2015 Harley-Davidson FLRT Freewheeler - Coolness Factor= 40%
Posted: Fri Aug 29, 2014 6:10 am
2015 Harley-Davidson FLRT Freewheeler on the Total Motorcycle Cool Wall
For MORE information and Photos click here: http://www.totalmotorcycle.com/motorcyc ... heeler.htm
Hot rod-inspired style and a smaller, easy-handling size make the new Freewheeler™ model unlike any other trike on the road. Confidence comes instantly in this saddle...
Harley-Davidson puts hot-rod swagger on three wheels with the 2015 Freewheeler™ motorcycle, the all-new trike model that fuses pure custom style and easy-handling performance. From its ape-hanger handlebar to its bobtail fenders the Freewheeler is a page ripped straight from the bad- attitude handbook, offered in a size that’s shorter and lighter for a riding experience like nothing else on the road.
Riding on three wheels has never been cooler. The Freewheeler front end is all new and features a chrome, seven-piece nacelle that’s tucked tight to the forks and holds a Dual Halogen headlamp in a polished chrome bucket. A trim front fender tops a 19-inch Enforcer Cast Aluminum wheel with machined highlights. The all-new rear body shape gives the Freewheeler a low, lean profile and incorporates a weatherproof trunk designed to hold two full-face helmets. The top trunk door opens right-to-left for easy loading. Dual chrome mufflers with slash-down tips are inset in the bottom of the trunk. Bobtail fenders terminate in an arrogant flip to expose the rear tires, and incorporate bright LED stop/tail/turn lamps.
The Freewheeler puts more riders a comfortable, confident position. That 12-inch mini-ape handlebar offers the tallest rise available on any motorcycle to place the hand controls closer to rider and reduce steering effort. The seat is shaped to move the rider forward for a better reach to the foot and hand controls, with a passenger position designed for comfort while blending with the bodywork. Soft-touch passenger grab rails are easy to grip and mount directly to the body.
The Freewheeler is equipped with electronic cruise control, a foot-activated parking brake, electric reverse gear and a hydraulic Assist and Slip clutch with reduced lever effort. The linked brake system allows the rider to apply both the front and rear brakes through the rear brake pedal. The full front brake system is applied only through the front brake lever and remains independent. Built around a chassis engineered exclusively for a three-wheeled vehicle, the Freewheeler offers premium Harley-Davidson quality and performance, backed by a full factory warranty and the network of authorized Harley-Davidson dealers.
2015 Harley-Davidson FLRT Freewheeler - http://www.Totalmotorcycle.com American Specifications/Technical Details
USA MSRP Price: Vivid Black $24,999; Color Option $25,499 USD
Canada MSRP Price: Vivid Black $ 31,619; Color Option $ 32,229 CDN
DIMENSIONS
Length 103.1 in.
Seat Height, Laden 7 26.9 in.
Seat Height, Unladen 7 27.5 in.
Ground Clearance 4.9 in.
Rake (steering head) (deg) 26
Trail 3.96 in.
Wheelbase 66 in.
Tires, Front Specification http://www.Totalmotorcycle.com MT 130/60B19 M/C 61H
Tires, Rear Specification P205/65R15
Fuel Capacity 6 gal.
Oil Capacity (w/filter) 4 qt.
Weight, As Shipped 1,045 lb.
Weight, In Running Order 1,082 lb.
Luggage Capacity -Volume 2 cu ft
ENGINE
Engine 1 Air-cooled, High Output Twin Cam 103™ with integrated oil cooler
Bore 3.87 in.
Stroke 4.374 in.
Displacement 103.1 cu in
Compression Ratio 9.7:1
Fuel System 3 Electronic Sequential Port Fuel Injection http://www.Totalmotorcycle.com (ESPFI)
DRIVETRAIN
Primary Drive Chain, 34/46 ratio
Gear Ratios (overall) 1st 10.534
Gear Ratios (overall) 2nd 7.302
Gear Ratios (overall) 3rd 5.423
Gear Ratios (overall) 4th 4.392
Gear Ratios (overall) 5th 3.741
Gear Ratios (overall) 6th 3.157
CHASSIS
Exhaust New mufflers designed to fit within the new shorter Freewheeler body. http://www.Totalmotorcycle.com The slash down style chrome finish mufflers are ~3” shorter than current FL mufflers
Wheels, Front Type 9 Enforcer Cast Aluminum
Wheels, Rear Type Enforcer Cast Aluminum
Brakes, Caliper Type 6 Piston fixed front with 4-31.75 mm frontPistons and 2-25.4 mm linked rear pistons, 31.75mm single piston floating rear
Parking Brake Foot actuated dual parking brake
PERFORMANCE
Engine Torque Testing Method J1349
Engine Torque 2 104.7 ft-lb
Engine Torque (rpm) 3,250
Fuel Economy: Combined City/Hwy 5 39 mpg
DIMENSIONS
Length 103.1 in.
Trail 3.96 in.
Wheelbase 66 in.
ENGINE
Bore 3.87 in.
Stroke 4.374 in.
DRIVETRAIN
CHASSIS
PERFORMANCE
