2015 Victory Magnum - Coolness Factor = 40.4%
Your Coolness Factor of the 2015 Victory Magnum is:
View results
Unread post by totalmotorcycle » Fri Nov 28, 2014 1:54 pm
2015 Victory Magnum on the Total Motorcycle Cool Wall
For MORE information and Photos click here: http://www.totalmotorcycle.com/motorcyc ... Magnum.htm
2015 Victory Magnum on Totalmotorcycle.com
Over the top custom style that comes to you straight from the Victory factory...
Envy comes standard. Life goes fast – make a lasting impr ession on the new Victory Magnum, our boldest bike to ever roll off the line. This big wheel bagger has the performance to turn heads, along with the style and sound to make people stop, stare, and listen. It ’s got a 21-inch wheel, slammed back-end, custom paint, and our best performing sound system ever — EVER ! Even sitting still, the Victory Magnum is never idle. Wherever it goes, it can’t be ignored.
Building on the international success of the sector-leading Cross Country, Victory Motorcycles have indulged themselves with a mainstream production model like no manufacturer before, creating a factory-custom bagger for a new generation of riders.
The new Magnum redefines the bagger class with its winning combination of fast handling chassis geometry, the lowest seat height in its class, uncompromised cornering clearance, and continent-crossing comfort as standard.
Its tall but muscular 21-inch front wheel, buried deep within a stylised front fender, reinforces the Magnum's slammed stance and the new LED headlight system, shrouded in the already-iconic Cobra-Hood fairing is just about the only thing that is capable of eclipsing the high status detailing of the new King of the Street.
Powered by Victory Motorcycles thundering 106ci (1731cc) Freedom® Motor, the new Magnum offers riders mountains of torque and easily accessible power across the rev range, delivered through a slick six speed overdrive transmission.
Finished in one of four radical eye-popping graphic schemes with 100W of music blasting out from the most powerful in-dash audio system that Victory Motorcycles has ever fitted to a motorcycle, the Magnum is guaranteed to make an entrance!
2015 Victory Magnum - Totalmotorcycle.com USA Specifications/Technical Details
US MSRP Price: $21,999 USD
Canada MSRP Price: $24,599
Specifications
Dry Weight 760 lbs / 345 kg
Displacement 106 ci / 1731 cc
Oil Capacity 5.0 qts / 4.73 ltr
ENGINE & DRIVETRAIN
Battery 12 volts / 18 amp hours
Charging System 48 amps max output
Compression Ratio 9.4 : 1
Cooling Air / oil
Drive/Driven Clutch Wet, multi-plate
Exhaust Split dual exhaust with crossover
Transmission Type 6-speed overdrive constant mesh
Transmission/Final Drive Carbon Fiber Reinforced Belt
Transmission/Primary Drive Gear drive with torque compensator
Valve Train Single overhead camshafts with 4 valves per cylinder, self-adjusting cam chains, hydraulic lifters
Bore x Stroke (mm) 101 x 108 mm
Engine Type 4-stroke 50° V-Twin
Suspension
Front Suspension Inverted cartridge telescopic fork, 43 mm diameter, 5.1 in / 130 mm travel
Rear Suspension Single, mono-tube gas, cast aluminum with constant rate linkage, 4.7 in / 120 mm travel, air adjustable
Brakes
Brake System Type Conventional w/ optional ABS
Front Brakes Dual 300mm floating rotor with 4-piston calipers
Rear Brakes 300mm floating rotor with 2-piston caliper
Tires / Wheels
Front Tires 120/70R21 Dunlop Elite 3 Front
Front Wheel 21 x 3.5" Front
Rear Tires 180/60R16 Dunlop Elite 3
Rear Wheel 16 x 5.0"
DIMENSIONS
Fuel Capacity (gallons/liters) 5.8 gal / 22 ltr
GCWR 1360 lbs / 618 kg
Ground Clearance 5.8 in / 148 mm
Rake/Trail 29.0° / 5.6 in / 142 mm
Seat Height 26.3 in / 667 mm
Wheelbase 65.7 in / 1670 mm
Overall Length (in./cm.) 104.3 in / 2650 mm
Features
Colors Metasheen Black over Super Steel Gray, Magnum Red over Super Steel Gray, Ness Midnight Cherry, Plasma Lime with Silver
2017 Motorcycle Model Guides
2016 Motorcycle Model Guides
Re: This Week: 2015 Victory Magnum - Vote Now
Unread post by totalmotorcycle » Fri Nov 28, 2014 2:18 pm
New for 2015, Victory introduces a motorcycle that copies what has been done in the car industry! Super custom styling.
montanalifter
Real Name: Bill
My Motorcycle: Stratoliner S, Thunderbird Storm
Unread post by montanalifter » Fri Nov 28, 2014 6:46 pm
Was going to hit the awesome button till I looked at the price, 22k is a little steep for me. Its a solid cool.
BRUMBEAR
Real Name: Dave
Years Riding: 40
Unread post by BRUMBEAR » Fri Nov 28, 2014 8:10 pm
cool machine not my thing but it is kinda cool looking :cowboy:
there aint nothin like it
ceemes
Real Name: a big secret
Unread post by ceemes » Fri Nov 28, 2014 8:16 pm
:sick: :puke: :puke: :puke: :puke: :puke:
[img]http://i38.tinypic.com/2j0gmzq.jpg[/img]
Grey Thumper
Real Name: Dino
Unread post by Grey Thumper » Sat Nov 29, 2014 6:40 am
Ok, first off, I'm not into cruisers, so there's an inherent bias. But this one looks particularly cringe-inducing. Just a crass, gaudy, bloated, excessive, chromed-out, overweight boat of a bike that's also waaaaay too expensive.
