The "how do I do this" thread
- sapaul
- Years Riding: 90
Ask away, no such thing as a stupid question, an example would be
why is it better to ride with the balls of your feet on the pegs ?
- Real Name: Ryan
Re: The "how do I do this" thread
I've been finding out the answer to that one lately... My feet, (or boats as Mom calls them) have been dragging on the ground when I start to lean over decently. Never happened on my Volusia, but happens daily on my Z... haha.
Like SaPaul says, ask away!
- sapaul
- Years Riding: 90
How do I know when to change tyres?
- Real Name: Ryan
Look on the side of your tire, and on the sidewall of it you'll see a triangle. That triangle points to the tread, and there is an extra piece of rubber in the tread above it. That's your Tread Wear Indicator (often called TWI). If your tread is at the same height as your TWI, it's time to change tires. A lot of people go past the TWI and that's very dangerous in conditions other than dry pavement.
- Real Name: Ryan
How do I know when my chain and sprocket need to be adjusted/replaced?
- sapaul
- Years Riding: 90
When your chain snaps, locks up your wheel and thows you off the bike, or when the stealership say's he can sell you a nice chain and sprocket ............... yes/no
- Johnj
- Real Name: Johnny Strabler
If your chain has more than ¾ of an inch of slack, in the middle of it's run, you may need to adjust your chain.
If you can lift the chain off the sprocket and/or the teeth of the sprocket are hooked, you may need to change your chain and sprocket set.
- Real Name: Ryan
No that's just plain fun...sapaul wrote: When your chain snaps, locks up your wheel and thows you off the bike, or when the stealership say's he can sell you a nice chain and sprocket ............... yes/no
- sapaul
- Years Riding: 90
Cool, JohnJ your turn for the question
