2015 Moto Guzzi Griso 8V SE - Coolness Factor = 89.7%
Your Coolness Factor of the 2015 Moto Guzzi Griso 8V SE is:
34
81%
6
14%
2
5%
0
No votes
Total votes: 42
Years Riding: 32
2015 Moto Guzzi Griso 8V SE on the Total Motorcycle Cool Wall
For MORE information and Photos click here: http://www.totalmotorcycle.com/motorcyc ... -8V-SE.htm
A SPECIAL EDITION FOR THE DISCERNING RIDING ENTHUSIAST...
The Griso S.E. comes alongside the elegant "Black Devil" graphic, the new Rosso Trophy livery, a colour concept that enhances the sport spirit of the attractive Larian naked. Both share the original silver graphic pattern, developed on a black or red satin base, that generates a strip of light that runs from the fuel tank to the side ducts.
Among the details making this a genuine special edition there are the attractive spoke wheels with a red Moto Guzzi logo cloned from high end new California 1400 Custom.
Powered by a modern transverse 90° V-twin "Quattrovalvole" series engine developing a peak power of approximately 110 hp at just 7500 rpm, the Griso 8V SE dominates the road with silky smooth power delivery and a commanding presence, inviting the rider to delve into the ability of the outstanding chassis to keep all those straining horses in check.
This is all thanks to the chassis, with twin overhead tubular elements in high tensile steel and the generously sized lateral reinforcement of the lower cradle, with ribbing that is much more than just an aesthetic suggestion but actually designed to confer extremely high torsional rigidity to the bike as a whole. The geometry has been defined for maximum stability, with a headstock inclined by of 26° resulting in a trail of 108 mm and a wheelbase of 1544 mm. Nonetheless, the Griso 8V SE is surprisingly nimble and sincere, rewarding the rider with lightning fast directional changes.
The impeccable road manners of the Griso 8V SE SE benefit from the low centre of gravity and the rock steady front end, with reduced offset plates to ensure an immediate and precise response to any steering input. This is a veritable scalpel on two wheels allowing the most discerning rider to carve perfect lines in the asphalt.
NEW DESIGN
NEW COMFORT
NEW ENGINE
2015 Moto Guzzi Griso 8V SE - http://www.Totalmotorcycle.com American Specifications/Technical Details
USA MSRP Price: $12,990 USD
Canada MSRP Price: $13600 CDN
ENGINE
Type : Four-stroke V 90 twin
Cooling : Air and oil cooled with independent cooling pump
Capacity : 1,151cc
Bore and stroke : 95 x 81.2 mm
Compression ratio : 11 : 1
Maximum power output : Over 80.8 kW (110 CV) at 7,500 rpm
Max Torque : Over 108 Nm at 6,400 rpm
Fuel supply/ignition : Multipoint sequential electronic injection, Magneti Marelli IAW 5A phased, alfa-n system; 2 x Ø50 mm throttle bodies with Weber IWP 189 injectors, Lambda probe.
Starter : Electric
Spark plugs : NGK PMR8B (Long Life)
Exhaust system : Stainless steel two-into-one 3-way catalysed with Lambda probe.
Homologation : Euro 3
TRANSMISSION
Gearbox : 6 speed
Gear ratios : 1st 17/38 = 1 : 2.235
Lubrication : Oil bath
Primary drive : Helicoidal gears, ratio 26/35 = 1 : 1.346
Final drive : CA.R.C reactive drive; double universal joint with floating bevel gear, ratio 12/44 = 1 : 3,666
Clutch : Single plate with integrated flexible couplings
FRAME
Frame : High tensile steel tubular twin cradle
Wheelbase : 1,554 mm
Rake : 108 mm
Steering rake : 26.30°
Steering angle. : 34°
Front suspension : Upside down Ø 43 mm fully adjustable forks (spring preload and hydraulic for rebound and compression) with mounting for radial callipers.
Front wheel travel : 120 mm
Rear suspension : Progressive single swingarm, fully adjustable monoshock with separate gas reservoir (spring preload and hydraulic for rebound and compression).
