2014 Aprilia RSV4 Factory APRC - Coolness Factor = 70.0%
Your Coolness Factor of the 2014 Aprilia RSV4 Factory APRC is:
View results
Years Riding: 32
2014 Aprilia RSV4 Factory APRC on the Total Motorcycle Cool Wall
For MORE photos and information click here: http://www.totalmotorcycle.com/motorcyc ... y-APRC.htm
WINNING IDENTITY...
Right from the start, the Aprilia RSV4 Factory set the benchmark in the supersport category and has evolved year after year without losing any of the extraordinary dynamic balance which helped it win five WSBK titles.
FROM ITS SUCCESS IN SBK, WHERE THE RSV4 WON 5 WORLD TITLES IN ONLY 4 YEARS, APRILIA IS PROUD TO INTRODUCE THE NEW RSV4 RANGE, THE MAXIMUM EXPRESSION OF TECHNOLOGY APPLIED TO A SUPERSPORT BIKE.
A TRUE LEGEND IN ITS SEGMENT WHICH, FROM THE TIME IT APPEARED ON THE SCENE, HAS DOMINATED THE WORLD SBK TRACKS AS WELL AS SPECIALISED PRESS COMPARATIVE TRACK TESTING.
NO ONE HAS BEEN ABLE TO KNOCK IT FROM THE TOP STEP OF THE PODIUM AND NOW IT WILL BE EVEN MORE DIFFICULT: THE TWO NEW RSV4 VERSIONS, R ABS AND FACTORY ABS, ARE THE FASTEST, MOST POWERFUL AND SAFEST RSV4 UNITS EVER BUILT.
NEW EXTREMELY ADVANCED BRAKING SYSTEM WITH MULTIMAP ABS (WHICH CAN BE DISENGAGED), POWER INCREASED TO 184 HP, HIGHLY REFINED ADVANCED aPRC: APRILIA RSV4 R ABS AND FACTORY ABS CONFIRM THEIR POSITION AS THE TOP DOGS IN THE SECTOR.
From the time it appeared on the scene, it was clear to all its rivals that the Aprilia RSV4 was the bike to beat.
Unmistakeable in its design lucidity and applied technology, the RSV4 is conceived around a 65° V4 engine never before seen on a factory sport bike, a frame which is the heir to a dynasty that has won 18 titles and 143 Grand Prix races in the 250 GP class, enhanced by the most advanced applied electronics systems to manage the engine and the bike's dynamic performance. This is a true vocation of Aprilia, which was the first manufacturer to adopt the Ride-By-Wire system as standard equipment (the multimap power management system), but above all the first to patent the aPRC dynamic control system, still today the only one with the exclusive self-calibration and wheelie control features.
This technological first is consolidated today with the new RSV4 ABS range: Aprilia RSV4 R ABS and Factory ABS are the models which, for the quantity and quality of new content and improvements, undoubtedly represent the most important advancements ever made on this extraordinary model.
From day one, the RSV4 Factory has been the benchmark in the supersport bike category. Year after year it has evolved without losing any of the incredible dynamic balance which took it to five WSBK titles, and, in 2012 to be nominated winner in a comparison of all sports bikes organised by the best known motorcycle magazines in the world. The ABS on the Aprilia RSV4 Factory signals yet another stage in the evolution of a dynasty of winning bikes. The aim was to improve on the previous version which was already seen as the absolute best and to consolidate the use of well proven technology. Better performance with better safety too. The Aprilia RSV4 Factory ABS becomes not only more powerful but also more ergonomic, stable and better under braking. It is also safer on the track and in road use thanks to the adoption of an exceptional new braking system fitted with multi-map ABS that can be adjusted or even disabled on the move.
2014 Aprilia RSV4 Factory APRC - http://www.Totalmotorcycle.com USA Specifications/Technical Details
US MSRP Price: $20,499 USD
Canada MSRP Price: $20,795 CDN
ENGINE
Type Aprilia V4 longitudinal 65°, 4-strokes, liquid cooling system, double overhead camshaft (DOHC), four valves per cylinder
Capacity 999.6 cc
Max power (at crankshaft) 184 hp (135,3 kW) at 12.500 rpm
Max torque (at crankshaft) 86.2 lb-ft 117 Nm at 10.000 rpm
Fuel system Airbox with front dynamic air intakes. Variable length intake ducts controlled via ECU. 4 Weber-Marelli Ø48-mm throttle bodies with 8 injectors and latest generation Ride-by-Wire engine management. Choice of three different engine maps selectable by the rider with bike in motion: T (Track), S (Sport), R (Road)
Exhaust system 4 into 2 into 1 layout, single oxygen sensor, lateral single silencer with engine control unit-controlled butterfly valve and integrated trivalent catalytic converter.
