2014 Triumph Daytona 675 ABS - Coolness Factor = 82.35%
Posted: Sat Mar 01, 2014 6:05 am
2014 Triumph Daytona 675 ABS on the Total Motorcycle Cool Wall
For A LOT MORE photos and information click here: http://www.totalmotorcycle.com/motorcyc ... 75-ABS.htm
For The Ride...
Apex after apex the new Daytona 675 inspires complete confidence. More power, lighter weight, and easier to ride, our engineers ambition was simple: to create the most perfectly balanced motorcycle. An equal blend of torque, responsiveness, agility, poise and purpose. The result is a bike with class-defining power, performance and handling. A bike that will inspire total confidence. And looks every bit as good.
The engine is brand new featuring twin injectors per cylinder, titanium valves, a 14,400 red line, and a spine tingling induction roar. It's faster on the track, better on the road and even more satisfying to own.
With twin injectors per cylinder the new Daytona can draw more fuel quicker when you open the throttle fully and demand more from the engine.
A first for a production Triumph, we have now fitted substantially lighter titanium valves to cope better with the higher revs. This also means lighter valve springs can be used, reducing valve train wear and friction.
2014 Triumph Daytona 675 ABS - http://www.Totalmotorcycle.com International Specifications/Technical Details
US MSRP Price: $11,599 USD
Canada MSRP Price: $12,599 CDN
UK/European MSRP Price: 9,249.00 (VAT Included)
Engine and Transmission
typeLiquid-cooled, 12 valve, DOHC, in-line 3-cylinder capacity675cc
bore76mm
stroke49.6mm
systemMultipoint (http://www.Totalmotorcycle.com) sequential electronic fuel injection with SAI
exhaustStainless steel 3 into 1 exhaust system low single sided stainless steel silencer
final driveO ring chain
clutchWet, multi-plate, slipper
gearbox6-speed, close ratio
oil capacity1US Gallon
Chassis Running Gear and Displays http://www.Totalmotorcycle.com
frameFront - Aluminium beam twin spar. Rear - 2 piece high pressure die cast
swingarmBraced, twin-sided, aluminium alloy with adjustable pivot position
Front WheelsCast aluminium alloy 5-spoke 17 x 3.5in
Rear WheelsCast aluminium alloy 5-spoke 17 x 5.5in
Front Tires120/70 ZR 17
Rear Tires180/55 ZR 17
Front SuspensionKYB 41mm upside down forks with adjustable preload, rebound and compression damping, 115mm travel
Rear SuspensionKYB monoshock with piggy back reservoir adjustable for rebound and compression damping, 135mm rear wheel travel
brakes frontTwin 308mm floating discs. Nissin 4-piston radial calipers.(Switchable ABS model available)
brakes rearSingle 220mm disc, Brembo single piston caliper. (Switchable ABS model available)
Dimensions and Capacities
length2045mm
width handlebars695
height without mirror (http://www.Totalmotorcycle.com) 1112mm
seat height820mm
wheelbase1375mm
rake22.9º
trail87.2mm
tank capacity4.6us gallon
wet weight184 kilo
http://www.Totalmotorcycle.com Performance
max power ec128PS @ 12500
max torque ec74NM @ 11900
For The Ride...
bore76mm
stroke49.6mm
length2045mm
width handlebars695
seat height820mm
wheelbase1375mm
rake22.9º
trail87.2mm
wet weight184 kilo
