What about Chinese bikes?
ill'n
#16 Unread post by ill'n »
TechTMW wrote:I would also like to point out that Taiwan is NOT China.
Amen to that! :P
obxbiker
#17 Unread post by obxbiker »
Lots of great comments about the Hyosungs and Kymco.
Have a little to add about Kymco.
Like Hyosung was involved with Susuki , Kymco for 40 years had a close relationship with Honda up until the 2000's.
Have you ever seen a Honda Magna 250/vt250 ?
They were made for the overseas market from the mid 90's till 2002, the same year that the Venox 250 was released overseas.
They are "basicly" the same bike.
The Venox has a diffferent seat, body panels and larger gas tank. The engine also has been retuned.Most of the other parts are the same. Thats why the Venox has such a great record as it is really not a new bike with new bike problems.
Here is a photo of the Honda Magna 250/VT250:
Kymco Venox:
HONDA MAGNA 250............vs..................KYMCO VENOX 250
Engine and transmission
Displacement:.....249.00 ccm (15.19 cubic inches)....................SAME
Engine type:....... V2 ..............................................................SAME
Stroke: ...............4.................................................................SAME
Power: ................27.00 HP (19.7 kW)) @ 10000 RPM............28hp [27.50 HP (20.1 kW)) @ 10500 RPM]
Torque: ...............23.00 Nm................................................. 19.80 Nm
(2.3 kgf-m or 17.0 ft.lbs) @ 7500 RPM................................... (2.0 kgf-m or 14.6 ft.lbs) @ 8500 RPM ]
Compression: ......11.0:1.....................................................N/A
Bore x stroke: .....60.0 x 44.1 mm (2.4 x 1.7 inches).............58x47.2
Fuel system: ........Carburettor.............................................SAME
Valves per cyl:..... 4.............................................................SAME
Fuel control: .........DOHC.....................................................SAME
Cooling system:.... Liquid.....................................................SAME
Gearbox:.............. 5-speed...................................................SAME
Physical measures
Dry weight:............171.0 kg (377.0 pounds)........................418.5 lbs.
Seat height:........... 690 mm (27.2 inches)...........................29 in. (736.6mm)
Overall height:........1,065 mm (41.9 inches).........................1,080 mm (42.5 inches)
Overall length:....... 2,315 mm (91.1 inches).........................2,325 mm (91.5 inches)
Overall width:.........880 mm (34.6 inches)............................840 mm (33.1 inches)
Ground clearance:...130 mm (5.1 inches).............................N/A
Wheelbase: ............1,620 mm (63.8 inches)........................63 in. (1600.2mm)
Chassis and dimensions
Front tyre: .............120/80-17 61S ....................................SAME
Rear tyre: ...............150/80-15 M/C 70S..............................SAME
Front brakes: ...........Single disc..........................................SAME
Rear brakes: ............Expanding brake.................................DRUM
Speed and acceleration
Power/weight ratio: ...0.1579 HP/kg...................................... 0.1571 HP/kg
Other specifications
Fuel capacity: ...........11.00 litres (2.91 gallons).....................3.7 gallons(14 liters)
Here is a lot more information on the Venox and the Hyosung Cruisers:
Kymco & Hyosung
[size=59][b]CLICK ON BANNER[/b][/size]
[url=http://z11.invisionfree.com/HyosungCruisersOz/index.php?showtopic=2800&st=0][img]http://i73.photobucket.com/albums/i220/obxbiker/venoxbanner.jpg[/img][/url]
intotherain
My Motorcycle: FZ6
#18 Unread post by intotherain »
CHINA BIKE BAD, KOREA GOOD, JAPAN GOOD
DONT GET LIFAN or any of those chinese bikes.
I have to tighten almost every single thing on that bike every week. Everything comes loose, the chooke holder, handlebars, pegs, wheel. Its quite scary.
I had the same sit. as you where I just wanted a cheap bike to start with, but now I just wish I saved up for 1 more month and gotten a ninja 260 or 500.
qwerty
#19 Unread post by qwerty »
Dohun wrote:CHINA BIKE BAD, KOREA GOOD, JAPAN GOOD
I saved up another month and bought a Yamaha.
obxbiker
#20 Unread post by obxbiker »
Amen to that! :P
Totally different !!
entityof1
#21 Unread post by entityof1 »
well i worked in a scooter/motorcycle shop for a year, and i got to test drive the kymco 250 and was certainly impressed because it was dirt cheap. But, there is another side. It felt definitively.....cheaper. I felt like that if i wrecked it every piece of pot metal and plastic would break. i dunno just my opinion.
obxbiker
#22 Unread post by obxbiker »
entityof1 wrote:well i worked in a scooter/motorcycle shop for a year, and i got to test drive the kymco 250 and was certainly impressed because it was dirt cheap. But, there is another side. It felt definitively.....cheaper. I felt like that if i wrecked it every piece of pot metal and plastic would break. i dunno just my opinion.
Everyone is entitled to an opinion.
But my "test drive" has been owning one for over 4 years and a second one for a year and a half. I ride everyday and have over 36,000km between the two bikes and have never had them let me down unlike many other "metal" bikes that I have owned. (I have owned and rode bikes for over 38 years)
My "plastic and pot metal" venox ON THE ROAD and not in the shop like many of the "metal" bikes I've owned...well its hard to put a price on dependability !
Just wondering...what "metal" bike do you ride ?
intotherain
My Motorcycle: FZ6
#23 Unread post by intotherain »
what kind?
intotherain
My Motorcycle: FZ6
#24 Unread post by intotherain »
what kind?
Daikuma
Accessories?
#25 Unread post by Daikuma »
obxbiker wrote:Lots of great comments about the Hyosungs and Kymco.
Kymco Venox:
Physical measures
Kymco & Hyosung
Wow! Practically the same bike.
So can you bolt on older Magna 250 Accessories straight across? I'm thinking saddles, seatbacks, and saddlebags specifically, but knowing where anything might fit would be cool.
