griso 8V SE might well be one of the most unique and captivating motorcycles to come out of the Mandello Del Lario factory. The bold character expressed in the nonconformist styling of the Griso is given further emphasis by the aggressive new black/silver color concept in a matte tone that flows elegantly with the numerous black painted metal elements such as the frame, wheels, steering plates, handlebar and instrument panel covers.
Griso 8V SE has impeccable style; this machine is an instinctive creation, pure, solid and distinctive and in many ways a work of art.
The design details are discreet but elegant and pure quality; the lines blend together and are accentuated by the chrome finishing and satin metal form. The fuel tank lends itself superbly to the strong frame creating an aerodynamic teardrop body which is continued through to the tail which houses three high intensity LED light units.
The Griso is decidedly masculine and powerful yet the “Quattrovalvole” engine seems to be set like a jewel in a frame that shows off its revolutionary design to the utmost effect. Returning to the performance, it becomes obvious that the sophisticated components are not mere technical details included for the sake of style but enhances performance and provides guaranteed reactivity.
The Moto Guzzi Griso SE features the latest transverse 90° V-twin from the “Quattrovalvole” series and produces a peak power of 110 hp at just 7500 rpm with a whopping 108Nm of torque at 6400 rpm allowing the Griso SE to dominate the road with a smooth power delivery whilst the outstanding chassis keeps all those horses in check. The chassis is comprised of a twin overhead tubular element made from high tensile steel and generously sized lateral reinforcement of the lower cradle with ribbing that has been added not only for aesthetic purposes but also for increased rigidity.
The stylish black and silver livery contrasts elegantly with the black metal of the frame which also ties in the black rims, steering plates and handlebars. It also boasts chrome spoke wheels and colour coordinated badges. The incredible two-into-one exhaust system highlights the Griso SE’s boldness and further ads to the character of this unique motorcycle. Its details like this that leave an impression before you even ride the Moto Guzzi Griso 8V SE.
2013 Moto Guzzi Griso 1200 8V SE - Specifications/Technical Details
US MSRP Price: $12,690 USA
Canada MSRP Price: $13,590 CDN
ENGINE
Type Four-stroke V 90 twin
Cooling Air and oil cooled with independent cooling pump
Capacity 1,151cc
Bore and stroke 95 x 81.2 mm
Compression ratio 11:01
Maximum power output Over 110 hp at 7,500 rpm
Max Torque 80 foot pounds at 6,400 rpm
Fuel supply/ignition Multipoint sequential electronic injection, Magneti Marelli IAW 5A phased, alfa-n system; 2 x Ø50 mm throttle bodies with Weber IWP 189 injectors, Lambda probe.
Exhaust system Stainless steel two-into-one 3-way catalysed with Lambda probe.
TRANSMISSION
Gearbox 6 speed
Lubrication Oil bath
Final drive CA.R.C reactive drive; double universal joint with floating bevel gear, ratio 12/44 = 1 : 3,666
Clutch Single plate with integrated flexible couplings
CHASSIS / SUSPENSION / BRAKES
Frame High tensile steel tubular twin cradle
Wheelbase 61 inches (1,554 mm)
Trail 4.25 inches (108 mm)
Steering rake 26.30°
Steering angle. 34°
Front suspension Upside down Ø 43 mm fully adjustable forks (spring preload and hydraulic for rebound and compression) with mounting for radial callipers.
Front wheel travel 120 mm
Rear suspension Progressive single swingarm, fully adjustable monoshock with separate gas reservoir (spring preload and hydraulic for rebound and compression).
Rear wheel travel 110 mm
Front brakes Twin floating 320 mm stainless steel wave discs, Brembo radial callipers with 4 opposed pistons.
Rear brakes Single 282 mm fixed stainless steel disc, floating calliper with 2 parallel pistons.
Wheels Tubeless spoke wheels with aluminium Ber rim and Alpina spokes.
Front wheel 3.50" x 17"
Rear wheel 5.50" x 17"
Front tire 120/70 ZR17"
Rear tire 180/55 ZR17"
DIMENSIONS
Length 89 inches (2,260 mm)
Width 32.6 inches (830 mm)
Height 42.12 inches (1,070 mm)
Saddle height 31.4 inches (800 mm)
Minimum ground clearance 7.28 inches (185 mm)
Dry weight 489 pounds (222 kg)
Fuel tank capacity 4.4 gallons (16.7 litres)
Reserve .5 gallon
2017 Motorcycle Model Guides
Re: This week: 2013 Moto Guzzi Griso 1200 8V SE: Vote Today
Unread post by totalmotorcycle » Fri Apr 26, 2013 11:25 am
This weeks cool wall bike is brought to you by: :star: madjak30 and High_Side :star: who suggested it in our "Suggest the next Cool Wall Bike" thread here: viewtopic.php?f=61&t=40774&start=230
Thanks for the great suggestion!
montanalifter
Real Name: Bill
Unread post by montanalifter » Fri Apr 26, 2013 11:50 am
I like it a lot. Unique is written all over this bike.
