2014 Moto Guzzi V7 Racer - Coolness Factor = 92.31%
Posted: Fri Sep 26, 2014 5:08 am
2014 Moto Guzzi V7 Racer on the Total Motorcycle Cool Wall
For MORE information and Photos click here: http://www.totalmotorcycle.com/motorcyc ... -Racer.htm
GENUINE GENTLEMAN RIDER...
Produced in a limited edition as revealed by the commemorative plate on the steering yoke, the V7 Racer is now in its third edition.
It is immediately recognisable: new total black look applied to the side panels, mirrors, silencer support brackets and foot-rest guards.
The result is a dramatic contrast with the shiny chromium-plated 22 litre fuel tank. Staying on the topic of numbers, on the top fairing and tail fairing plates is still the number "7" (which in Moto Guzzi was dear to the 250 world champion Enrico Lorenzetti), but is now chromium plated instead of white. Also new is the single-seater saddle (on request the two-seater saddle with passenger footrests is available) covered with alcantara and imitation leather of the same colour as the customised leather belt with the Moto Guzzi logo on the top of the fuel tank.
Always spectacular is the red frame based on that of the first V7 Sport series with CrMo frame, the result of a special painting process, also applied to the hubs, wheel and swingarm, which enhances the architectural purity of the frame. Also red is the Moto Guzzi wording which now appears on the wheels, exactly as already seen on the latest California Custom.
With its tiny Plexiglas screen above the race number plate, the tail and top fairing - an exemplary expression of the Guzzi school - whose shape resembles the front of the legendary Gambalunga, an unequivocally sporty element in perfect harmony with the design of the front mudguard. Among the most distinctive elements of this special edition is the ample use of brushed and perforated aluminium, superior craftsmanship which characterises the side panels, the throttle body guards and the silencer mounting brackets.
Other premium components include the aft-mounted footpegs machined from solid billets, the lightened steering stem and the steering yoke guard consisting of a double chromed ring, which is so exquisitely crafted that it looks like an ornamental feature.
Particularly satisfying, not only from an aesthetic point of view but also in terms of dynamic performance, is the presence of a pair of WMY01 Bitubo shock absorbers with adjustable spring preload, in extension and compression, thanks to a 12 click adjusting knob.
This is a bike to be ridden strictly alone, in black riding suit, with a skullcap helmet and studded-palm leather gloves.
The Moto Guzzi V7 Racers remains an homage in design to the café racer motorcycles of the 1950s and 1960s, combined with the modern features of an Italian-engineered motorcycle. Featuring a new and more powerful, 750cc, 90-degree V-Twin motor and new lightweight, six split spoke aluminum wheels, the V7 Racer brings together classic style and craftsmanship.
The completely reengineered 750cc engine still relies on the engineering that made the Moto Guzzi V50 a success among riders in 1977. Since then the engine has been continuously updated yet stays faithful to the original genial layout introduced by Italian engineer Lino Tonti in the 70s and stays true to the characteristics of the Moto Guzzi tradition, that touring on a motorcycle at its most pure should be nothing but enjoyable.
While maintaining the classic 90° V configuration, the engine is now comprised of more than 70% new components. Cutting-edge technological solutions have been used to improve functionality, provide greater torque and power even at low rpms, and be more efficient, with higher fuel economy and reduced emissions. The new engine is more powerful and stays true to the characteristics of the Moto Guzzi tradition, that touring on a motorcycle at its most pure should be nothing but enjoyable.
The new tank brings with it a superior metallic construction that allows for a lighter tank along with a greater fuel capacity – the V7 Racer can hold a record 5.8 gallons which, together with reduced consumption, ensures a range of up to 310 miles.
The distinctiveness of the V7 Racer design is sporty and attention-getting in all the right ways. A new chrome fuel tank finished with a studded leather strap, a single-saddle suede seat with an aerodynamic seat cowl and ‘70s-style racer number plates mean the added engine performance is showcased right along with classic style. One look, and a rider will know that the V7 Racer speaks for itself.
The Moto Guzzi V7 Racer, iconic and prestigiously manufactured in Italy, will be available in 2013 in U.S. dealerships.
As with all of Moto Guzzi’s on-road motorcycles, the V7 Racer comes with a two-year manufacturer’s warranty and roadside assistance for one year.
2014 Moto Guzzi V7 Racer Totalmotorcycle.com Key Features
V7 CHANGES EVERYTHING TO REMAIN FAITHFUL TO ITS LEGEND.
New engine, revamped design, brand new equipment: the legend of the V7 reaches its highest expression yet.
2014 Moto Guzzi V7 Racer - Totalmotorcycle.com USA Specifications/Technical Details
US MSRP Price: $10,490 USD
Canada MSRP Price: $10,490 CDN (SAME PRICE AS IN USA)
ENGINE
Type 90° V-twin 4-stroke
Capacity 744 cc
Maximum power 37 kW (50HP) at 6,200 rpm
Maximum torque 42.7 ft lbs. / 58Nm at 5,000 rpm
Fuel system Weber-Marelli electronic fuel injection.
Exhaust system Three-way catalytic converter with double lambda probe
TRANSMISSION
Gearbox 5 speeds with cardan final drive
Lubrication forced circulation with lobe pump - circuit capacity: 1.78 Kg
Final drive CA.R.C. Compact Reactive Shaft Drive
Clutch Dry single plate with flexible couplings
CHASSIS / SUSPENSION / BRAKES
Frame Double cradle tubular frame in ALS steel with detachable rear subframe
Front suspension Telescopic hydraulic fork with 40 mm stanchions
Rear suspension Light alloy swing arm with 2 fully adjustable Bitubo shock absorbers
Brake system Brembo
Front brake 320 mm Ø stainless steel disc, Brembo caliper with 4 differentiated pistons
Rear brake 260 mm stainless steel disc, brembo double piston floating caliper
Wheels Aluminium spoked black anodised rims
Front wheel 18", 100/90
Rear wheel 17", 130/80
DIMENSIONS
Length 86 inches - 2184mm
Max width 31.5 inches - 800mm
Height 43.8 inches - 1112mm
Saddle height 31.6 in. (30.7 in. opt.) - 805 mm (780 mm opt.)
Curb weight 395 pounds - 179 kg
Fuel tank capacity 5.8 gallons - 22 liters
Reserve 1 gallon - 4 liters
ENGINE
Capacity 744 cc
TRANSMISSION
Brake system Brembo
DIMENSIONS
