shaft drive, vs belt driven
which is better?
1. shaft driven, is longer lasting, nearly maintence free.
2. shaft loses about 5+% of its rwp
3. its bulky and heavy
4. can not easily change the final drive ratio
5. much more durable and, smoother in long rides
Belt
1. quiet
2. direct connect, so u get majority of ur power
3. nearly maintence free, just a new belt
4. lighter
5. can easy change final drive ratio
6. smooth but maybe not as smooth as drive
can anyone add to this , im in a delima
Belt
1. quiet
4. lighter
- jmillheiser
- jmillheiser
- Kal
- Real Name: Jade
- Years Riding: 14
hmmm
What about chain drive though?
Kal...
Relationship Squid...
GPZ500S, CB250N, GB250Clubman
- jmillheiser
I would also check out the V-stars as well. The 1300 is new for 07 (slated to replace the 1100). The 650 will be cheaper and lighter, the 1100 will have more power and may or may not be easier to find used.
Pretty much any metric cruiser under 60hp would be perfectly fine for most new riders. the HD sportster 883 is also a decent choice though used ones cost almost as much as new ones (if you dont load an 883 down with options its actually pretty reasonable)
- Randy
- Legendary 300
- Real Name: Randy
- My Motorcycle: 2007/Honda/CBR1000
Cruisers are heavy in general. Who cares about an extra 10 or 15 pounds.
You negate all chain/belt lash and only have to change out hypoid oil about once a year if you go for the shaft drive.
I am kinda partial to the shaft drive for cruisers.
Trying is the first step towards failure - Homer Simpson
05 Yamaha VMAX
04 Suzuki SV650
05 Suzuki RMZ450
05 Yamaha VMAX
04 Suzuki SV650
05 Suzuki RMZ450
- Sev
I'd say... sit on them both. Find out which one is the most comfortable and then buy that one. In today's "modern age," the final drive is basically irrlevant to the bike you get. 10 lbs here or there, or having to change out the belt or drive oil isn't something that is going to bother you.
An uncomfortable seating position, bars that are to wide or to narrow, bad positioning of footpegs... these will make you unhappy. How the bike puts power to pavement is for all intents and purposes irrlevant. It REALLY only becomes an issue if you don't like something about the bike.
EG. Well... I like my bike, BUT*, the bars are to high, the seat is bloody hard, the pegs are to far forward. Oh and I have to lube the chain. It's always the last thing you mention when you complain about the bike, and you wouldn't be complaining about it if you didn't have the other problems.
*Note: I love my bike, everything about it, but the rockhard seat... and I'm learning to cope.
