2014 Ducati Superbike 899 Panigale - Coolness Factor = 83.3%
Your Coolness Factor of the 2014 Ducati Superbike 899 Panigale is:
View results
Unread post by totalmotorcycle » Fri Sep 27, 2013 1:37 pm
2014 Ducati Superbike 899 Panigale on the Total Motorcycle Cool Wall
For A LOT MORE photos and information click here: http://www.totalmotorcycle.com/motorcyc ... nigale.htm
2014 Ducati Superbike 899 Panigale on Totalmotorcycle.com
The new 899 Panigale – Supermid perfection...
The introduction of the highly-anticipated Ducati 899 Panigale provides a new way to access the exclusive world of Ducati Superbikes with a “Supermid” version designed to provide the thrill of the new generation flagship model with the refined character of an everyday streetbike.
The brand new Superquadro engine features a revised bore and stroke for a broad power delivery, producing 148hp (109kW) with a torque of 73lb-ft (10.1kgm). The super-smooth power unit continues to be a fully stressed member of the innovative Panigale monocoque construction, achieving both an outstanding power-to-weight ratio and ride-enhancing agility with a dry weight of 169kg (372.5lb). An 1199 silhouette underlines the family DNA, while the Ducati Quick Shift (DQS) and the fully integrated Riding Mode technologies of Ride-by-Wire, triple stage ABS, Ducati Traction Control (DTC) and Engine Brake Control (EBC) continue the benchmark ingenuity introduced with the award-winning Panigale.
Ducati’s constant pursuit of perfection now offers all-round performance for connoisseurs with an authentic and stylish way to enter the world of high performance. The 899 Panigale is available in traditional Ducati red with black wheels or a stunning arctic white silk with red wheels.
The best of both worlds
2014 Ducati Superbike 899 Panigale - Totalmotorcycle.com Specifications/Technical Details
MSRP Price: See dealer for pricing
Engine
Type Superquadro: L-twin cylinder, 4 valve per cylinder,
Desmodromic, liquid cooled
Displacement 898cc
Bore x Stroke 100 x 57.2mm
Compression Ratio 12.5:1
Power 148hp (109kw) @ 10,750rpm
Torque 73lb-ft (99Nm) @ 9,000rpm
Fuel injection
Mitsubishi electronic fuel injection system.
Single injector per cylinder.
Full ride-by-wire elliptical throttle bodies.
Totalmotorcycle.com
Exhaust 2-1-2 system with catalytic converter and 2 lambda probes.
Twin stainless steel mufflers with alumimum outer sleeves
Emissions Euro 3
Transmission
Gearbox 6 speed
Ratio 1=37/15 2=30/16 3=27/18 4=25/20 5=24/22 6=23/24
Primary drive Straight cut gears, Ratio 1.77:1
Final drive Chain 520; Front sprocket 15; Rear sprocket 44
Clutch Wet multiplate clutch with hydraulic control
Chassis
Frame Monocoque aluminum
Wheelbase 1,426mm (56.14in)
Rake 24°
Trail 96mm (3.78in)
Steering angle (total) 52°
Front suspension Showa BFP 43mm fully adjustable usd fork
Front wheel travel 120mm (4.72in)
Front wheel 10-spoke light alloy 3.50" x 17"
Totalmotorcycle.com
Front tyre 120/70 ZR17 Pirelli Diablo Rosso Corsa
Rear suspension
Fully adjustable Sachs unit.
Progressive linkage
Cast aluminum double-sided swingarm.
Rear wheel travel 130mm (5.12in)
Rear wheel 10 spoke light alloy 5.50" x 17"
Rear tyre 180/60 ZR17 Pirelli Diablo Rosso Corsa
Front brake 2 x 320mm semi-floating discs, radially mounted Brembo
Monobloc M4-32 callipers with ABS
Rear brake 245mm disc, 2-piston calliper
Fuel tank capacity 17l (4.5 gallon US)
Dry weight 169kg (372.5lb)
*Wet weight 193kg (425.5lb)
Seat height 830mm (32.48in)
Max height 1100mm (43.31in)
Max length 2075mm (81.69in)
Totalmotorcycle.com
Instrumentation LCD
Ducati electronics DTC, DQS, EBC, Riding Modes
Warranty 2 years unlimited mileage
Versions Dual seat
2017 Motorcycle Model Guides
2016 Motorcycle Model Guides
Re: This week: 2014 Ducati Superbike 899 Panigale: Vote Toda
Unread post by totalmotorcycle » Fri Sep 27, 2013 1:38 pm
The very first 2014 Ducati out of the gate is the brand new, 2014 Ducati Superbike 899 Panigale!
Good, bad or ugly? You decide. Ducati is listening.
BRUMBEAR
Real Name: Dave
Years Riding: 40
Unread post by BRUMBEAR » Fri Sep 27, 2013 6:47 pm
Dead sexy in every way!!!!!!!!
there aint nothin like it
pchast
Years Riding: 5
My Motorcycle: 1980 Suzuki GS550L
Unread post by pchast » Fri Sep 27, 2013 10:14 pm
Not for me.
'80 Suzuki GS550L
Grey Thumper
Real Name: Dino
Unread post by Grey Thumper » Sat Sep 28, 2013 12:05 am
Fail.