Years Riding: 11
Unread post by blues2cruise » Sat Nov 29, 2014 5:53 pm
As much as I like cruisers....this one is just plain fugly.
Uncool.
Flipper
Real Name: Nancy
My Motorcycle: 2010 Ninja 250
Unread post by Flipper » Sat Nov 29, 2014 8:34 pm
Hideous, ghastly machine.
I gave it a fail.
2010 Ninja 250
2006 CB600F (sold)
2006 Honda Rebel (sold)
HYPERR
Unread post by HYPERR » Sat Nov 29, 2014 10:02 pm
What are those pillion girls sitting on? The saddlebags? Their knees are higher than if they were riding pillion on a racer replica.
They are not going to be smiling for long. :laughing:
Unread post by dr_bar » Sat Nov 29, 2014 11:35 pm
I voted fail, looks way too much like the fugly piece of shite Vision...
With apologies to owners of said bike...
faded sun
Years Riding: 42
My Motorcycle: 2003 Honda ST 1300
Unread post by faded sun » Sun Nov 30, 2014 9:12 pm
Cringe-inducing indeed. Except people who buy a bike because of the stereo are probably incapable of cringing. Which leaves the rest of us to cringe for them....
Definitely a one-up model, which makes it a fail in my book.
Not to mention that colour... what's that even called?
Jock
JackoftheGreen
Real Name: Eric
Unread post by JackoftheGreen » Mon Dec 01, 2014 12:33 am
This bike could absolutely accommodate 2Up riding, in fact the pillion is fairly large. Pics are on the full model guide page.
The front fender is awesome, and I'm a huge fan of the hardbags but I don't like how they leave the rear wheel so concealed. It looks like a pull-back car with only half the wheel showing. Also not a fan of that ridiculous AARP fairing, and anyone who cares about having music on their motorcycle needs to reevaluate their motives. Especially someone buying a cruiser. Lastly, 96ci is just too much displacement to take seriously, and the vacuum cleaner belt belongs on a Whooville city bus.
All that on top of a $22,000 price tag and I just have to hand down an UnCool, which believe me, hurts. All that negativity aside, just sitting there on the rubber the Magnum is a beautiful machine, pure rolling art in my book.
Years Riding: 11
Unread post by blues2cruise » Mon Dec 01, 2014 1:09 am
faded sun wrote:Cringe-inducing indeed. Except people who buy a bike because of the stereo are probably incapable of cringing. Which leaves the rest of us to cringe for them....
This maybe????
montanalifter
Real Name: Bill
Unread post by montanalifter » Mon Dec 01, 2014 10:50 pm
I have found bikes look much better in the showroom when you see them in the "flesh". Magazines don't do them justice. I am a fan of green but that green not so sure it would look good in the showroom either.
Unread post by totalmotorcycle » Tue Dec 02, 2014 12:42 pm
This maybe????
That would be:
ceemes
Unread post by ceemes » Tue Dec 02, 2014 7:09 pm
This maybe????
That would be:
Plasma Slime with Silver (there ya go boss, fixed it for ya)
Unread post by totalmotorcycle » Fri Dec 05, 2014 12:24 pm
LOL Ceemes, love the fix!
Well, it was hard to to vote Fail, but I'll go Uncool. The reason being I like the radical paint scheme direction Victory is going with this, yes, the colors are not for everyone, but I'm glad to see something other than "black, matt black, shadow black, gloss black" Victory has been offering now for a few years.
The Magnum in my opinion is quite a unique (but not for me at all) bike. I can see the potential of what Victory is hoping to achieve here by offering a bike that goes beyond a Harley-Davidson custom and into the custom "car" arena. A 21" tire, that's massive and you can get many different rims and (If I remember right even a 23" front!). That's madness, but I've seen a lot of custom bikes here in Houston that look like this and they are mad.
Not sure about a manufacturer sacrificing rideability for style, and I know it's nothing new, but the 2015 Victory Magnum takes that to new lows.
A great show bike, but wouldn't want to own it myself or go over and see it other than that "OMG look at that accident face"...lol.
Unread post by totalmotorcycle » Fri Dec 05, 2014 12:32 pm
2015 Kawasaki Vulcan S ABS - Coolness Factor = 40.4%
Featured: November 28th, 2014 - December 5th, 2014
Most popular vote category: Cool/Fail Tie
Motorcycle Cool Wall discussion: viewtopic.php?f=61&t=50414
Total Motorcycle model page: http://www.totalmotorcycle.com/motorcyc ... Magnum.htm
Awesome (3 points) 11% [ 4 ]
Cool (2 points) 32% [ 12 ]
Uncool (1 point) 26% [ 10 ]
Fail (0 point) 32% [ 12 ]
Total votes: 38
= a Coolwall Factor of 40.4%
NOTES: "Who hit the Victory Magnum with the ugly stick" or so goes the majority of opinions for the 2015 Victory Magnum. Some like it, in fact, it's quite original and unique in many ways. But the overall presentation by Victory seems to go too far for many riders to swallow. At 40.4% it drops the Victory Magnum to our 3rd lowest position for the year. Hopefully it's better in the show rooms?
Next 2014 TMW Cool Wall bike is now up for voting on, have fun!
HYPERR
Re: 2015 Victory Magnum - Coolness Factor = 40.4%
Unread post by HYPERR » Fri Dec 05, 2014 7:00 pm
Quintessential Poser Bike
Users browsing this forum: Grey Thumper and 182 guests
cron
