2016 BMW R NineT Scrambler - Coolness Factor = 73.3%
Posted: Fri Jul 22, 2016 8:08 am
2016 BMW R NineT Scrambler on the Total Motorcycle Cool Wall
For MORE information and Photos click here: http://www.totalmotorcycle.com/motorcyc ... ambler.htm
2016 BMW R NineT Scrambler on http://www.Totalmotorcycle.com
Honest. Untamed. Air-cooled...
Feel the wind, lean into every curve and experience the freedom in every mile you ride – the BMW R nineT Scrambler empowers you to do your own thing. Tough, unconventional, and against established standards. Made for true characters who want their bike to be pure and minimalistic.
See, hear, feel.
The unique sound of the R nineT Scrambler is a real attention grabber. The classic 1200 cc boxer engine and its high-positioned dual silencer give the bike a powerful voice.
Compared to the R nineT, the handlebars are placed higher and the comfortable seat is repositioned. This ensures a confident and relaxed seating position for every rider. In combination with the slightly longer spring travel, you'll overcome rough spots with ease.
No limits.
Dual sport tires, a high exhaust system, and a relaxed, upright riding position help the Scrambler keep riding where the pavement ends. The 19-inch front wheel, the analog tachometer, a purist steel tank in monolith metallic matte and other unique details turn the Scrambler into a high-quality classic. And with just a few steps you can give the R nineT Scrambler your own individual touch.
Pure Scrambler. Pure BMW Motorrad. The R nineT Scrambler is at the highest level in matters of safety, reliability and quality. Standard ABS and optional ASC provide extra safety.
Make your statement with the R nineT Scrambler.
The new BMW R nineT Scrambler – a down-to-earth character beyond established conventions.
They were ridden by action heroes on the screen and scores of hobby racers entered mountain and beach races on them: the Scramblers. With deep-treaded tyres, a raised exhaust, somewhat extended spring travel and a relaxed seating position, Scramblers offered their riders in the 1950s to 1970s not just motorcycling fun on winding country roads but also great off-road capability and therefore an extended range of use. Like the motorcycles themselves, the people who rode Scramblers were not bound by established conventions. And they could be seen virtually everywhere: on winding country roads, stony mountain passes and - where it was allowed - even on sandy beaches.
2016 BMW R NineT Scrambler - http://www.Totalmotorcycle.com USA Specifications/Technical Details
US MSRP Price: $ TBA (including ABS) USD *Expected arrival at dealerships Q3 2016
Canada MSRP Price: $ See Dealer for pricing in CDN
Engine
Capacity 1170cc
Bore/stroke mm 101/73
Output kW/hp 81/110 at engine speed rpm 7 750
Torque Nm 116 at engine speed rpm 6 000
Type air/oil-cooled 2-cylinder boxer engine
No. of cylinders 2
Compression/fuel 12.0:1 / premium unleaded (95-98 RON)
Valve/accelerator actuation DOHC
Valves per cylinder 4
Ø intake/outlet mm 39/33
Ø Throttle valves mm 50
Engine control BMS-MP
Emission control closed-loop 3-way catalytic converter
Electrical system
Alternator W 720
Battery V/Ah 12/14 maintenance-free
Headlight W 60/55 H4
Starter kW 1.2
Power transmission - gearbox
Clutch Hydraulically activated dry clutch
Gearbox constant-mesh 6-speed gearbox
Primary ratio 1.737
Transmission ratios I 2.375
II 1.696
III 1.296
IV 1.065
V 0.939
VI 0.848
Rear wheel drive Universal shaft
Transmission ratio 2.91
Suspension
Frame construction type Tubular space frame in steel, engine self-supporting
Front wheel suspension Telescopic fork, Ø 43mm
Rear wheel suspension BMW Paralever
Total spring travel, front/rear mm 125/140
Wheel castor mm 110.6
Wheelbase mm 1 527
Steering head angle ° 61.5
Brakes front Hydraulically activated twin disc brake, Ø 320 mm; rear Single-disc brake Ø 265 mm
ABS BMW Motorrad ABS
Wheels Aluminium cast wheel; front 3.0 x 19"; rear 4.5 x 17"
Tyres front 120/70 ZR19, rear 170/60 ZR17
Dimensions and weights
Total length mm 2 175
Total width with mirrors mm 880
Seat height mm 820
DIN unladen weight, road ready kg 220
Permitted total weight kg 430
Fuel tank capacity l 17
Performance figures
Fuel consumption (WMTC) l/100 km 5.3
0-100 km/h s 3.6
Top speed km/h 200
See, hear, feel.
No limits.
Engine
Capacity 1170cc
No. of cylinders 2
Electrical system
Alternator W 720
Starter kW 1.2
Primary ratio 1.737
II 1.696
III 1.296
IV 1.065
V 0.939
VI 0.848
Suspension
Wheelbase mm 1 527
Seat height mm 820
Performance figures
0-100 km/h s 3.6
Top speed km/h 200
