2017 Triumph Tiger Explorer XRt - Coolness Factor = 45.8%
Your Coolness Factor of the 2017 Triumph Tiger Explorer XRt is:
View results
Unread post by totalmotorcycle » Fri Sep 16, 2016 12:23 pm
2017 Triumph Tiger Explorer XRt on the Total Motorcycle Cool Wall
For MORE information and Photos click here: http://www.totalmotorcycle.com/motorcyc ... er-XRt.htm
2017 Triumph Tiger Explorer XRt Review on http://www.Totalmotorcycle.com
Ultimate Road Orientated Adventure Bike....
The all-new Tiger Explorer XRT packs immense power and linear torque from its signature 1215cc triple engine and is optimised for road riding with cast wheels, ABS, Traction control and Brembo monobloc 4-piston radial callipers at the front, and a single 282mm disc, 2-piston sliding calliper at the rear. The XRT also incorporates Triumph’s electronically controlled semi-active suspension system (TSAS) continuously adjusts the suspension settings as you ride, delivering the best control, comfort and riding experience on any surface.
Five new selectable Rider modes; Road, Rain, Sport, Off-Road and fully customizable ‘Rider’ mode, incorporate different setting for ABS, traction control and throttle maps, each optimised to suit the selected mode for maximum control, comfort and rider engagement.
With an electronically adjustable touring screen, hand guards, heated grips, heated seats for both rider and pillion as well as pannier rails and cruise control as standard, crossing continents or the daily commute to work is an ease. It is the ultimate road orientated adventure bike.
2017 Triumph Tiger Explorer XRt http://www.Totalmotorcycle.com Key Features
Additional to Tiger Explorer XRX
•Electrically adjustable Touring screen
•Engine protection bars
•Heated rider and passenger seat
•Hill Hold Control
•Pannier rails for aluminium panniers
•"Sport" and fully customizable "Rider" riding mode
•TPMS
Plus Additional to Tiger Explorer XR
•Additional 12V Power Socket
•Advanced On Board computer
•cornering optimised ABS and Traction Control
•Cruise control
•Hand guards
•Heated grips
•Inertial Measurement Unit (IMU)
•"Off Road" riding mode
•Triumph Semi Active Suspension (TSAS)
•Self cancelling indicators
Plus XR Standard Equipment
•ABS and Traction Control
•Brembo monoblock 4-pistons radial calipers
•Centre stand
•Electrically adjustable screen
•Immobiliser
•Newly designed cast wheels
•On Board computer
•Road and Rain riding modes
•Sump guard
•USB Power Socket
•Adjustable WP front and rear suspension
•12V Power Socket
The new Tiger Explorer family has been conceived, designed and built to deliver the ultimate go anywhere, do anything transcontinental touring motorcycle for every adventure rider, wherever they ride.
Everything feels right with the world
Our new Tiger Explorer is packed full of new rider-focused technology to ensure superb handling stability and control that can be tailored to your personal preference, letting you get the most out of your ride, whether on road, trail or byway.
The range is divided in to two distinct model variants. The XR series are optimised for road use, while the XC models thrive in more rugged terrain, but both are equally happy when the roles are reversed.
The unique-in-class 1215cc triple engine delivers more power, more torque and improved fuel consumption, smoothly and progressively across the whole rev range.
2017 Triumph Tiger Explorer XRt - http://www.Totalmotorcycle.com Specifications/Technical Details
US MSRP Price:19500 USD
CAD MSRP Price: TBA
ENGINE AND TRANSMISSION
Type Liquidcooled, 12 valve, DOHC, inline 3cylinder
Capacity 1215cc
Bore Stroke 85 mm / 71.4 mm
Max Power EC 139 Hp (102 kW) @ 9,300 rpm 90.7 FTlbs (123 Nm) @ 6,200 rpm
Max Torque EC 123 Nm @ 6,200 rpm
System Ride by Wire, fuel injection
Exhaust Stainless steel 3 into 1 header system, side mounted stainless steel silencer
Final drive Shaft drive
Clutch Wet, multiplate hydraulically operated, torque assist
Gearbox 6speed
CHASSIS
Frame Tubular steel trellis frame
Swingarm Singlesided, cast aluminium alloy with shaft drive
Front Wheels Cast aluminium alloy 10spoke 19 x 3.0in
Rear Wheels Cast aluminium alloy 10spoke 17 x 4.5in
Front Tires 120/70 R19
Rear Tires 170/60 R17
Front Suspension
WP 48mm upside down forks, electronically adjustable damping, 190mm travel.
