Computer questions and solutions....thereof...
Years Riding: 11
#521 Unread post by blues2cruise » Thu Jul 09, 2009 9:27 pm
MrShake wrote:Its probably more likely a network infrastructure issue than a server size issue.
Well, whatever it is, it's horrible to work with.
Years Riding: 11
#522 Unread post by blues2cruise » Sun Sep 27, 2009 9:14 pm
I have a question about partitions.....someone suggested that it is better to have partitions so that all your work would not be lost in the event of a crash.....
Is this like having 2 hard drives in one?
Is this something that needs to be done by a pro..if it needs doing at all?
#523 Unread post by dr_bar » Sun Sep 27, 2009 10:16 pm
I have a question...
What would stop IE from connecting to the web even when the router has a good connection?
Skier
#524 Unread post by Skier » Sun Sep 27, 2009 10:34 pm
dr_bar wrote:I have a question...
IE only? Can you ping sites?
Amdonim
Real Name: AJ
My Motorcycle: 2000 ZG1000
#525 Unread post by Amdonim » Sun Sep 27, 2009 11:36 pm
blues2cruise wrote:I have a question about partitions.....someone suggested that it is better to have partitions so that all your work would not be lost in the event of a crash.....
It's relatively easy to do, I'm just not sure any way to do it with Windows already installed. It's easy enough to do while installing windows. Just make one partition big enough for programs and windows, and make another for your personal files etc...
#526 Unread post by dr_bar » Mon Sep 28, 2009 9:54 am
No, I can't ping...
Nalian
Years Riding: 5
My Motorcycle: 2011/BMW/F800R
#527 Unread post by Nalian » Mon Sep 28, 2009 11:11 am
You can do it with partition magic, but you're better off having a 2nd harddrive or drive itself. In the cirucmstance that you have a system crash that is just the OS, the 2nd partition would keep your files still. However if you have a larger issue or the harddrive itself dies - 2nd partition is no good.
What kind of files are you keeping, blues? If they are large files like pictures and such, I'd definitely recommend getting a 2nd harddrive. If it's smaller things that would fit on something like a thumb drive, just get one of those. They can be pretty cheap these days!
JC Viper
Real Name: JC
#528 Unread post by JC Viper » Mon Sep 28, 2009 11:47 am
or a portable Hard Drive from the likes of Western Digital Passport or Seagate FreeAgent Go or regular if you don't need portability.
They can store tons for reasonable prices.
Years Riding: 11
#529 Unread post by blues2cruise » Mon Sep 28, 2009 9:58 pm
Thanks everyone. I have everythig saved onto an external hard drive.
The hard drive in my computer is quite new so I don't think it's an issue.
What I have saved are mostly word documents and photographs...but they are on the external drive..
I will consider partitioning when I decide I need a new computer.
JC Viper
Real Name: JC
#530 Unread post by JC Viper » Tue Sep 29, 2009 1:44 am
blues2cruise wrote:Thanks everyone. I have everythig saved onto an external hard drive.
no need for a new PC, you can partition anytime you want. Just pop in the Window's disk or a partitioning program. Just make sure you have enough disk space for the two.
See, I'm ana about my important stuff to the point where I have one external back up along with 3 hard drives in my PC for redundancy. I have several self made programs and videos and reports that I would like to keep and hard drives have a tendency to go bad at the most inopportune moments.
Skier
#531 Unread post by Skier » Wed Sep 30, 2009 12:20 am
dr_bar wrote:No, I can't ping...
Can you ping the router? Can you open up the router's web interface with the machine?
Years Riding: 11
#532 Unread post by blues2cruise » Wed Sep 30, 2009 12:48 am
What does Ping mean?
csspostal
Real Name: Tom
#533 Unread post by csspostal » Wed Sep 30, 2009 8:53 am
blues2cruise wrote:What does Ping mean?
Ping measures the round trip time that it takes for a signal from one computer to another and back again.
The smaller amount of time to get a return on the signal the better your connection.
Think Radar and speed strap :(
JC Viper
Real Name: JC
#534 Unread post by JC Viper » Wed Sep 30, 2009 10:32 am
Or a submarine SONAR... or just tapping a metal bar to make it ping... =P
jonnythan
#535 Unread post by jonnythan » Wed Sep 30, 2009 11:57 am
Pings are also a way to test connectivity to a device. While ping replies can be turned off or firewalled, getting a ping response over a network means that both sides are properly connected to the same network. Getting no ping response can be a result of a misconfigured system or network device (router, switch, etc).
fong47
#536 Unread post by fong47 » Sat Nov 14, 2009 4:28 pm
IE is very slow and I rather use Mozilla Firefox 3.5 or you can try Google Chrome and I heard it's pretty good.
#537 Unread post by dr_bar » Sat Nov 14, 2009 4:35 pm
Well, I figured out what was wrong with this stupid piece of electronics...
I had loaded ZoneAlarm after I had my drive reformatted and I couldn't find my licence for the pro version. Having down loaded it as a trial version until I could find the licence, the damned thing expired on me and locked out the web. How stupid is that???
Years Riding: 11
#538 Unread post by blues2cruise » Sat Nov 14, 2009 5:20 pm
I've been getting a box pop up that says something like...Normal was being used by....did I want to change the global somthing or other....
It happens when I try to close an email document or a word document.
This just started happening a couple of weeks ago.
what is it and why is it happening?
ofblong
Legendary 2500
Legendary 2500
Real Name: Ben
#539 Unread post by ofblong » Mon Nov 16, 2009 4:13 pm
blues2cruise wrote:I've been getting a box pop up that says something like...Normal was being used by....did I want to change the global somthing or other....
need the exact "fault" to be able to give you proper advice.
96' Honda Shadow Deluxe VLX
Years Riding: 11
#540 Unread post by blues2cruise » Mon Nov 23, 2009 12:06 am
Ok, I took a few snapshots of the boxes that pop up...
They appear in that order...sorry about the last one, I was a bit hasty and did not focus properly.
This just started a few weeks ago. I have no idea why or what it is.
The word program is also very slow.
Any clues?
