2014 Ducati Superbike 899 Panigale - Coolness Factor = 83.3%
Your Coolness Factor of the 2014 Ducati Superbike 899 Panigale is:
34
63%
16
30%
2
4%
2
4%
Total votes: 54
Years Riding: 32
2014 Ducati Superbike 899 Panigale on the Total Motorcycle Cool Wall
For A LOT MORE photos and information click here: http://www.totalmotorcycle.com/motorcyc ... nigale.htm
2014 Ducati Superbike 899 Panigale on Totalmotorcycle.com
The new 899 Panigale – Supermid perfection...
The introduction of the highly-anticipated Ducati 899 Panigale provides a new way to access the exclusive world of Ducati Superbikes with a “Supermid” version designed to provide the thrill of the new generation flagship model with the refined character of an everyday streetbike.
The brand new Superquadro engine features a revised bore and stroke for a broad power delivery, producing 148hp (109kW) with a torque of 73lb-ft (10.1kgm). The super-smooth power unit continues to be a fully stressed member of the innovative Panigale monocoque construction, achieving both an outstanding power-to-weight ratio and ride-enhancing agility with a dry weight of 169kg (372.5lb). An 1199 silhouette underlines the family DNA, while the Ducati Quick Shift (DQS) and the fully integrated Riding Mode technologies of Ride-by-Wire, triple stage ABS, Ducati Traction Control (DTC) and Engine Brake Control (EBC) continue the benchmark ingenuity introduced with the award-winning Panigale.
Ducati’s constant pursuit of perfection now offers all-round performance for connoisseurs with an authentic and stylish way to enter the world of high performance. The 899 Panigale is available in traditional Ducati red with black wheels or a stunning arctic white silk with red wheels.
The best of both worlds
2014 Ducati Superbike 899 Panigale - Totalmotorcycle.com Specifications/Technical Details
MSRP Price: See dealer for pricing
Engine
Type Superquadro: L-twin cylinder, 4 valve per cylinder,
Desmodromic, liquid cooled
Displacement 898cc
Bore x Stroke 100 x 57.2mm
Compression Ratio 12.5:1
Power 148hp (109kw) @ 10,750rpm
Torque 73lb-ft (99Nm) @ 9,000rpm
Fuel injection
Mitsubishi electronic fuel injection system.
Single injector per cylinder.
Full ride-by-wire elliptical throttle bodies.
Totalmotorcycle.com
Exhaust 2-1-2 system with catalytic converter and 2 lambda probes.
Twin stainless steel mufflers with alumimum outer sleeves
Emissions Euro 3
Transmission
Gearbox 6 speed
Ratio 1=37/15 2=30/16 3=27/18 4=25/20 5=24/22 6=23/24
Primary drive Straight cut gears, Ratio 1.77:1
Final drive Chain 520; Front sprocket 15; Rear sprocket 44
Clutch Wet multiplate clutch with hydraulic control
Chassis
Frame Monocoque aluminum
Wheelbase 1,426mm (56.14in)
Rake 24°
Trail 96mm (3.78in)
Steering angle (total) 52°
Front suspension Showa BFP 43mm fully adjustable usd fork
Front wheel travel 120mm (4.72in)
Front wheel 10-spoke light alloy 3.50" x 17"
Totalmotorcycle.com
Front tyre 120/70 ZR17 Pirelli Diablo Rosso Corsa
Rear suspension
Fully adjustable Sachs unit.
Progressive linkage
Cast aluminum double-sided swingarm.
Rear wheel travel 130mm (5.12in)
Rear wheel 10 spoke light alloy 5.50" x 17"
Rear tyre 180/60 ZR17 Pirelli Diablo Rosso Corsa
Front brake 2 x 320mm semi-floating discs, radially mounted Brembo
Monobloc M4-32 callipers with ABS
Rear brake 245mm disc, 2-piston calliper
Fuel tank capacity 17l (4.5 gallon US)
Dry weight 169kg (372.5lb)
*Wet weight 193kg (425.5lb)
Seat height 830mm (32.48in)
Max height 1100mm (43.31in)
Max length 2075mm (81.69in)
Totalmotorcycle.com
Instrumentation LCD
Ducati electronics DTC, DQS, EBC, Riding Modes
Warranty 2 years unlimited mileage
Versions Dual seat
2023 Motorcycle Model Guides
Years Riding: 32
Re: This week: 2014 Ducati Superbike 899 Panigale: Vote Toda
The very first 2014 Ducati out of the gate is the brand new, 2014 Ducati Superbike 899 Panigale!
Good, bad or ugly? You decide. Ducati is listening.
BRUMBEAR
Real Name: Dave
Years Riding: 40
#3 Unread post by BRUMBEAR »
Dead sexy in every way!!!!!!!!
there aint nothin like it
pchast
#4 Unread post by pchast »
Not for me.
Grey Thumper
Real Name: Dino
#5 Unread post by Grey Thumper »
Fail.
Kidding. What's the point of posting a bike as inarguably cool as this one? It's
Years Riding: 32
I went with: Awesome
373lbs, 148hp, Ducati red and swoopy styling... that's pretty well puts it in my awesome book. This bike would sure move on a WOT. But not sure about the riding position or the seat padding. Most likely a real track bike vs a road bike, but if you can afford it, then why not? Even if it just sits (for shame) in your living room.
#7 Unread post by dr_bar »
Where's the "meh" button...???
Just kidding voted cool...
ZRex
Real Name: Ben
#8 Unread post by ZRex »
Awesome, one of the best looking and best handling sport bikes ever.
RhadamYgg
#9 Unread post by RhadamYgg »
It looks cool. Not sure if I would want to do a SS1000 on it, though. But if someone gave it to me and said "Ride it on weekends whenever you feel like it." I'd say yes.
Then I'd remember I have 4 kids and no time on weekends to ride it anyway.
#10 Unread post by Johnj »
Dude you're back. How's life treating you?