Kidding. What's the point of posting a bike as inarguably cool as this one? It's
Unread post by totalmotorcycle » Sat Sep 28, 2013 3:26 pm
I went with: Awesome
373lbs, 148hp, Ducati red and swoopy styling... that's pretty well puts it in my awesome book. This bike would sure move on a WOT. But not sure about the riding position or the seat padding. Most likely a real track bike vs a road bike, but if you can afford it, then why not? Even if it just sits (for shame) in your living room.
Unread post by dr_bar » Sat Sep 28, 2013 7:36 pm
Where's the "meh" button...???
Just kidding voted cool...
ZRex
Real Name: Ben
My Motorcycle: 2002 Kawasaki ZRX1200R
Unread post by ZRex » Mon Sep 30, 2013 7:49 am
Awesome, one of the best looking and best handling sport bikes ever.
RhadamYgg
Unread post by RhadamYgg » Wed Oct 02, 2013 8:47 pm
It looks cool. Not sure if I would want to do a SS1000 on it, though. But if someone gave it to me and said "Ride it on weekends whenever you feel like it." I'd say yes.
Then I'd remember I have 4 kids and no time on weekends to ride it anyway.
Unread post by Johnj » Wed Oct 02, 2013 9:20 pm
Dude you're back. How's life treating you?
HYPERR
Unread post by HYPERR » Thu Oct 03, 2013 8:13 am
Yeah welcome back RY! :motorcycle:
RhadamYgg
Unread post by RhadamYgg » Thu Oct 03, 2013 10:46 pm
Johnj wrote:Dude you're back. How's life treating you?
HYPERR wrote:Yeah welcome back RY! :motorcycle:
Hey guys, good to be back.
Life is treating me - Eh, not so bad. Mentally dying a bit every day since I have ridden my bike in probably over a year. A little bit due to gaining more than a little bit of weight and not wanting to admit it and buy new riding pants... and jacket - and a little bit due to being in a different house with a hard to access garage and it is a PITA to use the bike. Now I have a bit of fear of getting back on the bike since I haven't ridden in so long. But hey, it is winter and I'm fat and cushy now and wouldn't want to get too cold riding out in the winter.
Other than that, ok. Kids are growing like bananas and all four are in full day school (twins are 4.5 years old now and in full day pre-K). Got to looking at a used motorbike site and drooling over bikes I don't have. Then had the realization that I don't ride the one I have now, got depressed and headed over here. ;) Not that Total Motorcycle is depressing, but it is a good place to chat about bikes.
How are you guys?
Unread post by Johnj » Fri Oct 04, 2013 12:44 am
Same old grind here. Work, work and more work. Still riding the Buell or the Connie. I bought a second house last year as a garage, it's right across the street, and cheaper then building one. I started going to a gym 3 times a week, turning the fat into muscle.
BRUMBEAR
Real Name: Dave
Years Riding: 40
Unread post by BRUMBEAR » Fri Oct 04, 2013 6:55 am
Hey was wondering where you went!! I am still 40 miles north of Rahway and I am still FAT as well hey if it's are only major vice I'll get over it :D Glad your still with us and doing ok.
Re: 2014 Ducati Superbike 899 Panigale - Coolness Factor = 8
Unread post by totalmotorcycle » Fri Oct 11, 2013 11:55 am
Awesome (3 points) 61% [ 28 ]
Cool (2 points) 33% [ 15 ]
Uncool (1 point) 2% [ 1 ]
Fail (0 point) 4% [ 2 ]
Total votes : 46
= a Coolwall Factor of 83.3%
NOTES: We have a tie for 1st place on our cool wall thanks to Ducati's new 899 Panigale with a vote of 83.3%! (Tied with 2013 Moto Guzzi Griso 1200 8V SE). Will the Ducati and Moto Guzzi last as our #1 bikes of 2013 or will a bike between now and December 31st become the new King of Cool?
Next bike is now up for voting on, have fun!!
RhadamYgg
Unread post by RhadamYgg » Wed Oct 23, 2013 8:55 pm
Johnj wrote:Same old grind here. Work, work and more work. Still riding the Buell or the Connie. I bought a second house last year as a garage, it's right across the street, and cheaper then building one. I started going to a gym 3 times a week, turning the fat into muscle.
My commute has gotten worse. I'm doing the job search thing. I want something close so I can get a second bike, if I manage to have the time to ride the first one!
RhadamYgg
Unread post by RhadamYgg » Wed Oct 23, 2013 8:57 pm
BRUMBEAR wrote:Hey was wondering where you went!! I am still 40 miles north of Rahway and I am still FAT as well hey if it's are only major vice I'll get over it :D Glad your still with us and doing ok.
Yep, still ticking. I gained a bunch of weight and got an award - high blood pressure. Sometime when I actually get time to ride we could get together! Traffic has gotten so bad that I stopped riding the bike to work. I guess the economy has recovered - at least mostly!
jstark47
Unread post by jstark47 » Thu Oct 24, 2013 8:25 pm
RhadamYgg wrote:Traffic has gotten so bad that I stopped riding the bike to work. I guess the economy has recovered - at least mostly!
That's why I try to get up and out early, be at my office by 7:30 am. That means I leave by 6:30-6:45, it's 31 miles. If I get out early enough, it's not too crazy and reasonable for the bike. Wait until 8am and traffic is very nutz.
Users browsing this forum: ceemes, markdcoco, montanalifter, totalmotorcycle, ZRex and 118 guests
cron
