Help w/ a 83 Honda vfr750 'ceptor
Alright, I finally fixed the electrical to where all the gauges work and I can actually see whats going on with the engine. While doing this I discovered another problem... the dreaded oil leak whats the best way to attack this? It seems to be all on the back... around the valve cover and such. Is it ok to check the oil level on a kickstand - or should the bike be level. It seemed fine when I bought it two weeks ago and the only thing I did was change the plugs.
- The Doctor
- Veteran
- insaneman_12
- Veteran
- Years Riding: 25
- My Motorcycle: Motorcycle