Rear Suspension
WP monoshock, electronically adjustable semi active damping, 193mm wheel travel. Automatic preload adjustment.
Brakes Front Twin 305 mm floating discs, radially mounted monobloc Brembo calipers, 4piston, switchable ABS
Brakes Rear Single 282mm disc, Nissin 2piston sliding caliper, switchable ABS
Instrument Display and Functions
Instrument pack with analogue tachometer, fixed segment LCD display and multifunction dot matrix LCD display. Fixed segment LCD display: speedometer, fuel gauge, gear position indicator, service indicator, clock, ambient air temperature, coolant temperature, cruise control status and set speed. Multifunction DOT matrix LCD display: five Riding Modes (Road, Rain, OffRoad,
Sport, Rider), windscreen adjustment, TSAS setting, Trip computer (journey distance, journey time, average fuel consumption, average speed), motorcycle information (odometer, rangetoempty, instantaneous fuel consumption, TPMS), settings menu, heated grips status, heated seat status.
DIMENSIONS AND WEIGHTS
Width
Handlebars
32.7 in (830 mm) With handguards: 36.6 in (930 mm)
Height Without Mirror
57.9 in (1470 mm) 60.6 in (1540 mm) with higher screen position
Seat Height 33.0 33.7 in (837 857 mm)
Wheelbase 59.8 in (1520 mm)
Rake 23.1¢ª
Trail 3.9 in (99.2 mm)
Dry Weight 560 lbs (254 Kg)
Tank Capacity 5.3 US Gallon
FUEL CONSUMPTION
Fuel Consumption **
40.6 US MPG
**Fuel economy estimates are based on the EPA exhaust emission measurement test procedures
2017 Motorcycle Model Guides
2016 Motorcycle Model Guides
ceemes
Real Name: a big secret
Re: This Week: 2017 Triumph Tiger Explorer XRt - VOTE NOW
Unread post by ceemes » Sat Sep 17, 2016 9:42 am
Not bad, gave it a cool. But in my humble opinion, it has far too much electronics to be an adventure bike. It's fine if you adventure riding is only done with a 100 miles or so of the nearest Triumph certified repair tech/shop, but I would be very worried about taking it out into the rough of say outer Mongolia or the back roads of Northern BC. IMHO, a proper adventure type bike should adhere to the KISS principle (Keep it simple stupid) and it rider should be able to do basic road side or trail side repairs with a screw drive and an adjustable wrench, and not have to plug into a diagnostic computer to tell him which electronic do-hickey has failed and need to be replaced.
[img]http://i38.tinypic.com/2j0gmzq.jpg[/img]
Unread post by totalmotorcycle » Fri Sep 23, 2016 10:21 am
...and here I thought I would be the only one who voted Fail.
It's a nice looking bike overall, I like the look of the frame, the red colour and the little sporty skid plate... and I have to agree with ceemes, dual sport bikes are really meant to be simple, light and if I may add, mid-sized engined. 1215cc, 560lbs, loads of gadgets and super tall... not a great combination.
What's amazing, is there are 6 additional 2017 Triumph Tiger Explorer 1200cc versions! Talk about waaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaay too many versions... Triumph takes the cake by a football field.
Unread post by totalmotorcycle » Fri Sep 23, 2016 10:35 am
Featured: September 16th - September 23th, 2016
Most popular vote category: Tie Cool/Fail
Motorcycle Cool Wall discussion: viewtopic.php?f=61&t=53634
Total Motorcycle model page: http://www.totalmotorcycle.com/motorcyc ... er-XRt.htm
Awesome (3 points) 19% 19% [ 3 ]
Cool (2 points) 31% 31% [ 5 ]
Uncool (1 point) 19% 19% [ 3 ]
Fail (0 point) 31% 31% [ 5 ]
Total votes: 16
= a Coolwall Factor of 45.8%
Notes: Triumph makes some great bikes and are well known for their 3-cylinder engines, unique retro styling and British heritage... The original Triumph Tiger, a mid-sized adventure bike, started them onto the less traveled path... But somewhere along the way, there was a fork in the road and now they are lost. Our readers agree, the new 2017 Triumph Tiger Explorer XRt is just not right.
Users browsing this forum: ceemes, Google Adsense [Bot], pja2536, Yahoo [Bot] and 178 guests
cron
