This shifting thing......
Baltimore Newbie
#1 Unread post by Baltimore Newbie »
is'nt going well at all. My upshifts are getting a little bit better but still not 100% smooth. But my downshifts are jerky as all hell. I even skidded the back tire today and that scared the hell out of me because I thought it was going to catch and highside me. I bought David Hough's Proficient Motorcycling but that was mostly about cornering. So I went out and bought Total Control by Lee Parks. That's a good book and in it he suggested "blipping" the throttle. I tried this the way he said it and I could'nt get it to work for me. In the book the method described is to turn the throttle about 50% of the way as soon as you pull the clutch in. But when I tried that and let out the clutch, I got rocketed forward.
The only time I can really get a smooth downshift is when I am either coming down from highway speeds or going really slow, like pulling up to a red light and dragging the rear brake. Does anybody know how to make this throttle blip thing work? Any suggestions or help would really be appreciated.
m1a1dvr
#2 Unread post by m1a1dvr »
I was having the same problem. What I do to fix that is I just slow down to the point of the tach reading 2500-3000 RPM's. Then I will down shift and let the clutch out slowly. That will give me a smoothe downshift.
[img]http://i82.photobucket.com/albums/j270/m1a1dvr/dvrcopy.jpg[/img]
VermilionX
#3 Unread post by VermilionX »
1st of all, hough's book isn't all about cornering. :laughing:
that's just the 1st chapter.
blipping is simply a quick on-off-on throttle use. it works for both upshift and downshift. very important to learn if you wanna try clutchless shifting.
anyway... i was like that when i started, but then i got better as i ride the bike more. just keep practicing and get used to your machine.
VermilionX
#4 Unread post by VermilionX »
m1a1dvr wrote:I was having the same problem. What I do to fix that is I just slow down to the point of the tach reading 2500-3000 RPM's. Then I will down shift and let the clutch out slowly. That will give me a smoothe downshift.
each bike handles differently... so giving your rpm range won't neccessarily work for his bike. :wink:
m1a1dvr
#5 Unread post by m1a1dvr »
I realize that. But I was just saying how low I accually take the RPM's before I shift.
VermilionX
#6 Unread post by VermilionX »
m1a1dvr wrote:I realize that. But I was just saying how low I accually take the RPM's before I shift.
touché! :laughing:
Baltimore Newbie
#7 Unread post by Baltimore Newbie »
VermilionX wrote:1st of all, hough's book isn't all about cornering. :laughing:
what do you mean by on-off-on?
m1a1dvr
#8 Unread post by m1a1dvr »
What he means is to get on the throttle and then right off of it. All it is a real quick jab of throttle. Just to bring the RPM's up to match the new engine speed that the downshift is going to cause.
Kal
Real Name: Jade
#9 Unread post by Kal »
Hows your clutch control?
Kal...
Relationship Squid...
GPZ500S, CB250N, GB250Clubman
OoJRod06oO
#10 Unread post by OoJRod06oO »
When I downshift I pull the clutch in, downshift, give it a little bit of throttle to help the engine match the bikes speed and slowly let out on the clutch. I don't know if this is what "blipping" is but it seems to work fine for me and I've been told it's a little easier on your clutch in the longrun.
