2015 Hyosung GD250N - Coolness Factor = 41.7%
Posted: Fri Sep 18, 2015 5:34 am
2015 Hyosung GD250N on the Total Motorcycle Cool Wall
For MORE information and Photos click here: http://www.totalmotorcycle.com/motorcyc ... GD250N.htm
Your way to experience the ease of excitement...
The 2015 Hyosung GD250N / X4 EFI / X4 is all new ground for Hyosung with 98% new parts on this exciting new 250 single street bike. A fresh design with a high torque, liquid cooled, fuel injected, DOHC, 4 valve single cylinder engine which sets a new bench mark for this class of engine. Power and torque figures are impressive with 28.4 hp @ 8500 rpm and 26.1 Nm @ 7000rpm channelled through a 6 speed gearbox.. Yes more than enough to cross any intersection ahead of most other commuters. The new chassis starts with USD KYB forks, steel trellis perimeter frame, bolt on steel sub frame, aluminium swingarm, KYB rear shock and lightweight wheels. Keeping the centre of gravity low is a under slung stainless muffler. To stop this commuter wild thing you have a 4 piston front caliper gripping a lightweight disc and a dual opposed piston rear caliper with braided stainless brake lines. The rider is kept informed by a digital dash with gear position indicator and vibes are low thanks to the tapered handlebars. Dry weight is only 135kg making for a top of the class power to weight ratio.
2015 Hyosung GD250N / X4 EFI http://www.Totalmotorcycle.com Key Features
The X4 is all new ground for Hyosung with 98% new parts on this exciting new 250 single street bike. A fresh design with a high torque, liquid cooled, fuel injected, DOHC, 4 valve engine which sets a new bench mark for this class of engine. Power and torque figures are impressive with 28.4 hp @ 8500 rpm and 26.1 Nm @ 7000rpm channelled through a 6 speed gearbox.. Yes more than enough to cross any intersection ahead of most other commuters. The new chassis starts with USD KYB forks, steel trellis perimeter frame, bolt on steel sub frame, aluminium swingarm, KYB rear shock and lightweight wheels. Keeping the centre of gravity low is a under slung stainless muffler. To stop this commuter wild thing you have a 4 piston front caliper gripping a lightweight disc and a dual opposed piston rear caliper with braided stainless brake lines. The rider is kept informed by a digital dash with gear position indicator and vibes are low thanks to the tapered handlebars. Dry weight is only 135kg making for a top of the class power to weight ratio.
The overall package is very promising indeed and the X4 will set a new standard of nimble, lightweight commuter bike.
Colours:
Black
Red
White
Blue
Colour choice subject to availabilty
Two year / 20,000km factory warranty.
201n Hyosung GD250N / X4 EFI - http://www.Totalmotorcycle.com International Specifications/Technical Details
US MSRP Price: $3799 USD
Canada MSRP Price: $ See Dealer CDN
Australia/NZ MSRP Price: $ See Dealer
ENGINE
Type Liquid cooled DOHC 4-valve Single cylinder
Displacement 249cc
Bore x Stroke 73 x 59.6
Compression Ratio 12 : 1
Max Power 21.2 kW (28.4 HP) @ 8500 RPM
Max Torque 26.1 Nm (2.56 kgf.m) @ 7000 RPM
Fuel System Fuel injection
Lubrication Wet sump
TRANSMISSION
Clutch Wet, Multiplate
Gear Constant mesh, Close ratio 6-speed (1down 5up)
Final Drive Chain
CHASSIS
Frame Type Steel tubular trellis perimeter main frame & Steel tubular assembly sub frame
Overall Length 1937mm
Overall Height 1100mm
Overall Width 700mm
Wheel Base 1346mm
Ground Clearance 135mm
Seat Height 810mm
Caster 23.5 °
Trail 93.6mm
Brake F: 300Ø Petal shaped spoke mounted single disc, 4 opposed pistons caliper, Stainless mesh hose
R: 230Ø Petal shaped single disc, 2 opposed pistons caliper, Stainless mesh hose
Suspension F: 37Ø Upside down Telescopic
R: Dual side Aluminum Swing arm with Gas charged Hydraulic shock absorber (Nonstep Preload adjustable)
Tyre F: 110/70 R17 54S / R: 150/60 R17 66S
Fuel Tank Capacity 11L
Curb Weight 155kg
Colours:
Black
Red
White
Blue
ENGINE
Displacement 249cc
TRANSMISSION
Final Drive Chain
CHASSIS
Overall Width 700mm
Wheel Base 1346mm
Seat Height 810mm
Caster 23.5 °
Trail 93.6mm
Curb Weight 155kg
