2016 Harley-Davidson Softail Slim S Fat Custom - Coolness Factor = 73.1%
Your Coolness Factor of the 2016 Harley-Davidson Softail Slim S Fat Custom is:
View results
Unread post by totalmotorcycle » Fri Aug 28, 2015 1:02 pm
2016 Harley-Davidson Softail Slim S Fat Custom on the Total Motorcycle Cool Wall
For MORE information and Photos click here: http://www.totalmotorcycle.com/motorcyc ... Custom.htm
American Muscle...
We’ve taken everything that was great about the Softail Slim® and added a little more. For starters, we’ve added power with a Screamin’ Eagle® Air-Cooled Twin Cam 110B™ engine. We’ve taken the military theme even further with an awesome Olive Gold Denim paint option and made the rest black to the core. Black triple clamp and riser, gloss black headlamp ring, fork slider covers and lower forks. Black brake levers, mirrors and black over/under shotgun exhaust with slash cut muffler. Every inch is modern power with old iron attitude.
Nothing gets more respect on the street than power. So when we built the new Softail Slim® S, we loaded it up with the most powerful engine you can get in cruiser this year.
The classic look of a hardtail and the comfort, handing and rideability of a modern motorcycle combine seamlessly in Harley-Davidson Softail models to deliver a smooth ride. The entire Softail® family is reinvigorated with exciting performance upgrades and updates for 2016, including the High Output Twin Cam 103B engine, electronic throttle, and standard or available electronic cruise control. Limited-edition Fat Boy® S and Softail Slim® S models combine rich finishes with the Screamin’ Eagle® Twin Cam 110™ engine to deliver a complete package of big power and cutting-edge style to riders who want to stand out.
2016 Harley-Davidson Softail Slim S Fat Custom - http://www.Totalmotorcycle.com USA Specifications/Technical Details
US MSRP Price: Starting from $18499 USD
Canada MSRP Price: Starting from $21499 CDN
PRICING 6
Vivid Black $18,499
Color Option $18,899
Security Option Standard
ABS Option Standard
Cruise Control Option Standard
California Emissions $200
Freight $390
DIMENSIONS
Length 92.3 in.
Seat Height, Laden 7 23.8 in.
Seat Height, Unladen 7 28.2 in.
Ground Clearance 4.9 in.
Rake (steering head) (deg) 32.1
Trail 5.8 in.
Wheelbase 64.4 in.
Tires, Front Specification MT90B16 72H
Tires, Rear Specification MU85B16 77H
Fuel Capacity 5 gal.
Oil Capacity (w/filter) 3.5 qt.
Weight, As Shipped 682 lb.
Weight, In Running Order 712 lb.
ENGINE
Engine 1 Screamin' Eagle® Air-cooled, Twin Cam 110B™
Bore 4 in.
Stroke 4.374 in.
Displacement 110 cu in
Compression Ratio 9.5:1
Fuel System 3 Electronic Sequential Port Fuel Injection (ESPFI)
DRIVETRAIN
Primary Drive Chain, 34/46 ratio
Gear Ratios (overall) 1st 9.311
Gear Ratios (overall) 2nd 6.454
Gear Ratios (overall) 3rd 4.793
Gear Ratios (overall) 4th 3.882
Gear Ratios (overall) 5th 3.307
Gear Ratios (overall) 6th 2.79
CHASSIS
Exhaust Black over/under shotgun exhaust with slash-cut muffler
Wheels, Front Type 9 Black Steel Laced
Wheels, Rear Type Black Steel Laced
Brakes, Caliper Type 4-piston front and 2-piston rear
PERFORMANCE
Engine Torque Testing Method J1349
Engine Torque 2 109 ft-lb
Engine Torque (rpm) 3,500
Lean Angle, Right (deg.) 24
Lean Angle, Left (deg.) 24.9
Fuel Economy: Combined City/Hwy 5 43 mpg
ELECTRIC
Lights (as per country regulation), Indicator Lamps 8 High beam, neutral, low oil pressure, turn signals, engine diagnostics, security system (optional), 6-speed, low fuel warning, ABS (optional)
Gauges Tank-mounted electronic speedometer with odometer, time-of-day clock on odometer, dual tripmeter, RPM/gear display, fuel gauge with low fuel warning light and countdown feature, low oil pressure indicator light, engine diagnostics readout, LED indicator lights, 6-speed indicator light
1. Recommended 91 octane or higher fuel (R+M)/2.
2. Values shown are nominal. Performance may vary by country and region.
3. Standard and optional fuel systems may vary by country.
4. See motorcycle owner's manual for complete details.
5. Estimated from fuel economy tests on a sample motorcycle from the corresponding family conducted by Harley-Davidson under ideal laboratory conditions. Not all motorcycle models undergo fuel economy testing. Fuel economy and mileage may vary among motorcycle models within a family. Your mileage may vary depending on your personal riding habits, weather conditions, trip length, vehicle condition and vehicle configuration and other conditions. Break-in mileage may vary.
6. Prices listed are the Manufacturer's Suggested Retail Prices. Options such as color are available at additional cost. Prices exclude dealer setup, taxes, title and licensing and are subject to change. Dealer prices may vary.
