2015 Yamaha FJ-09 - Coolness Factor = 79.8%
Posted: Fri Feb 06, 2015 5:45 am
2015 Yamaha FJ-09 on the Total Motorcycle Cool Wall
For MORE information and Photos click here: http://www.totalmotorcycle.com/motorcyc ... a-FJ09.htm
2015 Yamaha FJ-09 on http://www.Totalmotorcycle.com
No matter what kind of riding you love, the all-new Yamaha FJ-09 offers the most performance, versatility and value packed into a single motorcycle...
The most versatile sport tourer.
Introducing the most performance, power, versatility and value ever packed into one motorcycle. From commuting and exploring back roads, to touring the open freeway and enjoying long sport tour adventures, the all new 2015 Yamaha FJ09 does it all in comfort and style with Yamaha's unmistakable reliability and performance.
Finally, the much anticipated FJ-09 has arrived! Designed around the concept of a "Versatile, Sporty Multi-Use machine", the FJ-09 offers a comfortable and exciting ride whether taking a relaxing tour or hitting the hustle of the city on your daily commute. An upright riding position, wide handlebar and all new seat design combine with the exciting power of the 3-cylinder Crossplane Concept engine to create a machine that will leave you grinning after every ride.
44 MPG
2015 Yamaha FJ-09 - http://www.Totalmotorcycle.com USA Specifications/Technical Details
US MSRP Price: $10,490 - Matte Gray - Available from November 2014; $10,490 - Candy Red - Available from November 2014
Canada MSRP Price: $10,999 CDN
Engine
Engine Type 847cc liquid-cooled inline 3-cylinder, DOHC, 12 valves
Bore x Stroke 78.0 x 59.1mm
Compression Ratio 11.5:1
Fuel Delivery Fuel Injection
Ignition TCI: Transistor Controlled Ignition
Transmission 6-speed; multiplate wet clutch
Chassis
Suspension / Front 41mm fork; adjustable preload and rebound damping; 5.4-in travel
Suspension / Rear Single shock; adjustable preload and rebound damping; 5.1-in travel
Brakes / Front ABS, Dual hydraulic disc, 298mm
Brakes / Rear Hydraulic disc, 245mm
Tires / Front 120/70-ZR17M/C
Tires / Rear 180/55-ZR17M/C
Dimensions
L x W x H 85.0 x 37.4 x 53.0 – 54.1 in
Seat Height 33.3 or 33.9 in
Wheelbase 56.7 in
Rake (Caster Angle) 24°
Trail 3.9 in
Fuel Capacity 4.8 gal
Fuel Economy 44 mpg
Wet Weight 462 lb
44 MPG
Engine
Chassis
Dimensions
Wheelbase 56.7 in
Trail 3.9 in
Fuel Economy 44 mpg
Wet Weight 462 lb
