2017 Honda Shadow Phantom - Coolness Factor = 50.0%
Posted: Fri Feb 24, 2017 5:26 am
2017 Honda Shadow Phantom on the Total Motorcycle Cool Wall
For MORE information and Photos click here: http://www.totalmotorcycle.com/motorcyc ... hantom.htm
2017 Honda Shadow Phantom on www.Totalmotorcycle.com
The Minimalist...
The Shadow Phantom® celebrates the joy of back-to-basics motorcycling by delivering a V-twin ride packing a uniquely clean and uncluttered appearance. Check out the minimalist look and extensive blackout treatment that bring your eyeballs back to that very cool 745cc V-twin engine, featuring the convenience and sophistication of Programmed Fuel Injection. By staking out the low-profile approach to cool, the Shadow Phantom reinforces the idea that bling ain't everything in a bike.
This bike doesn’t need shiny colors and excess chrome to make its presence known.
We like to leave that to its blacked-out 745cc V-twin engine and its commanding, throaty exhaust.
The Phantom is finished off with spoked wheels on black rims, tough front fork, bobbed fenders and matte silver highlights.
No matter if you’re cruising the boulevard or taking a weekend trip, you’re going to be comfortable with the Phantom’s slightly more upright seating position. Here’s something that’s going to make you feel even more comfortable, the Phantom’s low price tag. It’s time to make your move and get on a Honda Phantom.
Feel the V-Twin Power
The Shadow Phantom’s 745cc V-twin engine features Programmed Fuel Injection (PGM-FI), ensuring easy cold-weather starting and seamless, all-condition fuel delivery.
Style That Stands Apart.
Black engine, frame, rims and handlebar—all ever-so-perfectly accented with matte silver highlights—that’s the Phantom’s trademark look. It’s a machine everyone is going to take seriously.
Engineered for the Long Run
The Phantom’s durable and virtually maintenance-free shaft final drive ensures smooth, dependable power delivery to the asphalt. No hassles, just smooth, quiet power
2017 Honda Shadow Phantom www.Totalmotorcycle.com Key Features
Impressive power
745 cc liquid-cooled V-twin engine produces impressive power over a broad rpm range.
2017 Honda Shadow Phantom - www.Totalmotorcycle.com USA Specifications/Technical Details
US MSRP Price: $7699 USD
Canada MSRP Price: $9099 CDN
ENGINE
Engine Type 745cc liquid-cooled 52 degrees V-twin
Bore And Stroke 79mm x 76mm
Induction PGM-FI with automatic enrichment circuit, one 34mm throttle body
Ignition Digital with 3-D mapping, two spark plugs per cylinder
Compression Ratio 9.6:1
Valve Train SOHC; three valves per cylinder
DRIVE TRAIN
Transmission Wide-ratio five-speed
Final Drive Shaft
CHASSIS / SUSPENSION / BRAKES
Front Suspension 41mm fork; 4.6 inches travel
Rear Suspension Dual shocks with five-position spring-preload adjustability; 3.5 inches travel
Front Brake Single 296mm disc with twin-piston caliper
Rear Brake Drum
Front Tire 120/90-17
Rear Tire 160/80-15
DIMENSIONS
Rake 34 degrees (Caster Angle)
Trail 161mm (6.3 inches)
Wheelbase 64.6 inches
Seat Height 25.8 inches
Curb Weight 549 pounds (Includes all standard equipment, required fluids and full tank of fuel
ready to ride.)
Fuel Capacity 3.7 gallons, including 0.9-gallon reserve
Miles Per Gallon
56 MPG - Honda's fuel economy estimates are based on EPA exhaust emission
measurement test procedures and are intended for comparison purposes only. Your
actual mileage will vary depending on how you ride, how you maintain your vehicle,
weather, road conditions, tire pressure, installation of accessories, cargo, rider and
passenger weight, and other factors.
OTHER
Emissions
Meets current EPA standards. California version meets current California Air
Resources Board (CARB) standards and may differ slightly due to emissions
equipment.
Available Colors Matte Black Metallic
Model ID VT750C2B
FACTORY WARRANTY INFORMATION
One Year Transferable, unlimited-mileage limited warranty; extended coverage available with
a Honda Protection Plan.
The Minimalist...
Impressive power
ENGINE
DRIVE TRAIN
Final Drive Shaft
Rear Brake Drum
Rear Tire 160/80-15
DIMENSIONS
ready to ride.)
Miles Per Gallon
OTHER
Emissions
equipment.
Model ID VT750C2B
