2017 Suzuki VanVan200 - Coolness Factor = 60.3%
Your Coolness Factor of the 2017 Suzuki VanVan200 is:
View results
Unread post by totalmotorcycle » Tue Oct 11, 2016 11:00 am
2017 Suzuki VanVan200 on the Total Motorcycle Cool Wall
For MORE information and Photos click here: http://www.totalmotorcycle.com/motorcyc ... Van200.htm
2017 Suzuki VanVan200 on http://www.Totalmotorcycle.com
Get into the VanVan spirit...
Introducing the 2017 VanVan 200; the bike that puts the FUN in FUNKY. With its distinctive retro look, this baby is classic cool and ready to groove whenever and wherever you are. Whether you’re looking to cruise down to the beach, bop around campus, venture outside of your campsite, or go anywhere else in between, unleash your funk in whatever way your heart desires with the VanVan 200.
Its wide and spacious seat provides plenty of room for your plus-one and delivers comfort to the max; throw a leg over it and you’ll see what we mean! With easy peasy push-button starting and an advanced, compact electronic fuel injection (EFI) system, you’ll have those fat, over-sized tires rolling in no time. The Suzuki VanVan 200 is a proper motorcycle in every sense, and one that’s loaded with individuality and flair. Just like you.
Get a grip on a whole new standard. Striking looks. Comfort. Power. Versatility. Our standards deliver easy ergonomics, modern style, and metro muscle in dynamite packages. Whatever type of riding you prefer, our standards can handle it.
2017 Suzuki VanVan200 http://www.Totalmotorcycle.com Key Features
The VanVan’s 199cc, 4-stroke, 1-cylinder, air-cooled engine is built for excellent response
Easy, push-button electric starting
Advanced, compact fuel injection system and well-designed exhaust are tuned with an emphasis on low-to-mid range power delivery that’s street friendly
Carefully selected transmission gear ratios provide smooth acceleration through each gear
Air-cooled oil cooler helps stabilize the engine’s performance
Wide 18-inch front and extra-wide 14-inch balloon tires, boost the VanVan’s classic retro look and add to its unique character
Wide, pleated and plush seat has a low seat height great for both rider and passenger
Classic round headlight upfront and a bold, distinctively designed rear tail/stop light
Easy-to-read speedometer with black face and white numbers glow with color in the dark
2017 Suzuki VanVan200 - http://www.Totalmotorcycle.com USA Specifications/Technical Details
US MSRP Price: $4599 USD.
Canada MSRP Price: $TBA CDN
Europe/UK MSRP Price: £3799 GBP (On The Road inc 20% Vat)
Engine
Engine 199cc, 4-stroke, air-cooled, 1 cylinder, SOHC
Fuel System Suzuki fuel injection
Starter Electric
Drive Train
Transmission 5-speed constant mesh
Chassis
Suspension Front Telescopic, coil spring, oil damped
Suspension Rear Swingarm type, coil spring, oil damped
Brakes Front Disc brake
Brakes Rear Drum brake
Tires Front 130/80-18 M/C 66P, tube type
Tires Rear 180/80-14 M/C 78P, tube type
Fuel Tank Capacity 6.5 L (1.7 US gal)
Color Metallic Triton Blue & Metallic Matte Fibroin Gray
Electrical
Ignition Electronic ignition (CDI)
Dimensions and Curb Weight
Overall Length 2140 mm (84.3 in)
Overall Width 865 mm (34.1 in)
Wheelbase 1385 mm (54.5 in)
Ground Clearance 220 mm (8.7 in)
Seat Height 770 mm (30.3 in)
Curb Weight 128.0 kg (282.2 lbs)
2017 Motorcycle Model Guides
2016 Motorcycle Model Guides
Re: This Week: 2017 Suzuki VanVan200 - VOTE NOW
Unread post by totalmotorcycle » Fri Oct 21, 2016 9:56 am
New to this week's Cool Wall, the 2017 Suzuki VanVan200! While the Suzuki VanVan has been around before in Europe and Australia (ie, the Vanvan 125 are very popular due to graduated licensing), the VanVan 200 is completely new for North America...
Will it be a success or failure here?
ceemes
Real Name: a big secret
Unread post by ceemes » Sat Oct 22, 2016 10:44 am
I.....I am not too sure what to make of this.....okay, its a 200CC and looks a lot like the 185's you see plying around the streets of Tacloban or Manila or Singapore for that matter, at least from the front......but that huge muffler on the back and even wider rear tyre.....and a fuel tank with the capacity of a peanut shell......I just don't know what to think.......plus the name VanVan is bloody stupid.......its interesting......and should sell in SE Asia, but if they are planning flog it in NA or Western Europe, I think it will fail horribly....and I guess that give me my rating doesn't it? Fail.