7. Measurement reflects 180 lb. (81.7 kg) operator weight.
8. North America security system includes immobilizer; outside North America the security system includes immobilizer and siren.
9. Standard and optional wheels may vary by country and region.
2017 Motorcycle Model Guides
2016 Motorcycle Model Guides
Re: This Week: 2016 Harley-Davidson Softail Slim S Fat Custom - Vote Now
Unread post by totalmotorcycle » Fri Aug 28, 2015 1:08 pm
BRAND NEW for 2016, in fact, the whole Harley-Davidson S Fat Custom line is as well!
Special note: The S Line comes equipped with the Screamin' Eagle® Air-cooled, Twin Cam 110B™... this is the first time the 110B engine has been used outside of the CVO line.
Enjoy!
montanalifter
Real Name: Bill
Unread post by montanalifter » Sun Aug 30, 2015 3:53 am
I think it is a great looking bike. Has a gear indicator and tach (is this new for Harley?). Most powerful cruiser? I think they mean that Harley makes. Cruise control is nice.
faded sun
Years Riding: 42
Unread post by faded sun » Sun Aug 30, 2015 10:27 pm
Military paint job is a non-starter for me. But I am not in the Harley owner demographic.
Definitely a Harley. The ones I've ridden have had too much vibration to consider them for anything more than booting downtown. Have I been riding the wrong ones?
Jock
ZRex
Real Name: Ben
My Motorcycle: 2002 Kawasaki ZRX1200R
Unread post by ZRex » Mon Aug 31, 2015 10:51 pm
I voted Awesome, I really like this bike.
Grey Thumper
Real Name: Dino
Unread post by Grey Thumper » Thu Sep 03, 2015 10:53 pm
I'm not into cruisers at all, but this gets a solid cool from me. Looks great, and lots of power. 24 degrees of lean angle on either side is a bit of a bummer though.
Unread post by totalmotorcycle » Fri Sep 04, 2015 11:33 am
I voted: Awesome
There are not many Harley-Davidson motorcycle models I vote awesome for, most earn a solid cool (with some rare fails in the mix). But the new 2016 Harley-Davidson Softail Slim S Fat Custom I like a lot. It's not the paint job (more on that later) but that you get a CVO "lite" at just $3,600 more than the base model plus that all important 110 engine, and trust me, that 110 vs the 103 (or the 98) makes a big enough difference. Now you might say, what a sec, the new 2016 Harley-Davidson Softail Slim S Fat Custom is updated with the 103 HIGH OUTPUT version (see below).
So I like it, but I'm not sure about the paint job. This bike is sold worldwide with the same paint and I'm not sure if riders (who are not American/Pro-American) really want a WWII USA paint job on it riding around in their country (the white star on green was USA in WWII). I do like the design of it and personally think it's cool, but it's a little market limiting wouldn't you say?
2015 Air-cooled, Twin Cam 103B™
Engine Torque 97.4 ft-lb
vs
2016 Air-Cooled, High Output Twin Cam 103B
Engine Torque 100.3 ft-lb
vs
2016 Screamin' Eagle® Air-cooled, Twin Cam 110B
Engine Torque 109 ft-lb
...I'll let you decide for yourself there.
and the prices:
2016 Harley-Davidson Softail Slim S Fat Custom: $18499 USD / $21499 CDN
vs
2016 Harley-Davidson Softail Slim $14899 USD / $17399 CDN
+ 3,600 USD / 4,100 CDN
Overall, I really love the new S Fat Custom line and I hope Harley-Davidson expands it to include many other models or makes it an option on ANY model.
Unread post by totalmotorcycle » Fri Sep 04, 2015 11:45 am
Featured: August 28th, 2015 - September 4th 2015
Motorcycle Cool Wall discussion: viewtopic.php?f=61&t=51929
Total Motorcycle model page: http://www.totalmotorcycle.com/motorcyc ... Custom.htm
Awesome (3 points) 46% [ 12 ]
Cool (2 points) 31% [ 8 ]
Uncool (1 point) 19% [ 5 ]
Fail (0 point) 4% [ 1 ]
Total votes: 26
= a Coolwall Factor of 73.1%
Notes: Lots of power, great custom looks, new Screamin' Eagle® Air-cooled, Twin Cam 110B engine and for just $3 or $4k more vs 100% more for a CVO model. I'm definitely thinking Harley-Davidson did a good thing by introducing the S Fat Custom line, hopefully they make it an option for all bikes in the future.
Jarlaxle
Real Name: John
My Motorcycle: 2012 Suzuki Burgman
Re: 2016 Harley-Davidson Softail Slim S Fat Custom - Coolness Factor = 73.1%
Unread post by Jarlaxle » Mon Sep 07, 2015 7:24 am
Fail. 2-wheeled art that is somewhere between impractical and ludicrous for anything else. Doesn't handle, has a pounding, kidney-hammering ride on anything worse than a glass-smooth highway, engine is a throwback to 1930 and a hand grenade with the pin pulled.
Users browsing this forum: montanalifter, rtgrey and 127 guests
cron
