2015 Suzuki Boulevard S40 - Coolness Factor = 61.2%
Posted: Fri May 22, 2015 6:08 am
2015 Suzuki Boulevard S40 on the Total Motorcycle Cool Wall
For MORE information and Photos click here: http://www.totalmotorcycle.com/motorcyc ... rd-S40.htm
Timeless...
A timeless design that has remained strong over the years. The lightweight responsiveness of the Boulevard S40 enhances the amount joy you'll have cruising down the highway and beyond the city limits. The S40 utilizes a strong single-cylinder engine that provides exciting low-end to mid-range torque and rock solid reliability. At cruising speeds, you'll really appreciate the ride quality of the S40's suspension.
This gleaming beauty is what custom cruising all about. The SUZUKI BOULEVARD S40’s high torque, produced by its powerful engine, is fully utilized by a wide 5-speed transmission and low-maintenance belt drive. A large crankshaft delivers more stable power at low revs to ensuresmooth running. Narrow frame, teardrop-shape tank, and lots of chrome complete the custom-cruiser look.
2015 Suzuki Boulevard S40 - http://www.Totalmotorcycle.com USA Specifications/Technical Details
US MSRP Price: $5499 USD
Canada MSRP Price: $6199 CDN
ENGINE
Engine 652cc, 4-stroke, air-cooled, single cylinder, OHC
Bore x Stroke 94.0 mm x 94.0 mm (3.70 in x 3.70 in)
Fuel System MIKUNI BS40, single
Starter Electric
DRIVETRAIN
Transmission 5-speed constant mesh
Final Drive Belt drive
CHASSIS
Suspension Front Telescopic, coil spring, oil damped
Suspension Rear Swing arm type, coil spring, oil damped
Brakes Front Disc brake
Brakes Rear Drum brake
Tires Front 100/90-19 M/C 57H, tube type
Tires Rear 140/80-15 M/C 67H, tube type
Fuel Tank Capacity 2.8 US - Including Reserve
Color Candy Daring Red, Pearl Moon Stone Gray
ELECTRICAL
Ignition Electronic ignition (transistorized)
DIMENSIONSANDCURBWEIGHT
Overall Length 2180 mm (85.8 in)
Overall Width 720 mm (28.3 in)
Wheelbase 1480 mm (58.3 in)
Ground Clearance 135 mm (5.3 in)
Seat Height 700 mm (27.6 in)
Curb Weight 173 kg (381 lbs)
WARRANTY
Warranty 12 month unlimited mileage limited warranty.
Timeless...
ENGINE
Starter Electric
DRIVETRAIN
CHASSIS
ELECTRICAL
WARRANTY
