2016 Royal Enfield Classic Desert Storm - Coolness Factor = 64.7%
Posted: Fri Apr 29, 2016 5:31 am
2016 Royal Enfield Classic Desert Storm on the Total Motorcycle Cool Wall
For MORE information and Photos click here: http://www.totalmotorcycle.com/motorcyc ... -Storm.htm
1950's Style....
The Classic Desert Storm comes to you with a “sand” paint scheme reminiscent of the war era, a time when Royal Enfield motorcycles proved their capabilities and battle worthiness by impeccable service to soldiers in harsh conditions of the desert. Donning a younger look with styling cues one would expect only from a genuine Royal Enfield: single cylinder air-cooled pushrod engine, 1950s style nacelle and toolboxes, traditional paint scheme and buffed engine components, this motorcycle is all set to bring you the pleasures of modern motorcycling while reflecting the aura of eternal classic styling.
2016 Royal Enfield Classic Desert Storm http://www.Totalmotorcycle.com Features and Benefits
Engine
500cc, single cylinder, 4 stroke, spark ignition, air cooled, OHV engine produces 41.3 Nm of torque.
Headlamp
Headlight casing features the “Tiger Eye Lamps” for the Bullet look. The headlamp is traditional but with a powerful halogen bulb to provide good illumination.
Silencer
Aesthetically designed short silencer for that 1950’s look. Available as an optional accessory for off-road use only.
Tank
Finely crafted tank with post war era graphics and thigh pads make for a vintage look.
Wheel
Front: 19” Rear: 18”
2016 Royal Enfield Classic Desert Storm - http://www.Totalmotorcycle.com USA Specifications/Technical Details
US MSRP Price: $ See Dealer for pricing in USD
Canada MSRP Price: $ See Dealer for pricing in CDN
International MSRP Price: £4499 GBP (On The Road inc 20% Vat)
engine
Type Single Cylinder, 4 stroke,Twinspark
Displacement 499cc
Bore x stroke 84mm x 90mm
Compression Ratio 8.5:1
Maximum Power 27.2 bhp @ 5250 rpm
Maximum Torque 41.3 Nm @ 4000 rpm
Ignition System Digital Electronic Ignition
Clutch Wet, multi-plate
Gearbox 5 Speed Constant Mesh
Lubrication Wet sump
Engine Oil 15 W 50 API, SL Grade JASO MA
Fuel Supply Keihin Electronic Fuel Injection
Air Cleaner Paper Element
Engine Start Electric/Kick
chassis & suspension
Type Single downtube, using engine as stressed member
Front suspension Telescopic, 35mm forks, 130mm travel
Rear suspension Twin gas charged shock absorbers with 5-step adjustable preload, 80mm travel
dimensions
Wheelbase 1370 mm
Ground Clearance 135 mm
Length 2160mm
Width 800 mm
Height 1050mm
Kerb Weight 187 Kg (with 90% Fuel & Oil)
Fuel Capacity 14.5 Ltr (3.83 Gallon)
brakes & tyres
Tyres Fr. 90/90 – 19” – 52V
Tyres Rr. 110/80 – 18” – 58V
Brakes Front 280mm Disc, 2-Piston caliper
Brakes Rear 153mm Drum, Single Lead Internal Expanding
electricals
Electrical System 12 volt - DC
Battery 12 volt, 14 Ah
Head Lamp 60 W / 55 W, HALOGEN
Tail Lamp 21 W / 5 W
1950's Style....
Engine
Headlamp
Silencer
Tank
Wheel
engine
Displacement 499cc
dimensions
Wheelbase 1370 mm
Length 2160mm
Width 800 mm
Height 1050mm
brakes & tyres
electricals
