Suzuki Boulevard C50 BOSS: Coolness Factor = 52.3%
Your Coolness Factor of the 2014 Suzuki Boulevard C50 BOSS is..
View results
Unread post by totalmotorcycle » Fri Jun 21, 2013 10:47 am
2014 Suzuki Boulevard C50 BOSS on the Total Motorcycle Cool Wall
For A LOT MORE photos and information click here: http://www.totalmotorcycle.com/motorcyc ... 0-BOSS.htm
Go ahead, what are you waiting for?
One word comes to mind to describe the Suzuki Boulevard C50 B.O.S.S. - classic, a classic that just got better! The C50 B.O.S.S. is a cruiser that offers blacked out classic styling, unmatched comfort, and thrilling performance. With kicked out front ends, wide handlebars, smooth suspension, and well-cushioned seating; Suzuki's design team has the rider's comfort in mind. The C50 B.O.S.S. boasts a fuel-injected, 45-degree, V-twin engine that cranks out 805cc that generates abundant torque down low and matched by exciting top-end performance.
Cruise down the boulevard and own the night with a Suzuki B.O.S.S..
Climb aboard a true classic. Kick back and enjoy the timeless style that made riding synonymous with freedom. It’s all about the laid-back stance, broad saddle, and that irresistible rumble that only a cruiser can provide.
2014 Suzuki Boulevard C50 BOSS Total Motorcycle Key Features
The C50 B.O.S.S. has the following features blacked out: Head lamp housing, Rearview mirrors, Handlebars, Clutch lever, Brake lever, Handle switches, Front fork outer tubes, Steering stem head, Tank cover, Air cleaner cap, Clutch cover, Side covers, Second air valve cover, Generator cover, Final gear case, Taillight cover, Front brake caliper, Front and rear wheels, Mufflers, Prop stand
2014 Suzuki Boulevard C50 BOSS - Total Motorcycle USA Specifications/Technical Details
US MSRP Price: TBA USD
Engine
Engine 805cc, 4-stroke, 2-cylinder, liquid-cooled, SOHC, 45 degree V-Twin TMW
Bore x Stroke 83.0 mm x 74.4 mm (3.268 in x 2.929 in)
Compression Ratio 9.4 : 1
Fuel System Suzuki Fuel Injection
Starter Electric
Lubrication Wet sump
DriveTrain
Transmission 5-speed constant mesh
Final Drive Shaft Drive
Chassis
Suspension Front Telescopic, coil spring, oil damped
Suspension Rear Link type, coil spring, oil damped
Brakes Front Disc brake
Brakes Rear Drum brake
Tires Front 130/90-16M/C 67H, tube type
Tires Rear 170/80-15M/C 77H, tube type
Fuel Tank Capacity 4.1 US - Including Reserve
Color Glass Sparkle Black
Electrical
Ignition Electronic ignition (Transistorized)
Spark Plug NGK DR8EA or DENSO X24ESR-U
Headlight 12V 60/55W
Tail Light 12V 21/5W
Dimensions and Curb Weight TMW
Overall Length 2500 mm (98.4 in)
Overall Width 955 mm (37.6 in)
Wheelbase 1655 mm (65.2 in)
Ground Clearance 140 mm (5.5 in)
Seat Height 700 mm (27.6 in)
Curb Weight 611 lbs
Warranty
12 month unlimited mileage limited warranty.
2017 Motorcycle Model Guides
2016 Motorcycle Model Guides
Re: This week: 2014 Suzuki Boulevard C50 BOSS: Vote Today
Unread post by totalmotorcycle » Fri Jun 21, 2013 10:48 am
New for 2014, the first of 2 new 2014 Cruisers Suzuki has introduced.
Enjoy!
ceemes
Real Name: a big secret
Unread post by ceemes » Fri Jun 21, 2013 6:04 pm
We really need a "meh" option for bikes like this.....guess I will just give it a cool.
BRUMBEAR
Real Name: Dave
Years Riding: 40
Unread post by BRUMBEAR » Fri Jun 21, 2013 6:35 pm
I gave it a cool cause there is no Meh option as well, good idea Ceemes!! With a single disc and 5 speed trans the only thing thats appealing to me is that it looks OK. I have no problem with an 800cc motor thats ok by me and shaft is cool so Meh!!
there aint nothin like it
HYPERR
Unread post by HYPERR » Fri Jun 21, 2013 7:10 pm
ceemes wrote:We really need a "meh" option for bikes like this.....guess I will just give it a cool.
Wow ceemes gives a cruiser a cool rating? :shock:
Unread post by totalmotorcycle » Fri Jun 21, 2013 8:24 pm
I'll have to record that down for the record books! :laughing:
Gummiente
Years Riding: 35
My Motorcycle: '15 HD Road Glide
Unread post by Gummiente » Sat Jun 22, 2013 4:59 am
This one gets an "uncool" from me. It is nothing more than an existing cruiser tarted up with a blackout scheme... nothing new here, move along, folks. Monochromatic bikes just don't do it for me; when the finish on the parts fades (and they will fade) it almost always results in different shades between the plastic and metal parts. If one wants to spiff it up again by buying new parts, the cost is prohibitive... these are, after all, "special editions" with a corresponding limited run of spares.
