Qantas Mechanics
ZooTech
Years Riding: 18
Qantas Mechanics
#1 Unread post by ZooTech »
After every flight, Qantas pilots fill out a form, called a "gripe sheet", which tells mechanics about problems with the aircraft. The mechanics correct the problems, document their repairs on the form, and then pilots review the gripe sheets before the next flight.
Never let it be said that ground crews lack a sense of humor. Here are some actual maintenance complaints submitted by pilots (marked with a "P"); and the solutions recorded (marked with an "S") by maintenance engineers.
By the way, Qantas is the only major airline that has never had an accident.
P: Left inside main tire almost needs replacement.
S: Almost replaced left inside main tire.
P: Test flight OK, except auto-land very rough.
S: Auto-land not installed on this aircraft.
P: Something loose in cockpit.
S: Something tightened in cockpit.
P: Dead bugs on windshield.
S: Live bugs on back-order.
P: Autopilot in altitude-hold mode produces a 200 feet per minute descent.
S: Cannot reproduce problem on ground.
P: Evidence of leak on right main landing gear.
S: Evidence removed.
P: DME volume unbelievably loud.
S: DME volume set to more believable level.
P: Friction locks cause throttle levers to stick.
S: That's what they're for.
P: IFF inoperative.
S: IFF always inoperative in OFF mode.
P: Suspected crack in windshield.
S: Suspect you're right.
P: Number 3 engine missing.
S: Engine found on right wing after brief search.
P: Aircraft handles funny.
S: Aircraft warned to straighten up, fly right, and be serious.
P: Target radar hums.
S: Reprogrammed target radar with lyrics.
P: Mouse in cockpit.
S: Cat installed.
And the best one for last .............
P: Noise coming from under instrument panel. Sounds like a midget pounding on something with a hammer.
S: Took hammer away from midget
ejshotgun
#2 Unread post by ejshotgun »
Here's one that kept a staff sergeant in the Air Force from getting his 5th strip.
We were 462's which means we loaded bombs and in the case of my shop(who I'm talking about) troubleshoot/correct issues w/the weapons release system of the F111 D .
P. Malfunction in the weapons (bombs) release system.
S. Short between the headsets.
'77 KZ1000LTD
Riding again!!
scan
#3 Unread post by scan »
One of the funniest and scariest at the same time from above -
* 2003 Kawasaki ZRX1200R *
Tyrone ORourke
#4 Unread post by Tyrone ORourke »
:lol: great stuff. Though a little scary.
