2016 Triumph Speed 94R - Coolness Factor = 72.7%
Posted: Fri Sep 04, 2015 5:54 am
2016 Triumph Speed 94R on the Total Motorcycle Cool Wall
For MORE information and Photos click here: http://www.totalmotorcycle.com/motorcyc ... eed94R.htm
21 Years of The Speed Triple...
In 1994 the original Speed Triple burst into showrooms and set the scene for 21 years of naked dominance by mixing cool, café racer culture with the muscular aggression of the streetfighter scene, wrapped up in sportsbike-style handling prowess. The combination was an instant hit, wowing all kinds of riders from the spectrum of biking. Whether you were a hard-core sportsbike enthusiast or a relaxed Sunday-afternoon cruiser, you could find what you wanted in the Speed Triple.
2016 Triumph Speed 94R http://www.Totalmotorcycle.com Key Features
Since then, the Speed Triple has constantly moved with the times, evolving to keep pace with customer needs and the demands of modern riding, but always faithfully delivering the same core philosophy of raw, naked good looks coupled with outstanding handling. Each new evolution has benefitted from advances in engine and chassis performance, but all have retained the indomitable physical stance and raw attitude of the original inline triple, and each developing its own band of passionate owners and fans.
Today, that vision is brought full circle with the new Speed 94R and Speed 94RR each loaded with styling and design cues that echo the original and provide a fitting celebration of 21 years at the cutting edge of the class.
Speed 94R
The Speed 94R and Speed 94RR unite both ends of the Speed Triple story, combining the modern Speed Triple engine and chassis package together with stylistic and visual elements of the very first, original Speed Triple from 1994. The result is, literally, the best of both worlds.
The heart of the Speed 94R and Speed 94RR is a modern, fuel-injected three-cylinder 1050cc motor producing an astonishing 135PS and 111Nm of torque. The powerplant is matched to an aluminium trellis frame, beefy single-sided swingarm, fully adjustable 43mm upside-down Showa forks and monoshock, and Brembo radial calipers equipped with Triumph’s anti-lock brake system. The Speed 94R signature look is completed with a host of styling and design cues to echo the original 1994 Speed Triple, either in striking Racing Yellow or moody Jet Black, specially re-formulated to match the first Speed Triple paint schemes and finished with decals in the original Speed Triple script.
2016 Triumph Speed 94R - http://www.Totalmotorcycle.com European Specifications/Technical Details
Europe/UK MSRP Price: OTR £10,999.00 GBP (On The Road inc 20% Vat)
Engine and Transmission
typeLiquid-cooled, 12 valve, DOHC, in-line 3-cylinder
capacity1050cc
bore79.0mm
stroke71.4mm
systemMultipoint sequential electronic fuel injection with SAI
exhaustStainless Steel 3 into 1 into 2, twin high level stainless steel silencers
final driveX-Ring-Chain
clutchWet,Multi-Plate
gearbox6-Speed
oil capacity3.8L
Chassis, Running Gear and Displays
frameAluminium beam twin-spar
swingarmSingle-sided, aluminium alloy with eccentric chain adjuster
Front WheelsCast aluminium alloy multi-spoke 17 x 3.5in
Rear WheelsCast aluminium alloy multi-spoke 17 x 6.0in
Front Tyres120/70 ZR 17
Rear Tyres190/55 ZR 17
Front SuspensionÖhlins 43mm NIX30 upside down forks with adjustable rebound and compression damping, 120mm travel
Rear SuspensionÖhlins TTX36 twin tube Monoshock with rebound and compression damping, 130mm rear wheel travel
brakes frontTwin 320mm floating discs, Brembo 4-piston Monobloc radial calipers , Switchable ABS
brakes rearSingle 255mm disc, Nissin single 2-piston sliding caliper, Switchable ABS
instrument display and functionsLCD multi-functional instrument pack with digital speedometer, fuel gauge, trip computer, analogue tachometer, programmable gear change lights, lap timer, service interval announcement and TPMS ready, switchable ABS.
Dimensions and Capacities
length2100mmmm
width handlebars795mm
height without mirror1110mm
seat height825mm
wheelbase1435mm
rake22.8°
trail90.9mm
tank capacity17.5l
wet weight214 kg
dry weight186 kg
Performance
max power ec 133BHP @ 9400
max torque ec 111NM @ 7750
Speed 94R
capacity1050cc
bore79.0mm
stroke71.4mm
gearbox6-Speed
oil capacity3.8L
length2100mmmm
seat height825mm
wheelbase1435mm
rake22.8°
trail90.9mm
tank capacity17.5l
wet weight214 kg
dry weight186 kg
Performance
