2014 Victory High-Ball - Coolness Factor = 53.7%
Posted: Fri Aug 02, 2013 5:08 am
2014 Victory High-Ball on the Total Motorcycle Cool Wall
For A LOT MORE photos and information click here: http://www.totalmotorcycle.com/motorcyc ... h-Ball.htm
The ultimate bare-bones badass bobber...
Among custom cruiser motorcycles, nothing touches the Victory High-Ball. This cruiser with custom wheels, bobbed fenders and ape hangers brings out an attitude that can't be matched.
2014 Victory High-Ball Total Motorcycle Key Features
• APE HANGER HANDLEBARS
• 16” WHEELS WITH WHITEWALL TIRES
• SHORT FRONT FENDER
• 106 CUBIC-INCH FREEDOM® V-TWIN
• 110 FT-LBS OF TORQUE
• 6-SPEED OVERDRIVE TRANSMISSION
2014 Victory High-Ball - Total Motorcycle Specifications/Technical Details
US MSRP Price: $13,499
Canada MSRP Price: $14,899 CDN
Engine
Battery 12 volts / 18 amp hours
Bore x Stroke 101 x 108 mm
Charging System 38 amps max output
Clutch Wet, multi-plate
Compression Ratio 9.4 : 1
Cooling System Air / oil
Displacement 106 ci / 1731 cc
Engine Type 4-stroke 50° V-Twin
Exhaust Staggered slash-cut dual exhaust with crossover
Final Drive Carbon Fiber Reinforced Belt
Fuel Capacity 4.5 gal / 17.0 ltr
Oil Capacity 5.0 qts / 4.73 ltr
Primary Drive Gear drive with torque compensator Transmission 6-speed overdrive constant mesh Valve Train Single overhead camshafts with 4 valves per cylinder, self-adjusting cam chains, hydraulic lifters
Suspension (Totalmotorcycle.com)
Front Suspension Conventional telescopic fork, 43 mm diameter, 5.1 in / 130 mm travel
Rear Suspension Single, mono-tube gas, cast aluminum with rising rate linkage, 3.0 in / 75 mm travel, preload adjustable spring
Chassis (Totalmotorcycle.com)
Dry Weight 659 lbs / 300 kg
Ground Clearance 4.7 in / 120 mm
GVWR 1151 lbs / 523 kg
Length 93.4 in / 2372 mm
Rake/trail 32° / 6.7 in / 170 mm
Seat Height 25.0 in / 635 mm
Wheelbase 64.8 in / 1647 mm
Brakes
Brake System Type Conventional
Front braking system 300mm floating rotor with 4-piston caliper
Rear braking system 300mm floating rotor with 2-piston caliper
Wheels & Tires
Front Tire Metzeler ME880 Front Wheel 16 x 3.5 in
Rear Tire Metzeler ME880 Rear Wheel 16 x 3.5 in
Colors (Totalmotorcycle.com)
Suede Black with Graphics
Suede Black with Flames
Engine
Brakes
Wheels & Tires
