2010 Roehr 1250sc - Coolness Factor = 70.2%
Posted: Fri Jul 10, 2015 3:40 am
2010 Roehr 1250sc on the Total Motorcycle Cool Wall
For MORE information and Photos click here: http://www.totalmotorcycle.com/photos/2 ... 1250sc.htm
A new American Classic
The dream of owning an American made sport bike that could hold it's own against the world's finest machines has been a dream for many. This dream is now a reality. Not only is the Roehr 1250sc the fastest and most powerful American production sport bike, but one of the top performing machines in the world.
The 1250sc represents the birth of a new American motorcycle brand. A brand committed to producing beautiful, high performance machines made in the USA. The "can do" spirit that made America great is alive and well at Roehr Motorcycles. This passion is the foundation of our brand and expressed through our products.
The Roehr 1250sc, the rebirth of American world class performance.
Key Features
- This superbike is powered by a special version of the incomparable Harley-Davidson* Revolution* engine
- 180hp of supercharged American Muscle
- Innovative BiMetal composite beam frame
- Sleek European flavor design
- Performance without compromise
- Road or track
- World class motorcycle components
- Proudly handcrafted in the USA
- A true American thoroughbred superbike
2010 Roehr 1250sc - Specifications
MSRP: $Call USD
The Bike: The Roehr 1250sc boasts high-spec running gear – Ohlins suspension, Marchesini alloy wheels, Brembo brakes with radial-mount calipers at the front, composite bodywork and is powered by the 1250sc 180HP, specially developed supercharged version of the HarleyDavidson* 1250cc Revolution* engine. State of the art supercharger technology has been applied, providing reliable high power output with a broad, linear power delivery.
Engine:
2 Cylinder, Supercharged, Liquid Cooled, DOHC, Counterbalanced, 60deg, V-twin
Displacement:
1250cc
Bore x Stoke:
105mm x 72mm
Compression ratio:
11.3 / 1
Transmission:
5 speed
Clutch: Wet, multi-plate, hydraulic actuation, slipper type
HP/Torque:
180hp @ 9100 RPM,
115 lb/ft torque @ 7600 RPM
Final drive: 520 O-ring chain
The Chassis: A unique modular CrMo steel and aluminum frame has been developed. This frame uses these two materials at areas in which their material characteristics are best suited. The result is a stiff, light weight structure that provides unparalleled steering response
Chassis Type:
Steel/aluminum composite beam frame, 4130 steel/ 6061 aluminum
Wheelbase:
56 inches (1422mm)
Rake/trail:
23.5deg. / 89mm
Seat height:
31.5 inches
Dry weight:
432 lbs. (196kg)
Front suspension:
Ohlins 43mm fully adjustable upside-down fork with TiN
Rear suspension:
Ohlins fully adjustable linkless monoshock
Front Brakes:
2 x 330mm semi-floating discs, radially mounted Brembo 4 piston calipers.
Rear brake:
245mm single disc, with 2 piston Brembo caliper
Front Wheel/tire:
3.5 x 17 forged aluminum 10 spoke Marchesini, 120/70 ZR17
Rear wheel/tire:
6.0 x 17 forged aluminum 10 spoke Marchesini, 190/55 ZR17
Fuel tank capacity:
3.2 US gallons
Reserve fuel:
.5 US gallons
Key Features
- Road or track
MSRP: $Call USD
Engine:
Displacement:
1250cc
Bore x Stoke:
105mm x 72mm
Compression ratio:
11.3 / 1
Transmission:
5 speed
HP/Torque:
180hp @ 9100 RPM,
Chassis Type:
Wheelbase:
56 inches (1422mm)
Rake/trail:
23.5deg. / 89mm
Seat height:
31.5 inches
Dry weight:
432 lbs. (196kg)
Front suspension:
Rear suspension:
Front Brakes:
Rear brake:
Front Wheel/tire:
Rear wheel/tire:
Fuel tank capacity:
3.2 US gallons
Reserve fuel:
.5 US gallons