TRANSMISSION
Gearbox 6-speed cassette type gearbox
Lubrication Wet sump lubrication system with oil radiator and two oil pumps (lubrication and cooling)
Clutch Multiplate wet clutch with mechanical slipper system. http://www.Totalmotorcycle.com Gear lever with Aprilia Quick Shift electronic system 'AQS'
Traction management APRC System 'Aprilia Performance Ride Control', which includes Traction Control (ATC), Wheelie Control (AWC), Launch Control (ALC), all of which can be configured and deactivated independently through the race display.
CHASSIS / SUSPENSION / BRAKES
Frame Aluminium dual beam chassis with pressed and cast sheet elements.
Front suspension Öhlins adjustable steering damper.
Ø43mm Öhlins upside down units fully adjustable (Tin). Wheel travel: 120 mm
Rear suspension Aluminum alloy swingarm. ÖHLINS piggyback shock absorber with adjustable spring preload, compression, rebound damping and length. Wheel travel: 130 mm
Front brake Double Ø320mm lightweight stainless steel floating discs. http://www.Totalmotorcycle.com New M430 Brembo monobloc radial calipers with 4 opposed Ø30 mm pistons. Sintered pads. New radial master cylinder. Metal braided brake line.
Rear brake Ø220 mm disc. New Brembo floating caliper with 2 insulated Ø 32 mm pistons. Sintered pads. Master cylinder with integral reservoir. Metal braided brake line
ABS Multi-map Bosch 9MP ABS (3 maps selectable), deactivable and with RLM (Rear wheel Lift-up Mitigation).
Wheels Aprilia forged aluminum alloy rims, completely machined, 5 split spokes. Front:3.5”X17” Rear: 6.00”X17”
Front tire Radial tubeless - 120/70 ZR 17
Rear tire Radial tubeless - 200/55 ZR 17 (homologated option 190/50 ZR 17; 190/55 ZR 17)
DIMENSIONS
Max. Length 80.3 in. (2040 mm)
Max. Width 29 in. (735 mm) at the handlebar
Max. Height 44 in. (1120 mm)
Seat height 33 in. (840 mm)
Dry weight 398 lbs (181 kg)
Fuel tank capacity 4.9 gal. (18,5 lt)
2023 Motorcycle Model Guides
BRUMBEAR
Real Name: Dave
Years Riding: 40
Re: This Week: 2014 Aprilia RSV4 Factory APRC - Vote Today
#2 Unread post by BRUMBEAR »
OOOOHHHH mannnnn if I could bend enough to get in that saddle :shock: I'll tell ya what that machine is just AWESOME!!!!!!!!! This is a RACE bike with lights I love it!!!!
there aint nothin like it
HYPERR
#3 Unread post by HYPERR »
A phenomenal bike but why does it have to be so fugly, lol??? Even with its mfugliness, the bike is so great that I give it a cool.
Mithrandir
Real Name: Anthony
My Motorcycle: None
#4 Unread post by Mithrandir »
For the right type of person, this MC can be oodles of fun. (Could also be a ticket magnet ;) )
Although I do not see myself riding this type of MC, it looks like it can be a blast to ride. Definitely cool. :cool: :motorcycle:
Grey Thumper
Real Name: Dino
#5 Unread post by Grey Thumper »
I'm not a supersport-type either, but that longitudinal V4 merits at least a cool!
Years Riding: 32
I voted: Awesome
If I owned a sportbike, I couldn't think of a better, higher quality, more prestigious one to own (MV Agusta would be up there with this as well). Just a wow factor that makes any Japanese sportbike drool over it. But then again, it's price also puts it out of the reach of most, but you get what you pay for here, no questions asked. One of the very cream-of-the-crop V4 engines ever produced... "RSV4 Factory has been the benchmark in the supersport bike category"
Ticket magnet? Most likely, but if you can afford the bike....
#7 Unread post by sunshine229 »
Aprilia sportsbike... nothing but awesome for me! Even at $20k I would still buy this bike if I were in the market for that kind of ride. :mrgreen:
Years Riding: 32
Featured: June 6th, 2014 - June 13th, 2014
Motorcycle Cool Wall discussion: viewtopic.php?f=61&t=49461
Total Motorcycle model page: http://www.totalmotorcycle.com/motorcyc ... y-APRC.htm
Awesome (3 points) 31% [ 10 ]
Cool (2 points) 63% [ 20 ]
Uncool (1 point) 3% [ 1 ]
Fail (0 point) 3% [ 1 ]
Total votes : 32
= a Coolwall Factor of 74.0%
NOTES: Cream of the superbike crop.
Next 2014 TMW Cool Wall bike is now up for voting on, have fun!!
ZRex
Real Name: Ben
Re: 2014 Aprilia RSV4 Factory APRC - Coolness Factor = 70.0%
#9 Unread post by ZRex »
I voted Awesome, I would love to own one of these.