Edit: having looked at it a second time, I can only conclude that someone at Suzuki found a forgotten bin full of late 70's early 80's bike parts and decided instead of tossing them out to try and put together a new bikes.......yup....fail.
Grey Thumper
Real Name: Dino
Unread post by Grey Thumper » Sun Oct 23, 2016 1:12 am
ceemes wrote:Edit: having looked at it a second time, I can only conclude that someone at Suzuki found a forgotten bin full of late 70's early 80's bike parts and decided instead of tossing them out to try and put together a new bikes.......yup....fail.
You're right about the 70's bit. Apparently these things have been around for quite some time . . .
https://en.wikipedia.org/wiki/Suzuki_RV_125_VanVan
"The Suzuki RV125 VanVan is a motorcycle series manufactured by Suzuki in the 1970s and reintroduced in 2003."
montanalifter
Real Name: Bill
Unread post by montanalifter » Sun Oct 23, 2016 9:29 am
Retro looking and retro (back drum brake). The gas tank is so small it looks bad. I don't know what is up with bike makers putting small tanks on bikes, some even large displacement bikes have smaller tanks. 1.7 gallons? I think this bike would be used for toodling along on trails in the woods or as a local commuter. A 4 gallon tank sounds much more reasonable to me. I still think it is cool but not sure how many will sell when 4.5k will get you a lot of other options.
jstark47
Unread post by jstark47 » Sun Oct 23, 2016 7:40 pm
That looks like the offspring of an unnatural liaison between a TW200 and a SR400. :?
Coming from the same company that makes the elegant TU250X.... I'm...... I dunno..... kinda speechless. :ermm: I mean, I just don't get the point of this?? Uncool, I guess. There's other small displacement bikes, including the aforementioned SR400, TW200, and TU250X, that interest me more.
NorthernPete
Years Riding: 11
My Motorcycle: 1982 Yamaha sr250
Unread post by NorthernPete » Tue Oct 25, 2016 10:10 pm
Uncool. And I'm a small bike owner. Just bad looking. Tank doesn't suit it or hold enough.
1982 sr250
Unread post by totalmotorcycle » Fri Oct 28, 2016 8:05 am
I went with: Cool
It's a fun little in-town bike that I saw running about in London, UK. Petrol is mucho expensive in London (was $8.50/gallon when I left), and having a small tank, while not great for anything long distance, does help on the pocket book for those who would buy a VanVan. But I'm not so sure about the price either, it's not very "cheap" considering the bike has been around for a (couple of) dogs age without much improvement. I even considered a TW200 as my first bike back in the day as it was quirky like the VanVan, but ended up buying the 84' Honda Magna V30 instead (we all need a V4 with Corvette beating power right?). As mentioned, there are quite a few other retro's out there, either by Yamaha or Suzuki (TU250) or even Royal Enfield in this size. So why get a VanVan? Maybe your dad had one?
Still, it would make a great first bike, very light weight, low power and a low seat height. If you love it, get it I say. It will draw attention forsure and you'll feel good owning something truly retro and unique.
Unread post by totalmotorcycle » Fri Oct 28, 2016 8:38 am
Featured: October 21st - October 28th, 2016
Motorcycle Cool Wall discussion: viewtopic.php?f=61&t=53742
Total Motorcycle model page: http://www.totalmotorcycle.com/motorcyc ... Van200.htm
Awesome (3 points) 19% 19% [ 4 ]
Cool (2 points) 48% 48% [ 10 ]
Uncool (1 point) 29% 29% [ 6 ]
Fail (0 point) 5% 5% [ 1 ]
Total votes: 21
= a Coolwall Factor of 60.3%
Notes: Who knew a 200cc starter bike could be so controversial?! A blast from the 70's past, the VanVan has been a small bike staple around the globe, now North America gets another kick at the can with the VanVan200... little has changed in over 40 years though with the VanVan except the MSRP, which is teetering on "not-such-a-great-deal-o-meter". So many other choices in the 200-500cc category makes the VanVan either a love it or hate it bike. Luckily, it's cuteness and uniqueness allowed the VanVan200 to score over 60% cool...
Jarlaxle
Real Name: John
My Motorcycle: 2012 Suzuki Burgman
Re: 2017 Suzuki VanVan200 - Coolness Factor = 60.3%
Unread post by Jarlaxle » Mon Oct 31, 2016 7:20 pm
That looks like the answer to the $4600 question that nobody asked...
Users browsing this forum: montanalifter, rtgrey and 127 guests
cron
