2016 Hyosung GT650R - Coolness Factor = 50.0%
Posted: Fri Jun 24, 2016 3:24 am
2016 Hyosung GT650R Review on the Total Motorcycle Cool Wall
For MORE information and Photos click here: http://www.totalmotorcycle.com/motorcyc ... yosung.htm
2016 Hyosung GT650R
way to experience velocity....
The GT650R inspires rider confidence whether you're commuting to work or dominating at the racetrack. The 650cc 90-degree DOHC 8 valve fuel-injected V-twin engine delivers both peak power and a broad usable power band, while the adjustable suspension, inverted forks and oval tube frame provide you exceptional performance and extraordinary rider feedback. Four-piston calipers enhance breaking power and a LED tail lamp enhances your visibility and safety at night, while clip-on handlebars, three-position adjustable rearsets and a race-inspired full fairing complete the sportsbike package.
Whether naked or faired, the GT delivers all around performance and handling.The GT650 family starts with a rigid chassis and adjustable suspension that gives precise handling and feedback.650cc,90 degree DOHC, 8 valve, fuel injected V-twin engine gives both high peak power and a broad usable power band. The new 4-piston calipers enhance braking power and a LED tail lamp
enhances your visibility and safety at night. GT650R with clip on handle bars, adjustable foot pegs, race inspired full fairing and narrow and higher seat complete the sport bike package.
2016 Hyosung GT650R http://www.Totalmotorcycle.com Key Features
90° v-twin engine delivers high peak power and a broad usuable powerband makes the GT650 a great all around performer.
Features 41mm adjustable inverted forks and dual disc brakes in the front.
4 piston calipers on the front brakes provide the stopping power needed for sport riding and safety.
Wide 160/60-17 rear tire provides the traction to keep you moving and safe.
Dual stacked headlights provide the clear path for safe riding.
Adjustable rear sets allow the rider to set the right leg position for comfort and performance.
2016 Hyosung GT650R - http://www.Totalmotorcycle.com USA Specifications/Technical Details
US MSRP Price: $6599 USD
Canadian MSRP Price: $7499 CAD
Chassis Overall Length 82.28 inches
Overall Height 44.68 inches
Overall Width 27.56 inches
Wheel Base 56.50 inches
Seat Height 32.68 inches
Brake Front: 300Ø Semi Floating double discs, 4 pistons calipers
Brake Rear: 230Ø Single disc, 2 pistons caliper
Suspension Front: 41Ø Upside down Telescopic (Compression, Rebound damping adjustable)
Suspension Rear: Swing arm with Progressive linkage Hydraulic Mono shock absorber (Preload adjustable)
Tire Front: 120/60 ZR-17 / Rear: 160/60 ZR-17
Frue Tank CapacitY 4.5gal
Curb Weight 474lbs
Engine Type Liquid cooled DOHC 8-valve 90°; V-twin
Displacement 647cc
Bore x Stroke 81.5 x 62
Compression Ratio 11.5 : 1
Fuel System Fuel injection
Lubrication Wet sump
Transmission Clutch Wet, Multiplate
Gear Constant mesh 6-speed
Final Drive Chain
Warranty 2 Year Limited 1st year parts & labor, 2nd year parts
2016 Hyosung GT650R
Curb Weight 474lbs
Displacement 647cc
Final Drive Chain