:canada: Mike :gummiente:
'15 Road Glide
"If loud pipes really did save lives, imagine what you
could accomplish if you learned how to ride that thing"
montanalifter
Real Name: Bill
Unread post by montanalifter » Sat Jun 22, 2013 7:40 pm
I bet this bike does well for Suzuki. Lower price point, looks good.
Grey Thumper
Real Name: Dino
Unread post by Grey Thumper » Sat Jun 22, 2013 10:47 pm
I'm undecided if you'll look really silly wearing Hi Viz gear on a bike like this, or will Hi Viz gear will be an absolute necessity?
ceemes
Unread post by ceemes » Sun Jun 23, 2013 7:25 am
oi you two. Do a wee bit of research and you will find I started a thread where I waxed poetically on the sheer sexual beauty of the early Suzuki Boulevard M90. and where is our raspberry emotes????? oh well...... So :P to you. :D
HYPERR
Unread post by HYPERR » Sun Jun 23, 2013 9:06 pm
:nyah:
Years Riding: 11
Unread post by blues2cruise » Sun Jun 23, 2013 9:40 pm
It's exactly the style I love. And at 800cc.....it could be a first bike that last a long time.
Shaft drive is nice to have. I never had a problem with rear drum on my first bike so I don't see why it should be a problem here.
The materials used in today's systems are better than the old days and should present no problems. Since this isn't designed to "race", the drum on the back should be fine.
Shriker
Years Riding: 37
My Motorcycle: '13 VMax,'98 VTR1000F, '87 XT350
Unread post by Shriker » Mon Jun 24, 2013 1:56 pm
I too think we need a "meh" or middle of the road vote , neither cool or uncool.
Its a nice enough cruiser in a good size and looks nice enough etc. etc. It ONLY real pop factor is the all black look which these days is very common. I went uncool only because it seems like a really easy safe choice .....anything cool or better has to have something that is a bit more exiting or unique.
jstark47
Unread post by jstark47 » Mon Jun 24, 2013 10:23 pm
A late and lame attempt by Suzuki to hop on the blacked-out look bandwagon with minimal investment. Kind of a yawner, I agree with others, we really need a "meh" vote. It's a stretch to call this a "new" bike, it's just a cosmetic variation on an existing bike. HD does this kind of thing much better. I know the 805cc Suzuki mill, used to have a Marauder, that engine's kind of a yawner, too.
Uncool.
Unread post by totalmotorcycle » Thu Jun 27, 2013 6:53 pm
ceemes wrote: oi you two. Do a wee bit of research and you will find I started a thread where I waxed poetically on the sheer sexual beauty of the early Suzuki Boulevard M90. and where is our raspberry emotes????? oh well...... So :P to you. :D
Love it! :D
Unread post by totalmotorcycle » Thu Jun 27, 2013 6:56 pm
As for the bike I agree, it's sort of a "meh" vote isn't it? I think it's mostly the all blacked out look and the bike it just too bulky to pull it off with style. Seems more of a black wall of boringness that is screaming for some, any, color accents!
But it does get you in cheap (or I so assume) and a 800cc engine is really awesome, but I'm very uncool on the 611lb weight! (ouch for a 800cc).
I like it but dislike it a little more, so I'll go on the slight side of uncool. Still, it's a bike, and I'm sure some riders will love it, I just won't be the one drooling over it.
NorthernPete
Years Riding: 11
My Motorcycle: 1982 Yamaha sr250
Unread post by NorthernPete » Fri Jun 28, 2013 3:44 am
Cool. But forgettable. Two big Mehs up. Lol
1982 sr250
Unread post by sunshine229 » Fri Jun 28, 2013 8:24 am
I am not a cruiser person but I can still be impartial and vote a cruiser for how I feel about it overall, not how I feel about it for myself. Although I have voted other cruisers as awesome or cool in the past, I gave this one an uncool. I just don't find it appealing - wwwwaaaaayyyy too much black, front fender is way too thick, the passenger "pad" looks incredibly goofy and uncomfortable. Sorry guys, this bike is not just Meh but uncool.
Unread post by totalmotorcycle » Fri Jun 28, 2013 8:29 am
Thanks for everyone getting in their votes so far on this new 2014 Suzuki cruiser. Suzuki, always pushing the limits seemingly have pushed the limits of "blacked out" just a little too far with the new C50 BOSS. Will it be nicer looking in real life or even a bigger dud? Suzuki, we know you can do better!
Your Coolness Factor of the 2014 Suzuki Boulevard C50 BOSS is 52.3%
Awesome (3 points) 17% [ 6 ]
Cool (2 points) 34% [ 12 ]
Uncool (1 point) 37% [ 13 ]
Fail (0 point) 11% [ 4 ]
Total votes : 35
Next bike is now up for voting on, have fun!!
storysunfolding
Years Riding: 22
Re: Suzuki Boulevard C50 BOSS: Coolness Factor = 52.3%
Unread post by storysunfolding » Fri Jun 28, 2013 11:11 am
I didn't see this until now. No regrets for not voting :lol:
My Blog
Grasp life by the handlebars
Users browsing this forum: ceemes, Majestic-12 [Bot], markdcoco, montanalifter and 194 guests
cron
