2015 URAL MIR - Coolness Factor = 72.7%
Posted: Fri Nov 07, 2014 6:33 am
2015 URAL MIR on the Total Motorcycle Cool Wall
For MORE information and Photos click here: http://www.totalmotorcycle.com/motorcyc ... AL-MIR.htm
“MIR” translates as “World” and “Peace”...
Each year we take inspiration from the world around us to create our limited edition series. We explore the places that are far beyond the reach of any ordinary motorcycle, we come up with the cleverest equipment to help you conquer the unknown and we throw in a little something to raise your neighbor’s brows.
This year we are taking you to the outer space – the place where 20 years ago a joint Russian-American space mission Shuttle-Mir began an era of unprecedented cooperation and explorations. No wonder we felt a little nostalgic about that spirit of friendship and bridging the differences. We thought what better namesake for our 2014 Limited Edition and thus we bring you Ural MIR!
MIR comes in a brilliant orbital white with fine metal flake and finished with blue pearl clear. The result is a glowing white Ural with hues of blue that shift with the light - a perfect paint job for your intergalactic mission.
2014 LE Ural MIR - the only motorcycle that comes with the solar panel, the wrench and the Lev Andropov’s problem solving method.
Total Built for US : 20
2015 URAL MIR - http://www.Totalmotorcycle.com USA Specifications/Technical Details
US MSRP Price: $16999 USD
Engine and Transmission
•Displacement, cc: 749
•Engine type: OHV air cooled 2 cylinder 4 stroke “boxer” (flat twin http://www.Totalmotorcycle.com)
•Valve per cylinder: 2
•Bore and stroke (mm x mm): 78 x 78
•Max output (hp): 41 @ 5500 rpm
•Max torque (ft-lbs): 42 @ 4300 rpm
•Compression: 8.6:1
•Fuel system: Throttle body EFI
•Starting: Electric & Kickstart
•Clutch Double-disc dry
•Transmission type: Manual
•Speeds: 4 forward 1 reverse
•Primary drive (rear wheel): Driveshaft
•Final drive ratio: 4.62
•Engageable sidecar wheel drive: Yes, driveshaft
Physical Measurements
•Overall length, inch.: 98.8
•Overall heights, inch.: 54.3
•Overall width, inch.: 63.6
•Seat height, (unladen), inch.: 32.0
•Ground clearance (unladen),inch.: 6.8
•Dry weight, lbs: 730
Chassis
•Front suspension: IMZ leading link fork
•Rear suspension: Double sided swing-arm with two Sachs hydraulic spring shock absorbers, 5x adjustable
•Sidecar suspension: Single sided swing-arm with http://www.Totalmotorcycle.com Sachs hydraulic spring shock absorber, 5x adjustable
•Wheels: 2.5X19 Aluminum rims with steel spokes
•Tires: Duro HF-308, 4.0×19?
•Front brake: 4-piston fixed Brembo caliper with 295mm floating NG rotor
•Rear brake: HB big bore single piston integrated floating caliper with 256mm fixed NG rotor
•Sidecar brake: 2-piston fixed Brembo caliper with 245mm floating NG rotor
•Compression: 8.6:1
Chassis