2023 Motorcycle Model Guides
Years Riding: 32
Re: This Week: 2015 Moto Guzzi Griso 8V SE - Vote Now
This Cool Wall bike is brought to you by one of our community members, Faded Sun!
I had forgotten that the 2015 Moto Guzzi Griso 8V SE was redesigned for 2015 and even kept the low price of the old model!
NEW DESIGN
NEW COMFORT
NEW ENGINE
Check it out.
ceemes
Real Name: a big secret
#3 Unread post by ceemes »
After serving up the that crap-pie CCW offering last week, Mike has redeemed himself by offering up a proper if quirky bike from a proper if quirky manufacturer. I like this bike and gave it a solid cool. I would of went awesome except for tail end of the rear fender........what a good awful looking piece of kit, I doubt even a licence plate could hide its hideous looks. And while I have never been a big fan of fender eliminator kits, that godawful tail end is screaming for one, and it would be the first modification I would have done before riding it out of the dealership if I wear to buy one. It's a pity, because I really love the look of this machine.....but I just cannot get over that tail piece......
Grey Thumper
Real Name: Dino
This bike is pretty ancient (launched in 2005), with pretty evolutionary changes over the years (the most notable being a switch to an 8V engine), but otherwise it's mostly about "BOLD NEW GRAPHICS".
I don't care. It's a Guzzi. It's a modern classic. And it's awesome.
Incidentally, I never noticed how awful the rear fender was until Ceemes pointed it out. Fortunately, Google reveals that fender eliminator kits are available.
faded sun
Years Riding: 46
#5 Unread post by faded sun »
I saw one of these when I came out of work to ride home and wanted to get on it and ride IT home. It is a bit pricey to be sure, but just oozes fun when you are standing beside it with gear on.
I went with awesome.
Jock
Years Riding: 32
I went with: Awesome.
Really, really love the mojo the Griso exudes. If you did into the specs, the engine is actually more technologically advanced than one might assume especially the " Multipoint sequential electronic injection, Magneti Marelli IAW 5A phased, alfa-n system; 2 x Ø50 mm throttle bodies with Weber IWP 189 injectors, Lambda probe. " that's state of the art and very few motorcycles offer this EFI refinement.
So happy that Guzzi is still refining this bike, even after it's introduction a decade ago. You would almost think Guzzi would put a full fairing on it and made a supersport bike version out of it as well.
I absolutely wish I could fit on this motorcycle and ride it. It's just too small for my legs but that doesn't stop me from jumping on a Griso every time I see it at a dealership or a trade show! No sir. I'll wait in line for the opportunity in fact.
Now if they can just put the Griso engine into the V7 or made a Griso "stretched" for us 6'4" people.
Awesome bike.
ceemes wrote:After serving up the that crap-pie CCW offering last week, Mike has redeemed himself by offering up a proper if quirky bike from a proper if quirky manufacturer...
LOL. Your most welcome! I'm just happy the CCW bike didn't cause the ruckus it did a couple years ago when we had over 100 awesome votes for it!
ZRex
Real Name: Ben
#7 Unread post by ZRex »
I would probably vote Awesome for the looks alone, but this Guzzi would be insanely fun to ride, so I easily voted Awesome.
Years Riding: 32
Featured: October 9th, 2015 - October 16th 2015
Motorcycle Cool Wall discussion: viewtopic.php?f=61&t=52225
Total Motorcycle model page: http://www.totalmotorcycle.com/motorcyc ... -8V-SE.htm
Awesome (3 points) 77% [ 20 ]
Cool (2 points) 15% [ 4 ]
Uncool (1 point) 8% [ 2 ]
Fail (0 point) 0% [ 0 ]
Total votes: 26
= a Coolwall Factor of 89.7%
Notes: Moto Guzzi is on a tear this year as the 2015 Moto Guzzi Griso 8V SE shoots to the #1 top of the 2015 Cool Wall chart! That's makes Moto Guzzi models in all 3 top spots, an incredible result. Whatever is it Moto Guzzi is doing right for riders they are doing it the best in the industry. That said, we still have another 2.5 months of 2015 left...
