2015 Moto Guzzi V7 II Special - Coolness Factor = 85.7%
Posted: Tue Feb 10, 2015 8:51 am
2015 Moto Guzzi V7 II Special on the Total Motorcycle Cool Wall
For MORE information and Photos click here: http://www.totalmotorcycle.com/motorcyc ... pecial.htm
2015 Moto Guzzi V7 II Special on http://www.Totalmotorcycle.com
THE SECOND ACT OF A FIRST RATE WORK...
Of the V7 versions this is the one that most approaches the original spirit of its ancestor, beginning from its graphics, christened "Essetre" (S3) and inspired by the famous 1975 V750 S3. Following this graphic concept, the V7 II now has three glossy colour bases: classic black with orange stripes to faithfully revisit the colours of its famous ancestor and two brand new schemes on metallic red and light blue with a silver stripe.
As with the Stone, the Special also has a new frame that stands out, besides for the different engine and shock absorber mounting distances, for an improved finish in terms of welding and paintwork, as well as for the redesigned black brake and clutch levers and the new rear light cluster. Unlike the Stone and the Racer, the V7 Special has a fork stanchion protector instead of the dust boots that are fitted on the other models in the range.
THE NEW GENERATION OF A LEGEND
Introducing the new generation of one of the best-selling and popular "Eagle brand" models anywhere in the world.
The new Moto Guzzi V7 II was christened thus according to Mandello tradition and it is available in three different versions, each with its own identity: Stone, Racer and Special. Moto Guzzi V7 II literally has an extra gear. In fact, making it's début on the V7 II - and it is just the first on a long list of safety and performance technical advancements - is a new, six speed gearbox with spacing that has allowed the first and last two ratios to be reduced, decreasing the drop in rpm between one gear and the next. Along with the gearbox the clutch was also improved in order to achieve a softer action and a more even release. Moto Guzzi continues to develop solutions to increase active safety features and on the new V7 II the ABS braking system and MGCT (Moto Guzzi Controllo Trazione) system have been introduced.
The former is a two-channel system, whereas the latter is a sophisticated electronic system that ensures ideal traction in any conditions, preventing the rear wheel from sliding during acceleration, thereby averting dangerous loss of grip to increase riding safety.
The aesthetics have also evolved: on the new V7 II the engine has been tilted 4° toward the front axle and lowered 10 mm. This solution not only significantly improves the aesthetics from a side view, which on previous models seemed to have a "nose-up" look of the 90° V, but it also created more knee room. In fact, the new V7 II, which also has new 25 mm lower footpegs, provides a comfortable position even for above average height riders, while remaining accessible and "user friendly" for riders - men and women - of any size. The new Moto Guzzi V7 is available in three versions: V7 II Special, eclectic and essential, characterised by typical '70s colour schemes; V7 II Special, the closest to the original spirit of its ancestor, starting from the graphics inspired by the famous 1975 V750 S3; V7 II Racer that embodies the Moto Guzzi sports spirit. With its sporty set up, low handlebars and a chromium fuel tank with a leather fastening strap, V7 II Racer is a bike that was born to be ridden strictly one-up, wearing black leathers and leather stud palm gloves.
2015 Moto Guzzi V7 II Special - http://www.Totalmotorcycle.com American Specifications/Technical Details
USA MSRP Price: $9290 USD
Canada MSRP Price: $9490 CDN
ENGINE
Type 90° V-twin 4-stroke
Capacity 744 cc
Maximum power 37 kW (50HP) at 6,200 rpm
Maximum torque 42.7 ft lbs. / 58Nm at 5,000 rpm
Fuel system Weber-Marelli electronic fuel injection.
Exhaust system Three-way catalytic converter with double lambda probe
TRANSMISSION
Gearbox 5 speeds with cardan final drive
Lubrication forced circulation with lobe pump - circuit capacity: 1.78 Kg
Final drive CA.R.C. Compact Reactive Shaft Drive
Clutch Dry single plate with flexible couplings
CHASSIS / SUSPENSION / BRAKES
Frame Double cradle tubular frame in ALS steel with detachable rear subframe
Front suspension Telescopic hydraulic fork with 40 mm stanchions
Rear suspension Die cast light alloy swing arm with 2 spring preload adjustable shock absorbers
Brake system Brembo
Front brake 320 mm Ø stainless steel disc, Brembo caliper with 4 differentiated pistons
Rear brake 260 mm stainless steel disc, brembo double piston floating caliper
Wheels Spoked polished aluminium rims
Front wheel 18", 100/90
Rear wheel 17", 130/80
DIMENSIONS
Length 86 inches - 2184mm
Max width 31.5 inches - 800mm
Height 43.8 inches - 1112mm
Saddle height 31.6 in. (30.7 in. opt.) - 805 mm (780 mm opt.)
Curb weight 395 pounds - 179 kg
Fuel tank capacity 5.8 gallons - 22 liters
Reserve 1 gallon - 4 liters
* Weight with motorcycle ready for use with all operating fluids and without fuel.
ENGINE
Capacity 744 cc
TRANSMISSION
Brake system Brembo
DIMENSIONS