BRUMBEAR
Real Name: Dave
Years Riding: 40
Unread post by BRUMBEAR » Fri Apr 26, 2013 1:50 pm
I really like it I wouldn't buy one cause I already got a v-50 :D but I wouldn't kick it outa bed for eating Ritz crackers if ya folla me
there aint nothin like it
HYPERR
Unread post by HYPERR » Fri Apr 26, 2013 6:32 pm
Awesome! I want one! :D
madjak30
Years Riding: 3
My Motorcycle: 2006 Yamaha MT-01
Unread post by madjak30 » Fri Apr 26, 2013 8:18 pm
I voted: AWESOME
It's a really nice looking bike, but I still like mine better...but if you're in the States and can't get the MT-01, this is a nice alternative. ;-)
Years Riding: 41
Unread post by High_Side » Sat Apr 27, 2013 6:47 am
Awesome - always loved this bike, but prefer the older green bike / brown seat version if I had the choice. When you look around there really isn't another bike like it out there.
jstark47
Unread post by jstark47 » Sat Apr 27, 2013 1:01 pm
Not my favorite color scheme for this bike - I liked the ones that were the muted green color with the medium-brown leather seat.
Nonetheless....... it's a Griso 8v. One of my all-time motorcycle lust objects. Automatic AWESOME!! If Piaggio would get serious about their ridiculously sparse dealer network, I woudl SO own one of these.
BobK
Years Riding: 43
Unread post by BobK » Sat Apr 27, 2013 2:07 pm
I had a ride on one and it truly is awesome. I would have bought one if I hadn't had a bad experience with the local dealer.
HYPERR
Unread post by HYPERR » Sat Apr 27, 2013 5:55 pm
High_Side wrote:Awesome - always loved this bike, but prefer the older green bike / brown seat version if I had the choice.
jstark47 wrote:Not my favorite color scheme for this bike - I liked the ones that were the muted green color with the medium-brown leather seat.
That was the Special Edition Tenni that came out in 2009 and is my fave Griso as well. :kicking:
Hanson
Real Name: Richard Hanson
Years Riding: 3
Unread post by Hanson » Sun Apr 28, 2013 2:08 pm
I love the look of the Moto Guzzi bikes and I would love to own one. Perhaps a V7 Special, but I also love the idea of long distance riding, there are so many places I want to visit, and the lack of a strong dealer network weighs heavy on my mind. The Griso is just gorgeous.
If I lived in a city with a good Guzzi dealer and had room in the budget for two bikes so that one could just be used in the local environs, then one of the bikes in my garage would be a Moto Guzzi, or perhaps a Ducati, I love the exhaust art on the Ducati Diavel.
What man doesn't want to ride a naked Italian supermodel?
The Griso is easily an Awesome.
storysunfolding
Years Riding: 22
Unread post by storysunfolding » Sun Apr 28, 2013 5:07 pm
Beautiful bike. If I was single I'd buy one just for the bar bunnies.
My Blog
Grasp life by the handlebars
JackoftheGreen
Real Name: Eric
Unread post by JackoftheGreen » Sun Apr 28, 2013 5:26 pm
Like some women I've known, this bike looks great from the back but it all falls apart in profile. Tank's too low and long to look muscular, and whatever the hell that thing is on the exhaust tip looks great from the back and ridiculous from the side.
That said, I still wanna jump on it and make it scream. Still not the bike to lure me away from cruisers, but it's close. A solid Cool.
sapaul
Unread post by sapaul » Mon Apr 29, 2013 2:06 am
UUghhh "caveman sounds", uuuughhh uugghhh
Just looking at that thing makes me wanna go riiiiiiiiidddeeeee
Grey Thumper
Real Name: Dino
Unread post by Grey Thumper » Mon Apr 29, 2013 5:42 am
I think I've seen the Griso in one form or another (concept bike to 8v) for almost a decade, and I still haven't gotten tired of those looks. An awesome modern classic, and there really is nothing else like it out there.
Unread post by totalmotorcycle » Wed May 01, 2013 12:26 pm
I voted: Awesome (or Cool+)
I considered the Griso 1200 when I bought my V7 Stone, it definitely is a very unique bike on the market, amazing engine, awesome performance and is a true torque beast. I also really like the design of it and the colour choices Moto Guzzi has done. Even the price for the Griso from a top tier manufacturer like Guzzi is very reasonable. In short, it's pretty awesome. I wonder if there will ever be a V7 "Big Block" Guzzi. :revv:
What made me not buy the Griso was it's riding position (for me, a tall rider), the pegs, seat and handlebar just made me feel a little too pretzel like. If Guzzi lowered the pegs and/or raised the seat then it would have helped.
That said, it's an awesome bike (way to go Moto Guzzi) and I wonder what will come of the next generation Griso as now the California 1400 engine is out...
One thing for sure, Guzzi's are all unique bikes full of character. I'm sure it's 6's and 7's for some but it's one of those engines (small or big block) you just have to take a test ride on and see what it's like.
Unread post by totalmotorcycle » Thu May 02, 2013 9:41 pm
Get your votes in now, tomorrow is closing day for voting (to be recorded on the Cool Wall). !
Unread post by totalmotorcycle » Fri May 03, 2013 11:02 am
2013 Moto Guzzi Griso 1200 8V SE - Coolness Factor = 83.3%
Featured: April 26th, 2013 - May 3rd, 2013
Amazingly we only have 2 bikes in our 2013 Cool Wall lineup that have had 0 fail votes and they are both Moto Guzzi's! In fact, this particular Moto Guzzi with it's final score of 83.3% rockets it up to #1 SPOT on our Cool Wall making it THE most cool bike to date. It's unfortunate then there are not many riders taking advantage of such an awesome bike as there are few on the roads, but maybe that is what makes the Griso so cool too?
Users browsing this forum: Gummiente, markdcoco, montanalifter, ZRex and 99 guests
cron
